root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.21
Committed: Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 2.20: +1 -4 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.21 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.20 2018/08/02 18:33:47 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * program to convert from RADIANCE RLE to flat format
6     */
7
8 greg 2.4 #include <math.h>
9 schorsch 2.12
10     #include "platform.h"
11 greg 2.19 #include "rtio.h"
12 greg 2.18 #include "paths.h"
13 greg 2.4 #include "color.h"
14     #include "resolu.h"
15
16 greg 2.19 #define dumpheader(fp) putbinary(headlines, 1, headlen, fp)
17 gregl 2.8
18 greg 1.1 int bradj = 0; /* brightness adjustment */
19     int doflat = 1; /* produce flat file */
20 gregl 2.8 int force = 0; /* force file overwrite? */
21     int findframe = 0; /* find a specific frame? */
22     int frameno = 0; /* current frame number */
23     int fmterr = 0; /* got input format error */
24     char *headlines; /* current header info. */
25     int headlen; /* current header length */
26
27 greg 1.1 char *progname;
28
29 schorsch 2.16 static gethfunc addhline;
30 schorsch 2.17 static int transfer(char *ospec);
31     static int loadheader(FILE *fp);
32 schorsch 2.16
33 greg 1.1
34 schorsch 2.17 int
35     main(int argc, char *argv[])
36 greg 1.1 {
37 gregl 2.8 char *ospec;
38 greg 1.1 int i;
39 gregl 2.7
40 greg 1.1 progname = argv[0];
41
42     for (i = 1; i < argc; i++)
43     if (argv[i][0] == '-')
44     switch (argv[i][1]) {
45     case 'r':
46     doflat = !doflat;
47     break;
48     case 'e':
49     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
50     goto userr;
51     bradj = atoi(argv[++i]);
52     break;
53 gregl 2.8 case 'n':
54     findframe = atoi(argv[++i]);
55     break;
56     case 'f':
57     force++;
58     break;
59     case '\0':
60     goto gotfile;
61 greg 1.1 default:
62     goto userr;
63     }
64     else
65     break;
66 gregl 2.8 gotfile:
67 greg 1.1 if (i < argc-2)
68     goto userr;
69 gregl 2.8 if (i <= argc-1 && strcmp(argv[i], "-") &&
70     freopen(argv[i], "r", stdin) == NULL) {
71 greg 1.1 fprintf(stderr, "%s: can't open input \"%s\"\n",
72     progname, argv[i]);
73     exit(1);
74     }
75 schorsch 2.12 SET_FILE_BINARY(stdin);
76 gregl 2.8 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
77     while (transfer(ospec))
78     ;
79 greg 1.1 exit(0);
80     userr:
81 gregl 2.8 fprintf(stderr,
82     "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
83 greg 1.1 progname);
84     exit(1);
85     }
86
87
88 schorsch 2.17 static int
89     transfer( /* transfer a Radiance picture */
90     char *ospec
91     )
92 greg 1.1 {
93 schorsch 2.15 char oname[PATH_MAX];
94 gregl 2.8 FILE *fp;
95 greg 1.2 int order;
96 greg 2.3 int xmax, ymax;
97 greg 1.1 COLR *scanin;
98     int y;
99 gregl 2.8 /* get header info. */
100     if (!(y = loadheader(stdin)))
101     return(0);
102     if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
103     fprintf(stderr, "%s: bad input format\n", progname);
104     exit(1);
105     }
106     /* did we pass the target frame? */
107     if (findframe && findframe < frameno)
108     return(0);
109     /* allocate scanline */
110     scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
111     if (scanin == NULL) {
112     perror(progname);
