1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ra_ps.c,v 2.30 2018/08/02 18:33:47 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Radiance picture to PostScript file translator -- one way! |
6 |
7 |
8 |
#include <math.h> |
9 |
#include <ctype.h> |
10 |
11 |
#include "platform.h" |
12 |
#include "rtio.h" |
13 |
#include "color.h" |
14 |
#include "resolu.h" |
15 |
16 |
#define UPPER(c) ((c)&~0x20) /* ASCII trick */ |
17 |
18 |
#define CODE6GAM 1.47 /* gamma for 6-bit codes */ |
19 |
#define DEFGGAM 1.0 /* greyscale device gamma */ |
20 |
#define DEFCGAM 1.8 /* color device gamma */ |
21 |
22 |
#define GRY -1 /* artificial index for grey */ |
23 |
24 |
#define DEFMARG 0.5 /* default margin (inches) */ |
25 |
#define DEFWIDTH 8.5 /* default page width */ |
26 |
#define DEFHEIGHT 11 /* default page height */ |
27 |
#define HMARGIN (hmarg*72) /* horizontal margin */ |
28 |
#define VMARGIN (vmarg*72) /* vertical margin */ |
29 |
#define PWIDTH (width*72-2*HMARGIN) /* width of device */ |
30 |
#define PHEIGHT (height*72-2*VMARGIN) /* height of device */ |
31 |
32 |
#define RUNCHR '*' /* character to start rle */ |
33 |
#define MINRUN 4 /* minimum run-length */ |
34 |
#define RSTRT '!' /* character for MINRUN */ |
35 |
#define MAXRUN (MINRUN+'~'-RSTRT) /* maximum run-length */ |
36 |
37 |
char code[] = /* 6-bit code lookup table */ |
38 |
"0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+"; |
39 |
40 |
int wrongformat = 0; /* input in wrong format? */ |
41 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
42 |
43 |
double devgam = 0.; /* device gamma response */ |
44 |
double hmarg = DEFMARG, |
45 |
vmarg = DEFMARG; /* horizontal and vertical margins */ |
46 |
double width = DEFWIDTH, |
47 |
height = DEFHEIGHT; /* default paper width and height */ |
48 |
double dpi = 0; /* print density (0 if unknown) */ |
49 |
int docolor = 1; /* produce color image? */ |
50 |
int bradj = 0; /* brightness adjustment */ |
51 |
int ncopies = 1; /* number of copies */ |
52 |
53 |
char *progname; |
54 |
int xmax, ymax; /* input image dimensions */ |
55 |
56 |
typedef void putprimf_t(COLR *scn, int pri); |
57 |
58 |
static gethfunc headline; |
59 |
static putprimf_t Aputprim, Bputprim, Cputprim; |
60 |
61 |
static double unit2inch(register char *s); |
62 |
static int matchid(char *name, char *id); |
63 |
static void parsepaper(char *ps); |
64 |
static void quiterr(char *err); |
65 |
static void PSheader(int ac, char **av); |
66 |
static void PStrailer(void); |
67 |
static void PSprocdef(char *nam); |
68 |
static void ra2ps(void); |
69 |
static void putrle(int cnt, int cod); |
70 |
71 |
72 |
putprimf_t *putprim = Aputprim; /* function for writing scanline */ |
73 |
74 |
75 |
static int |
76 |
headline( /* check header line */ |
77 |
char *s, |
78 |
void *p |
79 |
80 |
