root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.13
Committed: Thu Jul 3 22:41:44 2003 UTC (22 years, 1 month ago) by schorsch
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.12 2003/06/05 19:29:34 schorsch Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 extern int addhline();
18
19 #define dumpheader(fp) fwrite(headlines, 1, headlen, fp)
20
21 int bradj = 0; /* brightness adjustment */
22
23 int doflat = 1; /* produce flat file */
24
25 int force = 0; /* force file overwrite? */
26
27 int findframe = 0; /* find a specific frame? */
28
29 int frameno = 0; /* current frame number */
30 int fmterr = 0; /* got input format error */
31 char *headlines; /* current header info. */
32 int headlen; /* current header length */
33
34 char *progname;
35
36
37 main(argc, argv)
38 int argc;
39 char *argv[];
40 {
41 char *ospec;
42 int i;
43
44 progname = argv[0];
45
46 for (i = 1; i < argc; i++)
47 if (argv[i][0] == '-')
48 switch (argv[i][1]) {
49 case 'r':
50 doflat = !doflat;
51 break;
52 case 'e':
53 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
54 goto userr;
55 bradj = atoi(argv[++i]);
56 break;
57 case 'n':
58 findframe = atoi(argv[++i]);
59 break;
60 case 'f':
61 force++;
62 break;
63 case '\0':
64 goto gotfile;
65 default:
66 goto userr;
67 }
68 else
69 break;
70 gotfile:
71 if (i < argc-2)
72 goto userr;
73 if (i <= argc-1 && strcmp(argv[i], "-") &&
74 freopen(argv[i], "r", stdin) == NULL) {
75 fprintf(stderr, "%s: can't open input \"%s\"\n",
76 progname, argv[i]);
77 exit(1);
78 }
79 SET_FILE_BINARY(stdin);
80 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
81 while (transfer(ospec))
82 ;
83 exit(0);
84 userr:
85 fprintf(stderr,
86 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
87 progname);
88 exit(1);
89 }
90
91
92 transfer(ospec) /* transfer a Radiance picture */
93 char *ospec;
94 {
95 char oname[128];
96 FILE *fp;
97 int order;
98 int xmax, ymax;
99 COLR *scanin;
100 int y;
101 /* get header info. */
102 if (!(y = loadheader(stdin)))
103 return(0);
104 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
105 fprintf(stderr, "%s: bad input format\n", progname);
106 exit(1);
107 }
108 /* did we pass the target frame? */
109 if (findframe && findframe < frameno)
110 return(0);
111 /* allocate scanline */
112 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
113 if (scanin == NULL) {
114 perror(progname);
115 exit(1);
116 }
117 /* skip frame? */
118 if (findframe > frameno) {
119 for (y = ymax; y--; )
120 if (freadcolrs(scanin, xmax, stdin) < 0) {
121 fprintf(stderr,
122 "%s: error reading input picture\n",
123 progname);
124 exit(1);
125 }
126 return(1);
127 }
128 /* open output file/command */
129 if (ospec == NULL) {
130 strcpy(oname, "<stdout>");
131 fp = stdout;
132 } else {
133 sprintf(oname, ospec, frameno);
134 if (oname[0] == '!') {
135 if ((fp = popen(oname+1, "w")) == NULL) {
136 fprintf(stderr, "%s: cannot start \"%s\"\n",
137 progname, oname);
138 exit(1);
139 }
140 } else {
141 if (!force && access(oname, 0) >= 0) {
142 fprintf(stderr,
143 "%s: output file \"%s\" exists\n",
144 progname, oname);
145 exit(1);
146 }
147 if ((fp = fopen(oname, "w")) == NULL) {
148 fprintf(stderr, "%s: ", progname);
149 perror(oname);
150 exit(1);
151 }
152 }
153 }
154 SET_FILE_BINARY(fp);
155 dumpheader(fp); /* put out header */
156 fputs(progname, fp);
157 if (bradj)
158 fprintf(fp, " -e %+d", bradj);
159 if (!doflat)
160 fputs(" -r", fp);
161 fputc('\n', fp);
162 if (bradj)
163 fputexpos(pow(2.0, (double)bradj), fp);
164 fputc('\n', fp);
165 fputresolu(order, xmax, ymax, fp);
166 /* transfer picture */
167 for (y = ymax; y--; ) {
168 if (freadcolrs(scanin, xmax, stdin) < 0) {
169 fprintf(stderr, "%s: error reading input picture\n",
170 progname);
171 exit(1);
172 }
173 if (bradj)
174 shiftcolrs(scanin, xmax, bradj);
175 if (doflat)
176 fwrite((char *)scanin, sizeof(COLR), xmax, fp);
177 else
178 fwritecolrs(scanin, xmax, fp);
179 if (ferror(fp)) {
180 fprintf(stderr, "%s: error writing output to \"%s\"\n",
181 progname, oname);
182 exit(1);
183 }
184 }
185 /* clean up */
186 if (oname[0] == '!')
187 pclose(fp);
188 else if (ospec != NULL)
189 fclose(fp);
190 return(1);
191 }
192
193
194 int
195 addhline(s) /* add a line to our info. header */
196 char *s;
197 {
198 char fmt[32];
199 int n;
200
201 if (formatval(fmt, s))
202 fmterr += !globmatch(PICFMT, fmt);
203 else if (!strncmp(s, "FRAME=", 6))
204 frameno = atoi(s+6);
205 n = strlen(s);
206 if (headlen)
207 headlines = (char *)realloc((void *)headlines, headlen+n+1);
208 else
209 headlines = (char *)malloc(n+1);
210 if (headlines == NULL) {
211 perror(progname);
212 exit(1);
213 }
214 strcpy(headlines+headlen, s);
215 headlen += n;
216 return(0);
217 }
218
219
220 loadheader(fp) /* load an info. header into memory */
221 FILE *fp;
222 {
223 fmterr = 0; frameno = 0;
224 if (headlen) { /* free old header */
225 free(headlines);
226 headlen = 0;
227 }
228 if (getheader(fp, addhline, NULL) < 0)
229 return(0);
230 if (fmterr)
231 return(-1);
232 return(1);
233 }
