root/radiance/ray/src/px/ra_ps.c
Mon Jul 27 01:25:33 2020 UTC (3 years, 9 months ago) by greg
Changes since 2.31: +18 -17 lines
Diff to previous 2.31 , to selected 2.29
fix(ra_ps): change needed to pass unit test under Windows
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.30: +1 -3 lines
Diff to previous 2.30 , to selected 2.29
Thu Aug 2 18:33:47 2018 UTC (5 years, 9 months ago) by greg
Diff to previous 2.29
Revision 2.29 - (view) (download) (annotate) - [selected]
Tue Mar 20 18:45:04 2018 UTC (6 years, 2 months ago) by greg
Diff to previous 2.28
Added missing rtio.h include to redefine getc, putc, etc.
Changes since 2.27: +71 -46 lines
Diff to previous 2.27 , to selected 2.29
Fri Jan 2 12:47:01 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 2.26: +34 -28 lines
Diff to previous 2.26 , to selected 2.29
Changes since 2.25: +5 -5 lines
Diff to previous 2.25 , to selected 2.29
Changes since 2.24: +4 -7 lines
Diff to previous 2.24 , to selected 2.29
Changes since 2.23: +3 -7 lines
Diff to previous 2.23 , to selected 2.29
Mon Jul 19 09:53:06 1999 UTC (24 years, 10 months ago) by gwlarson
Diff to previous 2.22 , to selected 2.29
added missing semicolon to union declaration
Tue Oct 27 09:08:27 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 2.21 , to selected 2.29
Fri Aug 28 10:03:46 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 2.20: +12 -8 lines
Diff to previous 2.20 , to selected 2.29
made different gamma defaults for color and greyscale
Fri Sep 26 14:20:38 1997 UTC (26 years, 7 months ago) by gregl
Changes since 2.19: +28 -13 lines
Diff to previous 2.19 , to selected 2.29
added -d option to match printer density to pixels
Tue Sep 23 16:52:23 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.18: +10 -6 lines
Diff to previous 2.18 , to selected 2.29
fixed gamma correction and added new pages sizes
Thu Sep 18 18:01:24 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.17: +130 -6 lines
Diff to previous 2.17 , to selected 2.29
added -m and -p options to specify paper size and margins
Thu Sep 18 15:16:23 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.16: +14 -7 lines
Diff to previous 2.16 , to selected 2.29
added gamma correction for non-linear PostScript devices
Fri Oct 6 12:38:38 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.15: +4 -2 lines
Diff to previous 2.15 , to selected 2.29
fixed problem with -c -C output
Thu Oct 5 09:53:47 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.14: +104 -44 lines
Diff to previous 2.14 , to selected 2.29
 added -A, -B and -C options for different output types
removed interleave procedure since it seems unnecessary for colorimage
Wed Oct 4 16:01:32 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.13 , to selected 2.29
changed landscape orientation for ghostview
Wed Oct 4 12:30:58 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.12: +11 -4 lines
Diff to previous 2.12 , to selected 2.29
added gamma compression to reduce quantization errors
Thu Sep 28 16:34:30 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 2.11 , to selected 2.29
minor comment fix
Thu Sep 28 11:23:42 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.10: +80 -28 lines
Diff to previous 2.10 , to selected 2.29
added -c option for color output
Wed Sep 27 13:29:52 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.9: +30 -14 lines
Diff to previous 2.9 , to selected 2.29
added appropriate comments and save/restore for EPS conformation
Thu Feb 10 21:59:53 1994 UTC (30 years, 3 months ago) by greg
Changes since 2.8: +57 -13 lines
Diff to previous 2.8 , to selected 2.29
added run-length compression
Thu Feb 10 15:40:12 1994 UTC (30 years, 3 months ago) by greg
Diff to previous 2.7 , to selected 2.29
added bind command to main PostScript procedure definition
Thu Nov 18 09:55:17 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.6 , to selected 2.29
minor compiler warning fixes
Mon Sep 21 12:15:08 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.5: +12 -4 lines
Diff to previous 2.5 , to selected 2.29
Changes for PC port
Fri Aug 14 14:04:09 1992 UTC (31 years, 9 months ago) by greg
Diff to previous 2.4 , to selected 2.29
set black to black and white to white
Fri Aug 14 13:27:52 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.3: +8 -3 lines
Diff to previous 2.3 , to selected 2.29
added -n option for number of copies to print
Mon Jul 13 10:53:42 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.2 , to selected 2.29
moved commands around a little
Mon Jul 13 09:53:14 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.1: +11 -18 lines
Diff to previous 2.1 , to selected 2.29
changed and fixed image transformation
Mon Jul 13 09:28:01 1992 UTC (31 years, 10 months ago) by greg
Diff to selected 2.29