81 |
char fmt[MAXFMTLEN]; |
82 |
83 |
if (isformat(s)) { |
84 |
formatval(fmt, s); |
85 |
wrongformat = strcmp(fmt, COLRFMT); |
86 |
} else if (isaspect(s)) |
87 |
pixaspect *= aspectval(s); |
88 |
return(0); |
89 |
90 |
91 |
int |
92 |
main(int argc, char *argv[]) |
93 |
94 |
int i; |
95 |
double d; |
96 |
97 |
progname = argv[0]; |
98 |
99 |
for (i = 1; i < argc; i++) |
100 |
if (argv[i][0] == '-') |
101 |
switch (argv[i][1]) { |
102 |
case 'b': /* produce b&w PostScript */ |
103 |
docolor = 0; |
104 |
break; |
105 |
case 'c': /* produce color PostScript */ |
106 |
docolor = 1; |
107 |
break; |
108 |
case 'A': /* standard ASCII encoding */ |
109 |
putprim = Aputprim; |
110 |
break; |
111 |
case 'B': /* standard binary encoding */ |
112 |
putprim = Bputprim; |
113 |
break; |
114 |
case 'C': /* compressed ASCII encoding */ |
115 |
putprim = Cputprim; |
116 |
break; |
117 |
case 'd': /* print density */ |
118 |
dpi = atof(argv[++i]); |
119 |
break; |
120 |
case 'g': /* device gamma adjustment */ |
121 |
devgam = atof(argv[++i]); |
122 |
break; |
123 |
case 'p': /* paper size */ |
124 |
parsepaper(argv[++i]); |
125 |
break; |
126 |
case 'm': /* margin */ |
127 |
d = atof(argv[i+1]); |
128 |
d *= unit2inch(argv[i+1]); |
129 |
switch (argv[i][2]) { |
130 |
case '\0': |
131 |
hmarg = vmarg = d; |
132 |
break; |
133 |
case 'h': |
134 |
hmarg = d; |
135 |
break; |
136 |
case 'v': |
137 |
vmarg = d; |
138 |
break; |
139 |
default: |
140 |
goto userr; |
141 |
142 |
i++; |
143 |
break; |
144 |
case 'e': /* exposure adjustment */ |
145 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
146 |
goto userr; |
147 |
bradj = atoi(argv[++i]); |
148 |
break; |
149 |
case 'n': /* number of copies */ |
150 |
ncopies = atoi(argv[++i]); |
151 |
break; |
152 |
default: |
153 |
goto userr; |
154 |
155 |
else |
156 |
break; |
157 |
158 |
if (i < argc-2) |
159 |
goto userr; |
160 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
161 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
162 |
progname, argv[i]); |
163 |
exit(1); |
164 |
165 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
166 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
167 |
progname, argv[i+1]); |
168 |
exit(1); |
169 |
170 |
SET_FILE_BINARY(stdin); |
171 |
/* get our header */ |
172 |
getheader(stdin, headline, NULL); |
173 |
if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0) |
174 |
quiterr("bad picture format"); |
175 |
/* gamma compression */ |
176 |
if (devgam <= 0.05) |
177 |
devgam = docolor ? DEFCGAM : DEFGGAM; |
178 |
if (putprim == Cputprim) |
179 |
setcolrgam(CODE6GAM); |
180 |
else if (devgam != 1.) |
181 |
setcolrgam(devgam); |
182 |
/* write header */ |
183 |
PSheader(argc, argv); |
184 |
/* convert file */ |
185 |
ra2ps(); |
186 |
/* write trailer */ |
187 |
PStrailer(); |
