root/radiance/ray/src/px/ra_rgbe.c
Tue Apr 22 14:51:29 2025 UTC (10 days, 6 hours ago) by greg
Changes since 2.24: +3 -5 lines
fix: Changed some errors to warnings for pclose()
Tue Apr 22 04:45:25 2025 UTC (10 days, 16 hours ago) by greg
Changes since 2.23: +8 -4 lines
fix: Added check to return value of pclose() in several tools
Tue Sep 10 20:24:42 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 2.22: +25 -6 lines
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Tue Jun 11 17:24:01 2024 UTC (10 months, 2 weeks ago) by greg
Changes since 2.21: +33 -22 lines
perf(ra_rgbe): Improved error-checking and include initial header in all subsequent frames
Sat Dec 28 18:05:14 2019 UTC (5 years, 4 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.20: +1 -4 lines
Diff to previous 2.20
Thu Aug 2 18:33:47 2018 UTC (6 years, 9 months ago) by greg
Diff to previous 2.19
Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.18: +4 -3 lines
Tue Feb 2 18:02:32 2016 UTC (9 years, 3 months ago) by greg
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Fri Jan 2 12:47:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.15: +8 -6 lines
Mon Nov 10 12:28:56 2003 UTC (21 years, 5 months ago) by schorsch
Fixed size of command line buffers, and allow spaces in input file paths.
Mon Oct 27 10:24:51 2003 UTC (21 years, 6 months ago) by schorsch
Various compatibility fixes.
Thu Jul 3 22:41:44 2003 UTC (21 years, 10 months ago) by schorsch
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.11: +5 -11 lines
Wed Apr 23 00:52:34 2003 UTC (22 years ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.9: +2 -5 lines
Tue Oct 27 09:08:27 1998 UTC (26 years, 6 months ago) by gwlarson
Fri Jan 23 11:38:39 1998 UTC (27 years, 3 months ago) by gregl
Changes since 2.7: +157 -51 lines
made program read multiple frames in a single file
Fri Jan 23 09:28:29 1998 UTC (27 years, 3 months ago) by gregl
Changes since 2.6: +16 -16 lines
made program work with XYZE images as well as RGBE
Thu Nov 18 09:55:20 1993 UTC (31 years, 5 months ago) by greg
Changes since 2.5: +1 -2 lines
minor compiler warning fixes
Tue Apr 27 12:37:23 1993 UTC (32 years ago) by greg
fixed incorrect error message
Fri Oct 2 16:26:39 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.3: +4 -4 lines
Mon Sep 21 12:15:13 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.2: +12 -2 lines
Changes for PC port
Fri Jan 3 22:58:08 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.1: +11 -6 lines
fixed ordering of output header
Tue Nov 12 16:05:45 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.20
Mon Nov 11 14:01:34 1991 UTC (33 years, 5 months ago) by greg
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 2.20
Fri Aug 23 17:37:14 1991 UTC (33 years, 8 months ago) by greg
Diff to selected 2.20
