root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.17
Committed: Sun Mar 28 20:33:14 2004 UTC (20 years, 5 months ago) by schorsch
CVS Tags: rad4R2P2, rad5R0, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.16 2004/01/02 12:47:01 schorsch Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "rtprocess.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 #define dumpheader(fp) fwrite(headlines, 1, headlen, fp)
19
20 int bradj = 0; /* brightness adjustment */
21 int doflat = 1; /* produce flat file */
22 int force = 0; /* force file overwrite? */
23 int findframe = 0; /* find a specific frame? */
24 int frameno = 0; /* current frame number */
25 int fmterr = 0; /* got input format error */
26 char *headlines; /* current header info. */
27 int headlen; /* current header length */
28
29 char *progname;
30
31 static gethfunc addhline;
32 static int transfer(char *ospec);
33 static int loadheader(FILE *fp);
34
35
36 int
37 main(int argc, char *argv[])
38 {
39 char *ospec;
40 int i;
41
42 progname = argv[0];
43
44 for (i = 1; i < argc; i++)
45 if (argv[i][0] == '-')
46 switch (argv[i][1]) {
47 case 'r':
48 doflat = !doflat;
49 break;
50 case 'e':
51 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
52 goto userr;
53 bradj = atoi(argv[++i]);
54 break;
55 case 'n':
56 findframe = atoi(argv[++i]);
57 break;
58 case 'f':
59 force++;
60 break;
61 case '\0':
62 goto gotfile;
63 default:
64 goto userr;
65 }
66 else
67 break;
68 gotfile:
69 if (i < argc-2)
70 goto userr;
71 if (i <= argc-1 && strcmp(argv[i], "-") &&
72 freopen(argv[i], "r", stdin) == NULL) {
73 fprintf(stderr, "%s: can't open input \"%s\"\n",
74 progname, argv[i]);
75 exit(1);
76 }
77 SET_FILE_BINARY(stdin);
78 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
79 while (transfer(ospec))
80 ;
81 exit(0);
82 userr:
83 fprintf(stderr,
84 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
85 progname);
86 exit(1);
87 }
88
89
90 static int
91 transfer( /* transfer a Radiance picture */
92 char *ospec
93 )
94 {
95 char oname[PATH_MAX];
96 FILE *fp;
97 int order;
98 int xmax, ymax;
99 COLR *scanin;
100 int y;
101 /* get header info. */
102 if (!(y = loadheader(stdin)))
103 return(0);
104 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
105 fprintf(stderr, "%s: bad input format\n", progname);
106 exit(1);
107 }
108 /* did we pass the target frame? */
109 if (findframe && findframe < frameno)
110 return(0);
111 /* allocate scanline */
112 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
113 if (scanin == NULL) {
114 perror(progname);
115 exit(1);
116 }
117 /* skip frame? */
118 if (findframe > frameno) {
119 for (y = ymax; y--; )
120 if (freadcolrs(scanin, xmax, stdin) < 0) {
121 fprintf(stderr,
122 "%s: error reading input picture\n",
123 progname);
124 exit(1);
125 }
126 return(1);
127 }
128 /* open output file/command */
129 if (ospec == NULL) {
130 strcpy(oname, "<stdout>");
131 fp = stdout;
132 } else {
133 sprintf(oname, ospec, frameno);
134 if (oname[0] == '!') {
135 if ((fp = popen(oname+1, "w")) == NULL) {
136 fprintf(stderr, "%s: cannot start \"%s\"\n",
137 progname, oname);
138 exit(1);
139 }
140 } else {
141 if (!force && access(oname, 0) >= 0) {
142 fprintf(stderr,
143 "%s: output file \"%s\" exists\n",
144 progname, oname);
145 exit(1);
146 }
147 if ((fp = fopen(oname, "w")) == NULL) {
148 fprintf(stderr, "%s: ", progname);
149 perror(oname);
150 exit(1);
151 }
152 }
153 }
154 SET_FILE_BINARY(fp);
155 dumpheader(fp); /* put out header */
156 fputs(progname, fp);
157 if (bradj)
158 fprintf(fp, " -e %+d", bradj);
159 if (!doflat)
160 fputs(" -r", fp);
161 fputc('\n', fp);
162 if (bradj)
163 fputexpos(pow(2.0, (double)bradj), fp);
164 fputc('\n', fp);
165 fputresolu(order, xmax, ymax, fp);
166 /* transfer picture */
167 for (y = ymax; y--; ) {
168 if (freadcolrs(scanin, xmax, stdin) < 0) {
169 fprintf(stderr, "%s: error reading input picture\n",
170 progname);
171 exit(1);
172 }
173 if (bradj)
174 shiftcolrs(scanin, xmax, bradj);
175 if (doflat)
176 fwrite((char *)scanin, sizeof(COLR), xmax, fp);
177 else
178 fwritecolrs(scanin, xmax, fp);
179 if (ferror(fp)) {
180 fprintf(stderr, "%s: error writing output to \"%s\"\n",
181 progname, oname);
182 exit(1);
183 }
184 }
185 /* clean up */
186 if (oname[0] == '!')
187 pclose(fp);
188 else if (ospec != NULL)
189 fclose(fp);
190 return(1);
191 }
192
193
194 static int
195 addhline( /* add a line to our info. header */
196 char *s,
197 void *p
198 )
199 {
200 char fmt[32];
201 int n;
202
203 if (formatval(fmt, s))
204 fmterr += !globmatch(PICFMT, fmt);
205 else if (!strncmp(s, "FRAME=", 6))
206 frameno = atoi(s+6);
207 n = strlen(s);
208 if (headlen)
209 headlines = (char *)realloc((void *)headlines, headlen+n+1);
210 else
211 headlines = (char *)malloc(n+1);
212 if (headlines == NULL) {
213 perror(progname);
214 exit(1);
215 }
216 strcpy(headlines+headlen, s);
217 headlen += n;
218 return(0);
219 }
220
221
222 static int
223 loadheader( /* load an info. header into memory */
224 FILE *fp
225 )
226 {
227 fmterr = 0; frameno = 0;
228 if (headlen) { /* free old header */
229 free(headlines);
230 headlen = 0;
231 }
232 if (getheader(fp, addhline, NULL) < 0)
233 return(0);
234 if (fmterr)
235 return(-1);
236 return(1);
237 }
