root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.19
Committed: Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.18: +4 -3 lines
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.18 2016/02/02 18:02:32 greg Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "rtio.h"
15 #include "paths.h"
16 #include "color.h"
17 #include "resolu.h"
18
19 #define dumpheader(fp) putbinary(headlines, 1, headlen, fp)
20
21 int bradj = 0; /* brightness adjustment */
22 int doflat = 1; /* produce flat file */
23 int force = 0; /* force file overwrite? */
24 int findframe = 0; /* find a specific frame? */
25 int frameno = 0; /* current frame number */
26 int fmterr = 0; /* got input format error */
27 char *headlines; /* current header info. */
28 int headlen; /* current header length */
29
30 char *progname;
31
32 static gethfunc addhline;
33 static int transfer(char *ospec);
34 static int loadheader(FILE *fp);
35
36
37 int
38 main(int argc, char *argv[])
39 {
40 char *ospec;
41 int i;
42
43 progname = argv[0];
44
45 for (i = 1; i < argc; i++)
46 if (argv[i][0] == '-')
47 switch (argv[i][1]) {
48 case 'r':
49 doflat = !doflat;
50 break;
51 case 'e':
52 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
53 goto userr;
54 bradj = atoi(argv[++i]);
55 break;
56 case 'n':
57 findframe = atoi(argv[++i]);
58 break;
59 case 'f':
60 force++;
61 break;
62 case '\0':
63 goto gotfile;
64 default:
65 goto userr;
66 }
67 else
68 break;
69 gotfile:
70 if (i < argc-2)
71 goto userr;
72 if (i <= argc-1 && strcmp(argv[i], "-") &&
73 freopen(argv[i], "r", stdin) == NULL) {
74 fprintf(stderr, "%s: can't open input \"%s\"\n",
75 progname, argv[i]);
76 exit(1);
77 }
78 SET_FILE_BINARY(stdin);
79 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
80 while (transfer(ospec))
81 ;
82 exit(0);
83 userr:
84 fprintf(stderr,
85 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
86 progname);
87 exit(1);
88 }
89
90
91 static int
92 transfer( /* transfer a Radiance picture */
93 char *ospec
94 )
95 {
96 char oname[PATH_MAX];
97 FILE *fp;
98 int order;
99 int xmax, ymax;
100 COLR *scanin;
101 int y;
102 /* get header info. */
103 if (!(y = loadheader(stdin)))
104 return(0);
105 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
106 fprintf(stderr, "%s: bad input format\n", progname);
107 exit(1);
108 }
109 /* did we pass the target frame? */
110 if (findframe && findframe < frameno)
111 return(0);
112 /* allocate scanline */
113 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
114 if (scanin == NULL) {
115 perror(progname);
116 exit(1);
117 }
118 /* skip frame? */
119 if (findframe > frameno) {
120 for (y = ymax; y--; )
121 if (freadcolrs(scanin, xmax, stdin) < 0) {
122 fprintf(stderr,
123 "%s: error reading input picture\n",
124 progname);
125 exit(1);
126 }
127 return(1);
128 }
129 /* open output file/command */
130 if (ospec == NULL) {
131 strcpy(oname, "<stdout>");
132 fp = stdout;
133 } else {
134 sprintf(oname, ospec, frameno);
135 if (oname[0] == '!') {
136 if ((fp = popen(oname+1, "w")) == NULL) {
137 fprintf(stderr, "%s: cannot start \"%s\"\n",
138 progname, oname);
139 exit(1);
140 }
141 } else {
142 if (!force && access(oname, 0) >= 0) {
143 fprintf(stderr,
144 "%s: output file \"%s\" exists\n",
145 progname, oname);
146 exit(1);
147 }
148 if ((fp = fopen(oname, "w")) == NULL) {
149 fprintf(stderr, "%s: ", progname);
150 perror(oname);
151 exit(1);
152 }
153 }
154 }
155 SET_FILE_BINARY(fp);
156 dumpheader(fp); /* put out header */
157 fputs(progname, fp);
158 if (bradj)
159 fprintf(fp, " -e %+d", bradj);
160 if (!doflat)
161 fputs(" -r", fp);
162 fputc('\n', fp);
163 if (bradj)
164 fputexpos(pow(2.0, (double)bradj), fp);
165 fputc('\n', fp);
166 fputresolu(order, xmax, ymax, fp);
167 /* transfer picture */
168 for (y = ymax; y--; ) {
169 if (freadcolrs(scanin, xmax, stdin) < 0) {
170 fprintf(stderr, "%s: error reading input picture\n",
171 progname);
172 exit(1);
173 }
174 if (bradj)
175 shiftcolrs(scanin, xmax, bradj);
176 if (doflat)
177 putbinary((char *)scanin, sizeof(COLR), xmax, fp);
178 else
179 fwritecolrs(scanin, xmax, fp);
180 if (ferror(fp)) {
181 fprintf(stderr, "%s: error writing output to \"%s\"\n",
182 progname, oname);
183 exit(1);
184 }
185 }
186 /* clean up */
187 if (oname[0] == '!')
188 pclose(fp);
189 else if (ospec != NULL)
190 fclose(fp);
191 return(1);
192 }
193
194
195 static int
196 addhline( /* add a line to our info. header */
197 char *s,
198 void *p
199 )
200 {
201 char fmt[32];
202 int n;
203
204 if (formatval(fmt, s))
205 fmterr += !globmatch(PICFMT, fmt);
206 else if (!strncmp(s, "FRAME=", 6))
207 frameno = atoi(s+6);
208 n = strlen(s);
209 if (headlen)
210 headlines = (char *)realloc((void *)headlines, headlen+n+1);
211 else
212 headlines = (char *)malloc(n+1);
213 if (headlines == NULL) {
214 perror(progname);
215 exit(1);
216 }
217 strcpy(headlines+headlen, s);
218 headlen += n;
219 return(0);
220 }
221
222
223 static int
224 loadheader( /* load an info. header into memory */
225 FILE *fp
226 )
227 {
228 fmterr = 0; frameno = 0;
229 if (headlen) { /* free old header */
230 free(headlines);
231 headlen = 0;
232 }
233 if (getheader(fp, addhline, NULL) < 0)
234 return(0);
235 if (fmterr)
236 return(-1);
237 return(1);
238 }
