root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.21
Committed: Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
CVS Tags: rad5R4, rad5R3
Changes since 2.20: +1 -4 lines
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.20 2018/08/02 18:33:47 greg Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <math.h>
9
10 #include "platform.h"
11 #include "rtio.h"
12 #include "paths.h"
13 #include "color.h"
14 #include "resolu.h"
15
16 #define dumpheader(fp) putbinary(headlines, 1, headlen, fp)
17
18 int bradj = 0; /* brightness adjustment */
19 int doflat = 1; /* produce flat file */
20 int force = 0; /* force file overwrite? */
21 int findframe = 0; /* find a specific frame? */
22 int frameno = 0; /* current frame number */
23 int fmterr = 0; /* got input format error */
24 char *headlines; /* current header info. */
25 int headlen; /* current header length */
26
27 char *progname;
28
29 static gethfunc addhline;
30 static int transfer(char *ospec);
31 static int loadheader(FILE *fp);
32
33
34 int
35 main(int argc, char *argv[])
36 {
37 char *ospec;
38 int i;
39
40 progname = argv[0];
41
42 for (i = 1; i < argc; i++)
43 if (argv[i][0] == '-')
44 switch (argv[i][1]) {
45 case 'r':
46 doflat = !doflat;
47 break;
48 case 'e':
49 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
50 goto userr;
51 bradj = atoi(argv[++i]);
52 break;
53 case 'n':
54 findframe = atoi(argv[++i]);
55 break;
56 case 'f':
57 force++;
58 break;
59 case '\0':
60 goto gotfile;
61 default:
62 goto userr;
63 }
64 else
65 break;
66 gotfile:
67 if (i < argc-2)
68 goto userr;
69 if (i <= argc-1 && strcmp(argv[i], "-") &&
70 freopen(argv[i], "r", stdin) == NULL) {
71 fprintf(stderr, "%s: can't open input \"%s\"\n",
72 progname, argv[i]);
73 exit(1);
74 }
75 SET_FILE_BINARY(stdin);
76 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
77 while (transfer(ospec))
78 ;
79 exit(0);
80 userr:
81 fprintf(stderr,
82 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
83 progname);
84 exit(1);
85 }
86
87
88 static int
89 transfer( /* transfer a Radiance picture */
90 char *ospec
91 )
92 {
93 char oname[PATH_MAX];
94 FILE *fp;
95 int order;
96 int xmax, ymax;
97 COLR *scanin;
98 int y;
99 /* get header info. */
100 if (!(y = loadheader(stdin)))
101 return(0);
102 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
103 fprintf(stderr, "%s: bad input format\n", progname);
104 exit(1);
105 }
106 /* did we pass the target frame? */
107 if (findframe && findframe < frameno)
108 return(0);
109 /* allocate scanline */
110 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
111 if (scanin == NULL) {
112 perror(progname);
113 exit(1);
114 }
115 /* skip frame? */
116 if (findframe > frameno) {
117 for (y = ymax; y--; )
118 if (freadcolrs(scanin, xmax, stdin) < 0) {
119 fprintf(stderr,
120 "%s: error reading input picture\n",
121 progname);
122 exit(1);
123 }
124 return(1);
125 }
126 /* open output file/command */
127 if (ospec == NULL) {
128 strcpy(oname, "<stdout>");
129 fp = stdout;
130 } else {
131 sprintf(oname, ospec, frameno);
132 if (oname[0] == '!') {
133 if ((fp = popen(oname+1, "w")) == NULL) {
134 fprintf(stderr, "%s: cannot start \"%s\"\n",
135 progname, oname);
136 exit(1);
137 }
138 } else {
139 if (!force && access(oname, 0) >= 0) {
140 fprintf(stderr,
141 "%s: output file \"%s\" exists\n",
142 progname, oname);
143 exit(1);
144 }
145 if ((fp = fopen(oname, "w")) == NULL) {
146 fprintf(stderr, "%s: ", progname);
147 perror(oname);
148 exit(1);
149 }
150 }
151 }
152 SET_FILE_BINARY(fp);
153 dumpheader(fp); /* put out header */
154 fputs(progname, fp);
155 if (bradj)
156 fprintf(fp, " -e %+d", bradj);
157 if (!doflat)
158 fputs(" -r", fp);
159 fputc('\n', fp);
160 if (bradj)
161 fputexpos(pow(2.0, (double)bradj), fp);
162 fputc('\n', fp);
163 fputresolu(order, xmax, ymax, fp);
164 /* transfer picture */
165 for (y = ymax; y--; ) {
166 if (freadcolrs(scanin, xmax, stdin) < 0) {
167 fprintf(stderr, "%s: error reading input picture\n",
168 progname);
169 exit(1);
170 }
171 if (bradj)
172 shiftcolrs(scanin, xmax, bradj);
173 if (doflat)
174 putbinary((char *)scanin, sizeof(COLR), xmax, fp);
175 else
176 fwritecolrs(scanin, xmax, fp);
177 if (ferror(fp)) {
178 fprintf(stderr, "%s: error writing output to \"%s\"\n",
179 progname, oname);
180 exit(1);
181 }
182 }
183 /* clean up */
184 if (oname[0] == '!')
185 pclose(fp);
186 else if (ospec != NULL)
187 fclose(fp);
188 return(1);
189 }
190
191
192 static int
193 addhline( /* add a line to our info. header */
194 char *s,
195 void *p
196 )
197 {
198 char fmt[MAXFMTLEN];
199 int n;
200
201 if (formatval(fmt, s))
202 fmterr += !globmatch(PICFMT, fmt);
203 else if (!strncmp(s, "FRAME=", 6))
204 frameno = atoi(s+6);
205 n = strlen(s);
206 if (headlen)
207 headlines = (char *)realloc((void *)headlines, headlen+n+1);
208 else
209 headlines = (char *)malloc(n+1);
210 if (headlines == NULL) {
211 perror(progname);
212 exit(1);
213 }
214 strcpy(headlines+headlen, s);
215 headlen += n;
216 return(0);
217 }
218
219
220 static int
221 loadheader( /* load an info. header into memory */
222 FILE *fp
223 )
224 {
225 fmterr = 0; frameno = 0;
226 if (headlen) { /* free old header */
227 free(headlines);
228 headlen = 0;
229 }
230 if (getheader(fp, addhline, NULL) < 0)
231 return(0);
232 if (fmterr)
233 return(-1);
234 return(1);
235 }