188 |
exit(0); |
189 |
userr: |
190 |
fprintf(stderr, |
191 |
"Usage: %s [-b|c][-A|B|C][-e +/-stops][-p paper][-m[h|v] margin][-d dpi][-g gamma] [input [output]]\n", |
192 |
progname); |
193 |
exit(1); |
194 |
195 |
196 |
197 |
static double |
198 |
unit2inch( /* determine unit */ |
199 |
register char *s |
200 |
201 |
202 |
static struct unit {char n; float f;} u[] = { |
203 |
{'i', 1.}, |
204 |
{'m', 1./25.4}, |
205 |
{'c', 1./2.54}, |
206 |
{'\0',0} }; |
207 |
register struct unit *up; |
208 |
209 |
while (*s && !isalpha(*s)) |
210 |
s++; |
211 |
for (up = u; up->n; up++) |
212 |
if (up->n == *s) |
213 |
return(up->f); |
214 |
return(1.); |
215 |
216 |
217 |
218 |
static int |
219 |
matchid( /* see if name matches id (case insensitive) */ |
220 |
char *name, |
221 |
register char *id |
222 |
223 |
224 |
register char *s = name; |
225 |
226 |
while (*s) { |
227 |
if (isalpha(*s)) { |
228 |
if (!isalpha(*id) || UPPER(*s) != UPPER(*id)) |
229 |
return(0); |
230 |
} else if (*s != *id) |
231 |
return(0); |
232 |
s++; id++; |
233 |
234 |
return(!*id || s-name >= 3); /* substrings >= 3 chars OK */ |
235 |
236 |
237 |
238 |
static void |
239 |
parsepaper( /* determine paper size from name */ |
240 |
char *ps |
241 |
242 |
243 |
static struct psize {char n[12]; float w,h;} p[] = { |
244 |
{"envelope", 4.12, 9.5}, |
245 |
{"executive", 7.25, 10.5}, |
246 |
{"letter", 8.5, 11.}, |
247 |
{"lettersmall", 7.68, 10.16}, |
248 |
{"legal", 8.5, 14.}, |
249 |
{"monarch", 3.87, 7.5}, |
250 |
{"statement", 5.5, 8.5}, |
251 |
{"tabloid", 11., 17.}, |
252 |
{"A3", 11.69, 16.54}, |
253 |
{"A4", 8.27, 11.69}, |
254 |
{"A4small", 7.47, 10.85}, |
255 |
{"A5", 6.00, 8.27}, |
256 |
{"A6", 4.13, 6.00}, |
257 |
{"B4", 10.12, 14.33}, |
258 |
{"B5", 7.17, 10.12}, |
259 |
{"C5", 6.38, 9.01}, |
260 |
{"C6", 4.49, 6.38}, |
261 |
{"DL", 4.33, 8.66}, |
262 |
{"hagaki", 3.94, 5.83}, |
263 |
{"",0.0,0.0} }; |
264 |
register struct psize *pp; |
265 |
register char *s = ps; |
266 |
double d; |
267 |
268 |
if (isdigit(*s)) { /* check for WWxHH specification */ |
269 |
width = atof(s); |
270 |
271 |
s++; |
272 |
d = unit2inch(s); |
273 |
height = atof(++s); |
274 |
width *= d; |
275 |
height *= d; |
276 |
if ((width >= 1.) & (height >= 1.)) |
277 |
return; |
278 |
} else /* check for match to standard size */ |
279 |
for (pp = p; pp->n[0]; pp++) |
280 |
if (matchid(s, pp->n)) { |
281 |
width = pp->w; |
282 |
height = pp->h; |
283 |
return; |
284 |
285 |
fprintf(stderr, "%s: unknown paper size \"%s\" -- known sizes:\n", |
286 |
progname, ps); |
287 |
fprintf(stderr, "_Name________Width_Height_(inches)\n"); |
288 |
289 |
fprintf(stderr, "%-11s %5.2f %5.2f\n", pp->n, pp->w, pp->h); |
290 |
fprintf(stderr, "Or use WWxHH size specification\n"); |
291 |
exit(1); |
292 |
293 |
294 |
295 |
static void |
