root/radiance/ray/src/px/ra_rgbe.c
Revision: 2.26
Committed: Sat Jun 7 05:09:46 2025 UTC (6 weeks, 4 days ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.25: +1 -2 lines
2 static const char RCSid[] = "$Id: ra_rgbe.c,v 2.25 2025/04/22 14:51:29 greg Exp $";
5 * program to convert from RADIANCE RLE to flat format
6 */
7
8 #include <math.h>
9
10 #include "platform.h"
11 #include "rtio.h"
12 #include "color.h"
13 #include "resolu.h"
14
15 #define dumpheader(fp) putbinary(headlines, 1, headlen, fp)
16
17 int bradj = 0; /* brightness adjustment */
18 int doflat = 1; /* produce flat file */
19 int force = 0; /* force file overwrite? */
20 int findframe = 0; /* find a specific frame? */
21 int frameno = 0; /* current frame number */
22 int fmterr = 0; /* got input format error */
23 char *headlines = NULL; /* current header info. */
24 int headlen1 = 0; /* length of initial frame header */
25 int headlen = 0; /* current header length */
26 char fmt[MAXFMTLEN]; /* input format */
27
28 char *progname;
29
30 static gethfunc addhline;
31 static int transfer(char *ospec);
32 static int loadheader(FILE *fp);
33
34
35 int
36 main(int argc, char *argv[])
37 {
38 char *ospec;
39 int i;
40
41 progname = argv[0];
42
43 for (i = 1; i < argc; i++)
44 if (argv[i][0] == '-')
45 switch (argv[i][1]) {
46 case 'r':
47 doflat = !doflat;
48 break;
49 case 'e':
50 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
51 goto userr;
52 bradj = atoi(argv[++i]);
53 break;
54 case 'n':
55 findframe = atoi(argv[++i]);
56 break;
57 case 'f':
58 force++;
59 break;
60 case '\0':
61 goto gotfile;
62 default:
63 goto userr;
64 }
65 else
66 break;
67 gotfile:
68 if (i < argc-2)
69 goto userr;
70 if (i <= argc-1 && strcmp(argv[i], "-") &&
71 freopen(argv[i], "r", stdin) == NULL) {
72 fprintf(stderr, "%s: can't open input \"%s\"\n",
73 progname, argv[i]);
74 exit(1);
75 }
76 SET_FILE_BINARY(stdin);
77 ospec = i==argc-2 ? argv[i+1] : (char *)NULL;
78 while (transfer(ospec))
79 ;
80 exit(0);
81 userr:
82 fprintf(stderr,
83 "Usage: %s [-r][-e +/-stops][-f][-n frame] [input [outspec]]\n",
84 progname);
85 exit(1);
86 }
87
88
89 static int
90 transfer( /* transfer a Radiance picture */
91 char *ospec
92 )
93 {
94 char oname[PATH_MAX];
95 FILE *fp;
96 int order;
97 int xmax, ymax;
98 COLR *scanin;
99 int y;
100 /* get header info. */
101 if (!(y = loadheader(stdin)))
102 return(0);
103 if (y < 0 || (order = fgetresolu(&xmax, &ymax, stdin)) < 0) {
104 fprintf(stderr, "%s: bad input format\n", progname);
105 exit(1);
106 }
107 /* did we pass the target frame? */
108 if (findframe && findframe < frameno)
109 return(0);
110 /* allocate scanline */
111 scanin = (COLR *)malloc(xmax*sizeof(COLR));
112 if (scanin == NULL) {
113 perror(progname);
114 exit(1);
115 }
116 /* skip frame? */
117 if (findframe > frameno) {
118 if (NCSAMP > 3) {
119 if (fseek(stdin, ymax*xmax*LSCOLR, SEEK_CUR) < 0) {
120 perror(progname);
121 exit(1);
122 }
123 } else
124 for (y = ymax; y--; )
125 if (freadcolrs(scanin, xmax, stdin) < 0) {
126 fprintf(stderr,
127 "%s: error reading input picture\n",
128 progname);
