root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.12
Committed: Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.11: +5 -11 lines
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.11 2003/04/23 00:52:34 greg Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11
12 #include "platform.h"
13 #include "color.h"
14 #include "resolu.h"
15
16 extern int addhline();
17
18 #define dumpheader(fp) fwrite(headlines, 1, headlen, fp)
19
20 int bradj = 0; /* brightness adjustment */
21
22 int doflat = 1; /* produce flat file */
23
24 int force = 0; /* force file overwrite? */
25
26 int findframe = 0; /* find a specific frame? */
27
28 int frameno = 0; /* current frame number */
29 int fmterr = 0; /* got input format error */
30 char *headlines; /* current header info. */
31 int headlen; /* current header length */
32
33 char *progname;
34
35
36 main(argc, argv)
37 int argc;
38 char *argv[];
39 {
40 char *ospec;
41 int i;
42
43 progname = argv[0];
44
45 for (i = 1; i < argc; i++)
46 if (argv[i][0] == '-')
47 switch (argv[i][1]) {
48 case 'r':
49 doflat = !doflat;
50 break;
51 case 'e':
52 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
53 goto userr;
54 bradj = atoi(argv[++i]);
55 break;
56 case 'n':
57 findframe = atoi(argv[++i]);
58 break;
59 case 'f':
60 force++;
61 break;
62 case '\0':
63 goto gotfile;
64 default:
65 goto userr;
66 }
67 else
68 break;
69 gotfile:
70 if (i < argc-2)
71 goto userr;
72 if (i <= argc-1 && strcmp(argv[i], "-") &&
73 freopen(argv[i], "r", stdin) == NULL) {
74 fprintf(stderr, "%s: can't open input \"%s\"\n",
75 progname, argv[i]);
76 exit(1);
77 }
78 SET_FILE_BINARY(stdin);
79 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
80 while (transfer(ospec))
81 ;
82 exit(0);
83 userr:
84 fprintf(stderr,
85 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
86 progname);
87 exit(1);
88 }
89
90
91 transfer(ospec) /* transfer a Radiance picture */
92 char *ospec;
93 {
94 char oname[128];
95 FILE *fp;
96 int order;
97 int xmax, ymax;
98 COLR *scanin;
99 int y;
100 /* get header info. */
101 if (!(y = loadheader(stdin)))
102 return(0);
103 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
104 fprintf(stderr, "%s: bad input format\n", progname);
105 exit(1);
106 }
107 /* did we pass the target frame? */
108 if (findframe && findframe < frameno)
109 return(0);
110 /* allocate scanline */
111 scanin = (COLR *)tempbuffer(xmax*sizeof(COLR));
112 if (scanin == NULL) {
113 perror(progname);
114 exit(1);
115 }
116 /* skip frame? */
117 if (findframe > frameno) {
118 for (y = ymax; y--; )
119 if (freadcolrs(scanin, xmax, stdin) < 0) {
120 fprintf(stderr,
121 "%s: error reading input picture\n",
122 progname);
123 exit(1);
124 }
125 return(1);
126 }
127 /* open output file/command */
128 if (ospec == NULL) {
129 strcpy(oname, "<stdout>");
130 fp = stdout;
131 } else {
132 sprintf(oname, ospec, frameno);
133 if (oname[0] == '!') {
134 if ((fp = popen(oname+1, "w")) == NULL) {
135 fprintf(stderr, "%s: cannot start \"%s\"\n",
136 progname, oname);
137 exit(1);
138 }
139 } else {
140 if (!force && access(oname, 0) >= 0) {
141 fprintf(stderr,
142 "%s: output file \"%s\" exists\n",
143 progname, oname);
144 exit(1);
145 }
146 if ((fp = fopen(oname, "w")) == NULL) {
147 fprintf(stderr, "%s: ", progname);
148 perror(oname);
149 exit(1);
150 }
151 }
152 }
153 SET_FILE_BINARY(fp);
154 dumpheader(fp); /* put out header */
155 fputs(progname, fp);
156 if (bradj)
157 fprintf(fp, " -e %+d", bradj);
158 if (!doflat)
159 fputs(" -r", fp);
160 fputc('\n', fp);
161 if (bradj)
162 fputexpos(pow(2.0, (double)bradj), fp);
163 fputc('\n', fp);
164 fputresolu(order, xmax, ymax, fp);
165 /* transfer picture */
166 for (y = ymax; y--; ) {
167 if (freadcolrs(scanin, xmax, stdin) < 0) {
168 fprintf(stderr, "%s: error reading input picture\n",
169 progname);
170 exit(1);
171 }
172 if (bradj)
173 shiftcolrs(scanin, xmax, bradj);
174 if (doflat)
175 fwrite((char *)scanin, sizeof(COLR), xmax, fp);
176 else
177 fwritecolrs(scanin, xmax, fp);
178 if (ferror(fp)) {
179 fprintf(stderr, "%s: error writing output to \"%s\"\n",
180 progname, oname);
181 exit(1);
182 }
183 }
184 /* clean up */
185 if (oname[0] == '!')
186 pclose(fp);
187 else if (ospec != NULL)
188 fclose(fp);
189 return(1);
190 }
191
192
193 int
194 addhline(s) /* add a line to our info. header */
195 char *s;
196 {
197 char fmt[32];
198 int n;
199
200 if (formatval(fmt, s))
201 fmterr += !globmatch(PICFMT, fmt);
202 else if (!strncmp(s, "FRAME=", 6))
203 frameno = atoi(s+6);
204 n = strlen(s);
205 if (headlen)
206 headlines = (char *)realloc((void *)headlines, headlen+n+1);
207 else
208 headlines = (char *)malloc(n+1);
209 if (headlines == NULL) {
210 perror(progname);
211 exit(1);
212 }
213 strcpy(headlines+headlen, s);
214 headlen += n;
215 return(0);
216 }
217
218
219 loadheader(fp) /* load an info. header into memory */
220 FILE *fp;
221 {
222 fmterr = 0; frameno = 0;
223 if (headlen) { /* free old header */
224 free(headlines);
225 headlen = 0;
226 }
227 if (getheader(fp, addhline, NULL) < 0)
228 return(0);
229 if (fmterr)
230 return(-1);
231 return(1);
232 }
