root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.14
Committed: Mon Oct 27 10:24:51 2003 UTC (21 years, 9 months ago) by schorsch
Various compatibility fixes.
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.13 2003/07/03 22:41:44 schorsch Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "rtprocess.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 extern int addhline();
19
20 #define dumpheader(fp) fwrite(headlines, 1, headlen, fp)
21
22 int bradj = 0; /* brightness adjustment */
23
24 int doflat = 1; /* produce flat file */
25
26 int force = 0; /* force file overwrite? */
27
28 int findframe = 0; /* find a specific frame? */
29
30 int frameno = 0; /* current frame number */
31 int fmterr = 0; /* got input format error */
32 char *headlines; /* current header info. */
33 int headlen; /* current header length */
34
35 char *progname;
36
37
38 main(argc, argv)
39 int argc;
40 char *argv[];
41 {
42 char *ospec;
43 int i;
44
45 progname = argv[0];
46
47 for (i = 1; i < argc; i++)
48 if (argv[i][0] == '-')
49 switch (argv[i][1]) {
50 case 'r':
51 doflat = !doflat;
52 break;
53 case 'e':
54 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
55 goto userr;
56 bradj = atoi(argv[++i]);
57 break;
58 case 'n':
59 findframe = atoi(argv[++i]);
60 break;
61 case 'f':
62 force++;
63 break;
64 case '\0':
65 goto gotfile;
66 default:
67 goto userr;
68 }
69 else
70 break;
71 gotfile:
72 if (i < argc-2)
73 goto userr;
74 if (i <= argc-1 && strcmp(argv[i], "-") &&
75 freopen(argv[i], "r", stdin) == NULL) {
76 fprintf(stderr, "%s: can't open input \"%s\"\n",
77 progname, argv[i]);
78 exit(1);
79 }
80 SET_FILE_BINARY(stdin);
81 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
82 while (transfer(ospec))
83 ;
84 exit(0);
85 userr:
86 fprintf(stderr,
87 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
88 progname);
89 exit(1);
90 }
91
92
93 transfer(ospec) /* transfer a Radiance picture */
94 char *ospec;
95 {
96 char oname[128];
97 FILE *fp;
98 int order;
99 int xmax, ymax;
100 COLR *scanin;
101 int y;
102 /* get header info. */
103 if (!(y = loadheader(stdin)))
104 return(0);
105 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
106 fprintf(stderr, "%s: bad input format\n", progname);
107 exit(1);
108 }
109 /* did we pass the target frame? */
110 if (findframe && findframe < frameno)
111 return(0);
112 /* allocate scanline */
113 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
114 if (scanin == NULL) {
115 perror(progname);
116 exit(1);
117 }
118 /* skip frame? */
119 if (findframe > frameno) {
120 for (y = ymax; y--; )
121 if (freadcolrs(scanin, xmax, stdin) < 0) {
122 fprintf(stderr,
123 "%s: error reading input picture\n",
124 progname);
125 exit(1);
126 }
127 return(1);
128 }
129 /* open output file/command */
130 if (ospec == NULL) {
131 strcpy(oname, "<stdout>");
132 fp = stdout;
133 } else {
134 sprintf(oname, ospec, frameno);
135 if (oname[0] == '!') {
136 if ((fp = popen(oname+1, "w")) == NULL) {
137 fprintf(stderr, "%s: cannot start \"%s\"\n",
138 progname, oname);
139 exit(1);
140 }
141 } else {
142 if (!force && access(oname, 0) >= 0) {
143 fprintf(stderr,
144 "%s: output file \"%s\" exists\n",
145 progname, oname);
146 exit(1);
147 }
148 if ((fp = fopen(oname, "w")) == NULL) {
149 fprintf(stderr, "%s: ", progname);
150 perror(oname);
151 exit(1);
152 }
153 }
154 }
155 SET_FILE_BINARY(fp);
156 dumpheader(fp); /* put out header */
157 fputs(progname, fp);
158 if (bradj)
159 fprintf(fp, " -e %+d", bradj);
160 if (!doflat)
161 fputs(" -r", fp);
162 fputc('\n', fp);
163 if (bradj)
164 fputexpos(pow(2.0, (double)bradj), fp);
165 fputc('\n', fp);
166 fputresolu(order, xmax, ymax, fp);
167 /* transfer picture */
168 for (y = ymax; y--; ) {
169 if (freadcolrs(scanin, xmax, stdin) < 0) {
170 fprintf(stderr, "%s: error reading input picture\n",
171 progname);
172 exit(1);
173 }
174 if (bradj)
175 shiftcolrs(scanin, xmax, bradj);
176 if (doflat)
177 fwrite((char *)scanin, sizeof(COLR), xmax, fp);
178 else
179 fwritecolrs(scanin, xmax, fp);
180 if (ferror(fp)) {
181 fprintf(stderr, "%s: error writing output to \"%s\"\n",
182 progname, oname);
183 exit(1);
184 }
185 }
186 /* clean up */
187 if (oname[0] == '!')
188 pclose(fp);
189 else if (ospec != NULL)
190 fclose(fp);
191 return(1);
192 }
193
194
195 int
196 addhline(s) /* add a line to our info. header */
197 char *s;
198 {
199 char fmt[32];
200 int n;
201
202 if (formatval(fmt, s))
203 fmterr += !globmatch(PICFMT, fmt);
204 else if (!strncmp(s, "FRAME=", 6))
205 frameno = atoi(s+6);
206 n = strlen(s);
207 if (headlen)
208 headlines = (char *)realloc((void *)headlines, headlen+n+1);
209 else
210 headlines = (char *)malloc(n+1);
211 if (headlines == NULL) {
212 perror(progname);
213 exit(1);
214 }
215 strcpy(headlines+headlen, s);
216 headlen += n;
217 return(0);
218 }
219
220
221 loadheader(fp) /* load an info. header into memory */
222 FILE *fp;
223 {
224 fmterr = 0; frameno = 0;
225 if (headlen) { /* free old header */
226 free(headlines);
227 headlen = 0;
228 }
229 if (getheader(fp, addhline, NULL) < 0)
230 return(0);
231 if (fmterr)
232 return(-1);
233 return(1);
234 }