296 |
quiterr( /* print message and exit */ |
297 |
char *err |
298 |
299 |
300 |
if (err != NULL) { |
301 |
fprintf(stderr, "%s: %s\n", progname, err); |
302 |
exit(1); |
303 |
304 |
exit(0); |
305 |
306 |
307 |
308 |
static void |
309 |
PSheader( /* print PostScript header */ |
310 |
int ac, |
311 |
char **av |
312 |
313 |
314 |
char *rstr; |
315 |
int landscape, rotate, n; |
316 |
double pwidth, pheight; |
317 |
double iwidth, iheight; |
318 |
/* EPS comments */ |
319 |
puts("%!PS-Adobe-2.0 EPSF-2.0"); |
320 |
printf("%%%%Title: "); printargs(ac, av, stdout); |
321 |
printf("%%%%Creator: %s\n", progname); |
322 |
printf("%%%%Pages: %d\n", ncopies); |
323 |
if ( (landscape = xmax > pixaspect*ymax) ) |
324 |
puts("%%Orientation: Landscape"); |
325 |
else |
326 |
puts("%%Orientation: Portrait"); |
327 |
if ( (rotate = (PWIDTH > PHEIGHT) ^ landscape) ) { |
328 |
pwidth = PHEIGHT; |
329 |
pheight = PWIDTH; |
330 |
} else { |
331 |
pwidth = PWIDTH; |
332 |
pheight = PHEIGHT; |
333 |
334 |
if (dpi > 100 && (pixaspect >= 0.99) & (pixaspect <= 1.01)) |
335 |
if (pheight/pwidth > ymax/xmax) { |
336 |
n = pwidth*dpi/xmax; /* floor */ |
337 |
iwidth = n > 0 ? (double)(n*xmax)/dpi : pwidth; |
338 |
iheight = iwidth*ymax/xmax; |
339 |
} else { |
340 |
n = pheight*dpi/ymax; /* floor */ |
341 |
iheight = n > 0 ? (double)(n*ymax)/dpi : pheight; |
342 |
iwidth = iheight*xmax/ymax; |
343 |
344 |
else |
345 |
if (pheight/pwidth > pixaspect*ymax/xmax) { |
346 |
iwidth = pwidth; |
347 |
iheight = iwidth*pixaspect*ymax/xmax; |
348 |
} else { |
349 |
iheight = pheight; |
350 |
iwidth = iheight*xmax/(pixaspect*ymax); |
351 |
352 |
if (rotate) |
353 |
printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n", |
354 |
HMARGIN+(pheight-iheight)*.5, |
355 |
VMARGIN+(pwidth-iwidth)*.5, |
356 |
HMARGIN+(pheight-iheight)*.5+iheight, |
357 |
VMARGIN+(pwidth-iwidth)*.5+iwidth); |
358 |
else |
359 |
360 |
HMARGIN+(pwidth-iwidth)*.5, |
361 |
VMARGIN+(pheight-iheight)*.5, |
362 |
HMARGIN+(pwidth-iwidth)*.5+iwidth, |
363 |
VMARGIN+(pheight-iheight)*.5+iheight); |
364 |
puts("%%EndComments"); |
365 |
puts("gsave save"); |
366 |
puts("17 dict begin"); |
367 |
/* define image reader */ |
368 |
if (docolor) { |
369 |
printf("/redline %d string def\n", xmax); |
370 |
printf("/grnline %d string def\n", xmax); |
371 |
printf("/bluline %d string def\n", xmax); |
372 |
} else |
373 |
printf("/gryline %d string def\n", xmax); |
374 |
/* use compressed encoding? */ |
375 |
376 |
PSprocdef("read6bitRLE"); |
377 |
/* set up transformation matrix */ |
378 |
printf("%f %f translate\n", HMARGIN, VMARGIN); |
379 |
if (rotate) { |
380 |
printf("%f 0 translate\n", PWIDTH); |
381 |
puts("90 rotate"); |
382 |
383 |
printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5); |
384 |
printf("%f %f scale\n", iwidth, iheight); |