129 exit(1);
130 }
131 free(scanin);
132 return(1);
133 }
134 /* open output file/command */
135 if (ospec == NULL) {
136 strcpy(oname, "<stdout>");
137 fp = stdout;
138 } else {
139 sprintf(oname, ospec, frameno);
140 if (oname[0] == '!') {
141 if ((fp = popen(oname+1, "w")) == NULL) {
142 fprintf(stderr, "%s: cannot start \"%s\"\n",
143 progname, oname);
144 exit(1);
145 }
146 } else {
147 if (!force && access(oname, 0) >= 0) {
148 fprintf(stderr,
149 "%s: output file \"%s\" exists\n",
150 progname, oname);
151 exit(1);
152 }
153 if ((fp = fopen(oname, "w")) == NULL) {
154 fprintf(stderr, "%s: ", progname);
155 perror(oname);
156 exit(1);
157 }
158 }
159 }
160 SET_FILE_BINARY(fp);
161 newheader("RADIANCE", fp); /* put out header */
162 dumpheader(fp);
163 fputs(progname, fp);
164 if (bradj)
165 fprintf(fp, " -e %+d", bradj);
166 if (!doflat)
167 fputs(" -r", fp);
168 fputc('\n', fp);
169 if (bradj)
170 fputexpos(pow(2.0, (double)bradj), fp);
171 if (frameno)
172 fprintf(fp, "FRAME=%d\n", frameno);
173 if (fmt[0])
174 fputformat(fmt, fp);
175 fputc('\n', fp);
176 fputresolu(order, xmax, ymax, fp);
177 /* transfer picture */
178 for (y = ymax; y--; ) {
179 if (fread2colrs(scanin, xmax, stdin, NCSAMP, WLPART) < 0) {
180 fprintf(stderr, "%s: error reading input picture\n",
181 progname);
182 exit(1);
183 }
184 if (bradj)
185 shiftcolrs(scanin, xmax, bradj);
186 if (doflat ? (putbinary(scanin, sizeof(COLR), xmax, fp) != xmax) :
187 (fwritecolrs(scanin, xmax, fp) < 0))
188 goto writerr;
189 }
190 free(scanin); /* clean up */
191 if (fflush(fp) == EOF)
192 goto writerr;
193 if (oname[0] == '!') {
194 if (pclose(fp) != 0)
195 fprintf(stderr, "%s: warning - bad status from \"%s\"\n",
196 progname, oname);
197 } else if (ospec != NULL)
198 fclose(fp);
199 return(1);
200 writerr:
201 fprintf(stderr, "%s: error writing output to \"%s\"\n",
202 progname, oname);
203 exit(1);
204 }
205
206
207 static int
208 addhline( /* add a line to our info. header */
209 char *s,
210 void *p
211 )
212 {
213 int n;
214
215 if (isheadid(s))
216 return(0);
217 if (!strncmp(s, "FRAME=", 6)) {
218 frameno = atoi(s+6);
219 return(0);
220 }
221 if (formatval(fmt, s)) {
222 if (!strcmp(fmt, SPECFMT))
223 strcpy(fmt, COLRFMT);
224 else
225 fmterr += !globmatch(PICFMT, fmt);
226 return(0);
227 }
228 if (isncomp(s)) {
229 NCSAMP = ncompval(s);
230 return(NCSAMP - 3);
231 }
232 if (iswlsplit(s)) {
233 wlsplitval(WLPART, s);
234 return(0);
235 }
236 n = strlen(s);
237 if (headlen)
238 headlines = (char *)realloc((void *)headlines, headlen+n+1);
239 else
240 headlines = (char *)malloc(n+1);
241 if (headlines == NULL) {
242 perror(progname);
243 exit(1);
244 }
245 strcpy(headlines+headlen, s);
246 headlen += n;
247 return(0);
248 }
249
250
251 static int
252 loadheader( /* load an info. header into memory */
253 FILE *fp
254 )
255 {
256 fmterr = 0; frameno = 0;
257 /* revert to initial header length */
258 if (!headlen1) headlen1 = headlen;
259 else headlen = headlen1;
260
261 if (getheader(fp, addhline, NULL) < 0)
262 return(0);
263 if (fmterr)
264 return(-1);
265 return(1);
266 }
