Fixed size of command line buffers, and allow spaces in input file paths.
Various compatibility fixes.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
made program read multiple frames in a single file
made program work with XYZE images as well as RGBE
minor compiler warning fixes
fixed incorrect error message
Changes for PC port
fixed ordering of output header