385 |
puts("%%EndProlog"); |
386 |
/* start image procedure */ |
387 |
printf("%d %d 8 [%d 0 0 %d 0 %d]\n", xmax, ymax, xmax, -ymax, ymax); |
388 |
if (putprim == Cputprim) { |
389 |
if (docolor) { |
390 |
puts("{redline read6bitRLE}"); |
391 |
puts("{grnline read6bitRLE}"); |
392 |
puts("{bluline read6bitRLE}"); |
393 |
puts("true 3 colorimage"); |
394 |
} else |
395 |
puts("{gryline read6bitRLE} image"); |
396 |
} else { |
397 |
rstr = putprim==Aputprim ? "readhexstring" : "readstring"; |
398 |
if (docolor) { |
399 |
printf("{currentfile redline %s pop}\n", rstr); |
400 |
printf("{currentfile grnline %s pop}\n", rstr); |
401 |
printf("{currentfile bluline %s pop}\n", rstr); |
402 |
403 |
} else |
404 |
printf("{currentfile gryline %s pop} image\n", rstr); |
405 |
406 |
407 |
408 |
409 |
static void |
410 |
PStrailer(void) /* print PostScript trailer */ |
411 |
412 |
puts("%%Trailer"); |
413 |
if (ncopies > 1) |
414 |
printf("/#copies %d def\n", ncopies); |
415 |
puts("showpage"); |
416 |
puts("end"); |
417 |
puts("restore grestore"); |
418 |
puts("%%EOF"); |
419 |
420 |
421 |
422 |
static void |
423 |
PSprocdef( /* define PS procedure to read image */ |
424 |
char *nam |
425 |
426 |
427 |
short itab[128]; |
428 |
register int i; |
429 |
/* assign code values */ |
430 |
for (i = 0; i < 128; i++) /* clear */ |
431 |
itab[i] = -1; |
432 |
for (i = 1; i < 63; i++) /* assign greys */ |
433 |
itab[(int)code[i]] = 256.0*pow((i+.5)/64.0, CODE6GAM/devgam); |
434 |
itab[(int)code[0]] = 0; /* black is black */ |
435 |
itab[(int)code[63]] = 255; /* and white is white */ |
436 |
printf("/codetab ["); |
437 |
for (i = 0; i < 128; i++) { |
438 |
if (!(i & 0xf)) |
439 |
putchar('\n'); |
440 |
printf(" %3d", itab[i]); |
441 |
442 |
printf("\n] def\n"); |
443 |
printf("/nrept 0 def\n"); |
444 |
printf("/readbyte { currentfile read not {stop} if } bind def\n"); |
445 |
printf("/decode { codetab exch get } bind def\n"); |
446 |
printf("/%s {\t%% scanbuffer\n", nam); |
447 |
printf("\t/scanline exch def\n"); |
448 |
printf("\t{ 0 1 %d { scanline exch\n", xmax-1); |
449 |
printf("\t\tnrept 0 le\n"); |
450 |
printf("\t\t\t{ { readbyte dup %d eq\n", RUNCHR); |
451 |
printf("\t\t\t\t\t{ pop /nrept readbyte %d sub def\n", RSTRT-MINRUN+1); |
452 |
printf("\t\t\t\t\t\t/reptv readbyte decode def\n"); |
453 |
printf("\t\t\t\t\t\treptv exit }\n"); |
454 |
printf("\t\t\t\t\t{ decode dup 0 lt {pop} {exit} ifelse }\n"); |
455 |
printf("\t\t\t\tifelse } loop }\n"); |
456 |
printf("\t\t\t{ /nrept nrept 1 sub def reptv }\n"); |
457 |
printf("\t\tifelse put\n"); |
458 |
printf("\t\t} for\n"); |
459 |
printf("\t} stopped {pop pop 0 string} {scanline} ifelse\n"); |
460 |
printf("} bind def\n"); |
461 |
462 |
463 |
464 |
static void |
465 |
ra2ps(void) /* convert Radiance scanlines to 6-bit */ |