113     exit(1);
114     }
115     /* skip frame? */
116     if (findframe > frameno) {
117     for (y = ymax; y--; )
118     if (freadcolrs(scanin, xmax, stdin) < 0) {
119     fprintf(stderr,
120     "%s: error reading input picture\n",
121     progname);
122     exit(1);
123     }
124     return(1);
125     }
126     /* open output file/command */
127     if (ospec == NULL) {
128     strcpy(oname, "<stdout>");
129     fp = stdout;
130     } else {
131     sprintf(oname, ospec, frameno);
132     if (oname[0] == '!') {
133     if ((fp = popen(oname+1, "w")) == NULL) {
134     fprintf(stderr, "%s: cannot start \"%s\"\n",
135     progname, oname);
136     exit(1);
137     }
138     } else {
139     if (!force && access(oname, 0) >= 0) {
140     fprintf(stderr,
141     "%s: output file \"%s\" exists\n",
142     progname, oname);
143     exit(1);
144     }
145     if ((fp = fopen(oname, "w")) == NULL) {
146     fprintf(stderr, "%s: ", progname);
147     perror(oname);
148     exit(1);
149     }
150     }
151     }
152 schorsch 2.12 SET_FILE_BINARY(fp);
153 gregl 2.8 dumpheader(fp); /* put out header */
154     fputs(progname, fp);
155 greg 1.1 if (bradj)
156 gregl 2.8 fprintf(fp, " -e %+d", bradj);
157 gregl 2.7 if (!doflat)
158 gregl 2.8 fputs(" -r", fp);
159     fputc('\n', fp);
160 greg 2.2 if (bradj)
161 gregl 2.8 fputexpos(pow(2.0, (double)bradj), fp);
162     fputc('\n', fp);
163     fputresolu(order, xmax, ymax, fp);
164     /* transfer picture */
165 gregl 2.7 for (y = ymax; y--; ) {
166 gregl 2.8 if (freadcolrs(scanin, xmax, stdin) < 0) {
167     fprintf(stderr, "%s: error reading input picture\n",
168     progname);
169     exit(1);
170     }
171 greg 1.1 if (bradj)
172     shiftcolrs(scanin, xmax, bradj);
173     if (doflat)
174 greg 2.19 putbinary((char *)scanin, sizeof(COLR), xmax, fp);
175 greg 1.1 else
176 gregl 2.8 fwritecolrs(scanin, xmax, fp);
177     if (ferror(fp)) {
178     fprintf(stderr, "%s: error writing output to \"%s\"\n",
179     progname, oname);
180     exit(1);
181     }
182 greg 1.1 }
183 gregl 2.8 /* clean up */
184     if (oname[0] == '!')
185     pclose(fp);
186     else if (ospec != NULL)
187     fclose(fp);
188     return(1);
189     }
190
191
192 schorsch 2.16 static int
193     addhline( /* add a line to our info. header */
194     char *s,
195     void *p
196     )
197 gregl 2.8 {
198 greg 2.20 char fmt[MAXFMTLEN];
199 gregl 2.8 int n;
200
201     if (formatval(fmt, s))
202     fmterr += !globmatch(PICFMT, fmt);
203     else if (!strncmp(s, "FRAME=", 6))
204     frameno = atoi(s+6);
205     n = strlen(s);
206     if (headlen)
207 greg 2.11 headlines = (char *)realloc((void *)headlines, headlen+n+1);
208 gregl 2.8 else
209     headlines = (char *)malloc(n+1);
210     if (headlines == NULL) {
211     perror(progname);
212     exit(1);
213     }
214     strcpy(headlines+headlen, s);
215     headlen += n;
216 gwlarson 2.9 return(0);
217 gregl 2.8 }
218
219
220 schorsch 2.17 static int
221     loadheader( /* load an info. header into memory */
222     FILE *fp
223     )
224 gregl 2.8 {
225     fmterr = 0; frameno = 0;
226     if (headlen) { /* free old header */
227     free(headlines);
228     headlen = 0;
229     }
230     if (getheader(fp, addhline, NULL) < 0)
231     return(0);
232     if (fmterr)
233     return(-1);
234     return(1);
235 greg 1.1 }
