root/radiance/ray/src/px/ra_rgbe.c
Diff to previous 2.16
Revision 2.16 - (view) (download) (annotate) - [selected]
Fri Jan 2 12:47:01 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 2.15: +8 -6 lines
Diff to previous 2.15
Mon Nov 10 12:28:56 2003 UTC (20 years, 5 months ago) by schorsch
Diff to previous 2.14 , to selected 2.16
Fixed size of command line buffers, and allow spaces in input file paths.
Mon Oct 27 10:24:51 2003 UTC (20 years, 6 months ago) by schorsch
Diff to previous 2.13 , to selected 2.16
Various compatibility fixes.
Thu Jul 3 22:41:44 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.12 , to selected 2.16
Changes since 2.11: +5 -11 lines
Diff to previous 2.11 , to selected 2.16
Diff to previous 2.10 , to selected 2.16
Changes since 2.9: +2 -5 lines
Diff to previous 2.9 , to selected 2.16
Tue Oct 27 09:08:27 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 2.8 , to selected 2.16
Fri Jan 23 11:38:39 1998 UTC (26 years, 3 months ago) by gregl
Changes since 2.7: +157 -51 lines
Diff to previous 2.7 , to selected 2.16
made program read multiple frames in a single file
Fri Jan 23 09:28:29 1998 UTC (26 years, 3 months ago) by gregl
Changes since 2.6: +16 -16 lines
Diff to previous 2.6 , to selected 2.16
made program work with XYZE images as well as RGBE
Thu Nov 18 09:55:20 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.5: +1 -2 lines
Diff to previous 2.5 , to selected 2.16
minor compiler warning fixes
Tue Apr 27 12:37:23 1993 UTC (31 years ago) by greg
Diff to previous 2.4 , to selected 2.16
fixed incorrect error message
Fri Oct 2 16:26:39 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.3: +4 -4 lines
Diff to previous 2.3 , to selected 2.16
Mon Sep 21 12:15:13 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +12 -2 lines
Diff to previous 2.2 , to selected 2.16
Changes for PC port
Fri Jan 3 22:58:08 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.1: +11 -6 lines
Diff to previous 2.1 , to selected 2.16
fixed ordering of output header
Tue Nov 12 16:05:45 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.2 , to selected 2.16
Mon Nov 11 14:01:34 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 2.16
Fri Aug 23 17:37:14 1991 UTC (32 years, 8 months ago) by greg
Diff to selected 2.16