466 |
467 |
register COLR *scanin; |
468 |
int y; |
469 |
/* allocate scanline */ |
470 |
scanin = (COLR *)malloc(xmax*sizeof(COLR)); |
471 |
if (scanin == NULL) |
472 |
quiterr("out of memory in ra2ps"); |
473 |
/* convert image */ |
474 |
for (y = ymax-1; y >= 0; y--) { |
475 |
if (freadcolrs(scanin, xmax, stdin) < 0) |
476 |
quiterr("error reading Radiance picture"); |
477 |
if (putprim == Cputprim || devgam != 1.) { |
478 |
if (bradj) /* adjust exposure */ |
479 |
shiftcolrs(scanin, xmax, bradj); |
480 |
colrs_gambs(scanin, xmax); /* gamma compression */ |
481 |
} else |
482 |
normcolrs(scanin, xmax, bradj); |
483 |
if (docolor) { |
484 |
(*putprim)(scanin, RED); |
485 |
(*putprim)(scanin, GRN); |
486 |
(*putprim)(scanin, BLU); |
487 |
} else |
488 |
(*putprim)(scanin, GRY); |
489 |
if (ferror(stdout)) |
490 |
quiterr("error writing PostScript file"); |
491 |
492 |
putchar('\n'); |
493 |
/* free scanline */ |
494 |
free((void *)scanin); |
495 |
496 |
497 |
498 |
static void |
499 |
Aputprim( /* put out hex ASCII primary from scanline */ |
500 |
COLR *scn, |
501 |
int pri |
502 |
503 |
504 |
static char hexdigit[] = "0123456789ABCDEF"; |
505 |
static int col = 0; |
506 |
register int x, c; |
507 |
508 |
for (x = 0; x < xmax; x++) { |
509 |
if (pri == GRY) |
510 |
c = normbright(scn[x]); |
511 |
else |
512 |
c = scn[x][pri]; |
513 |
if (c > 255) c = 255; |
514 |
putchar(hexdigit[c>>4]); |
515 |
putchar(hexdigit[c&0xf]); |
516 |
if ((col += 2) >= 72) { |
517 |
putchar('\n'); |
518 |
col = 0; |
519 |
520 |
521 |
522 |
523 |
524 |
static void |
525 |
Bputprim( /* put out binary primary from scanline */ |
526 |
COLR *scn, |
527 |
int pri |
528 |
529 |
530 |
531 |
532 |
533 |
if (pri == GRY) |
534 |
535 |
else |
536 |
c = scn[x][pri]; |
537 |
538 |
putchar(c); |
539 |
540 |
541 |
542 |
543 |
static void |
544 |
Cputprim( /* put out compressed primary from scanline */ |
545 |
COLR *scn, |
546 |
int pri |
547 |
548 |
549 |
register int c; |
550 |
register int x; |
551 |
int lastc, cnt; |
552 |
553 |
lastc = -1; cnt = 0; |
554 |
555 |
if (pri == GRY) |
556 |
c = normbright(scn[x]) + 2; |
557 |
else |
558 |
c = scn[x][pri] + 2; |
559 |
560 |
c = code[c>>2]; |
561 |
if (c == lastc && cnt < MAXRUN) |
562 |
cnt++; |
563 |
else { |
564 |
putrle(cnt, lastc); |
565 |
lastc = c; |
566 |
cnt = 1; |
567 |
568 |
569 |
570 |
571 |
572 |
573 |
static void |
574 |
putrle( /* put out cnt of cod */ |
575 |
register int cnt, |
576 |
register int cod |
577 |
578 |
579 |
580 |
581 |
if (cnt >= MINRUN) { |
582 |
col += 3; |
583 |
putchar(RUNCHR); |
584 |
putchar(RSTRT-MINRUN+cnt); |
585 |
putchar(cod); |
586 |
} else { |
587 |
col += cnt; |
588 |
while (cnt-- > 0) |
589 |
putchar(cod); |
590 |
591 |
if (col >= 72) { |
592 |
putchar('\n'); |
593 |
col = 0; |
594 |
595 |
