root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.11
Committed: Wed Apr 23 00:52:34 2003 UTC (22 years, 1 month ago) by greg
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include "color.h"
12 #include "resolu.h"
13
14 #ifdef MSDOS
15 #include <fcntl.h>
16 #endif
17
18 extern int addhline();
19
20 #define dumpheader(fp) fwrite(headlines, 1, headlen, fp)
21
22 int bradj = 0; /* brightness adjustment */
23
24 int doflat = 1; /* produce flat file */
25
26 int force = 0; /* force file overwrite? */
27
28 int findframe = 0; /* find a specific frame? */
29
30 int frameno = 0; /* current frame number */
31 int fmterr = 0; /* got input format error */
32 char *headlines; /* current header info. */
33 int headlen; /* current header length */
34
35 char *progname;
36
37
38 main(argc, argv)
39 int argc;
40 char *argv[];
41 {
42 char *ospec;
43 int i;
44
45 progname = argv[0];
46
47 for (i = 1; i < argc; i++)
48 if (argv[i][0] == '-')
49 switch (argv[i][1]) {
50 case 'r':
51 doflat = !doflat;
52 break;
53 case 'e':
54 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
55 goto userr;
56 bradj = atoi(argv[++i]);
57 break;
58 case 'n':
59 findframe = atoi(argv[++i]);
60 break;
61 case 'f':
62 force++;
63 break;
64 case '\0':
65 goto gotfile;
66 default:
67 goto userr;
68 }
69 else
70 break;
71 gotfile:
72 if (i < argc-2)
73 goto userr;
74 if (i <= argc-1 && strcmp(argv[i], "-") &&
75 freopen(argv[i], "r", stdin) == NULL) {
76 fprintf(stderr, "%s: can't open input \"%s\"\n",
77 progname, argv[i]);
78 exit(1);
79 }
80 #ifdef MSDOS
81 setmode(fileno(stdin), O_BINARY);
82 #endif
83 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
84 while (transfer(ospec))
85 ;
86 exit(0);
87 userr:
88 fprintf(stderr,
89 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
90 progname);
91 exit(1);
92 }
93
94
95 transfer(ospec) /* transfer a Radiance picture */
96 char *ospec;
97 {
98 char oname[128];
99 FILE *fp;
100 int order;
101 int xmax, ymax;
102 COLR *scanin;
103 int y;
104 /* get header info. */
105 if (!(y = loadheader(stdin)))
106 return(0);
107 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
108 fprintf(stderr, "%s: bad input format\n", progname);
109 exit(1);
110 }
111 /* did we pass the target frame? */
112 if (findframe && findframe < frameno)
113 return(0);
114 /* allocate scanline */
115 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
116 if (scanin == NULL) {
117 perror(progname);
118 exit(1);
119 }
120 /* skip frame? */
121 if (findframe > frameno) {
122 for (y = ymax; y--; )
123 if (freadcolrs(scanin, xmax, stdin) < 0) {
124 fprintf(stderr,
125 "%s: error reading input picture\n",
126 progname);
127 exit(1);
128 }
129 return(1);
130 }
131 /* open output file/command */
132 if (ospec == NULL) {
133 strcpy(oname, "<stdout>");
134 fp = stdout;
135 } else {
136 sprintf(oname, ospec, frameno);
137 if (oname[0] == '!') {
138 if ((fp = popen(oname+1, "w")) == NULL) {
139 fprintf(stderr, "%s: cannot start \"%s\"\n",
140 progname, oname);
141 exit(1);
142 }
143 } else {
144 if (!force && access(oname, 0) >= 0) {
145 fprintf(stderr,
146 "%s: output file \"%s\" exists\n",
147 progname, oname);
148 exit(1);
149 }
150 if ((fp = fopen(oname, "w")) == NULL) {
151 fprintf(stderr, "%s: ", progname);
152 perror(oname);
153 exit(1);
154 }
155 }
156 }
157 #ifdef MSDOS
158 setmode(fileno(fp), O_BINARY);
159 #endif
160 dumpheader(fp); /* put out header */
161 fputs(progname, fp);
162 if (bradj)
163 fprintf(fp, " -e %+d", bradj);
164 if (!doflat)
165 fputs(" -r", fp);
166 fputc('\n', fp);
167 if (bradj)
168 fputexpos(pow(2.0, (double)bradj), fp);
169 fputc('\n', fp);
170 fputresolu(order, xmax, ymax, fp);
171 /* transfer picture */
172 for (y = ymax; y--; ) {
173 if (freadcolrs(scanin, xmax, stdin) < 0) {
174 fprintf(stderr, "%s: error reading input picture\n",
175 progname);
176 exit(1);
177 }
178 if (bradj)
179 shiftcolrs(scanin, xmax, bradj);
180 if (doflat)
181 fwrite((char *)scanin, sizeof(COLR), xmax, fp);
182 else
183 fwritecolrs(scanin, xmax, fp);
184 if (ferror(fp)) {
185 fprintf(stderr, "%s: error writing output to \"%s\"\n",
186 progname, oname);
187 exit(1);
188 }
189 }
190 /* clean up */
191 if (oname[0] == '!')
192 pclose(fp);
193 else if (ospec != NULL)
194 fclose(fp);
195 return(1);
196 }
197
198
199 int
200 addhline(s) /* add a line to our info. header */
201 char *s;
202 {
203 char fmt[32];
204 int n;
205
206 if (formatval(fmt, s))
207 fmterr += !globmatch(PICFMT, fmt);
208 else if (!strncmp(s, "FRAME=", 6))
209 frameno = atoi(s+6);
210 n = strlen(s);
211 if (headlen)
212 headlines = (char *)realloc((void *)headlines, headlen+n+1);
213 else
214 headlines = (char *)malloc(n+1);
215 if (headlines == NULL) {
216 perror(progname);
217 exit(1);
218 }
219 strcpy(headlines+headlen, s);
220 headlen += n;
221 return(0);
222 }
223
224
225 loadheader(fp) /* load an info. header into memory */
226 FILE *fp;
227 {
228 fmterr = 0; frameno = 0;
229 if (headlen) { /* free old header */
230 free(headlines);
231 headlen = 0;
232 }
233 if (getheader(fp, addhline, NULL) < 0)
234 return(0);
235 if (fmterr)
236 return(-1);
237 return(1);
238 }
