1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Radiance picture to PostScript file translator -- one way! |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#ifdef MSDOS |
13 |
#include <fcntl.h> |
14 |
#endif |
15 |
#include "color.h" |
16 |
17 |
#define GRY -1 /* artificial index for grey */ |
18 |
19 |
#define HMARGIN (.5*72) /* horizontal margin */ |
20 |
#define VMARGIN (.5*72) /* vertical margin */ |
21 |
#define PWIDTH (8.5*72-2*HMARGIN) /* width of device */ |
22 |
#define PHEIGHT (11*72-2*VMARGIN) /* height of device */ |
23 |
24 |
#define RUNCHR '*' /* character to start rle */ |
25 |
#define MINRUN 4 /* minimum run-length */ |
26 |
#define RSTRT '!' /* character for MINRUN */ |
27 |
#define MAXRUN (MINRUN+'~'-RSTRT) /* maximum run-length */ |
28 |
29 |
char code[] = /* 6-bit code lookup table */ |
30 |
"0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+"; |
31 |
32 |
int wrongformat = 0; /* input in wrong format? */ |
33 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
34 |
35 |
int docolor = 0; /* produce color image? */ |
36 |
int bradj = 0; /* brightness adjustment */ |
37 |
int ncopies = 1; /* number of copies */ |
38 |
39 |
char *progname; |
40 |
41 |
int xmax, ymax; |
42 |
43 |
extern char *malloc(); |
44 |
45 |
46 |
headline(s) /* check header line */ |
47 |
char *s; |
48 |
49 |
char fmt[32]; |
50 |
51 |
if (isformat(s)) { |
52 |
formatval(fmt, s); |
53 |
wrongformat = strcmp(fmt, COLRFMT); |
54 |
} else if (isaspect(s)) |
55 |
pixaspect *= aspectval(s); |
56 |
57 |
58 |
59 |
main(argc, argv) |
60 |
int argc; |
61 |
char *argv[]; |
62 |
63 |
int i; |
64 |
65 |
progname = argv[0]; |
66 |
67 |
for (i = 1; i < argc; i++) |
68 |
if (argv[i][0] == '-') |
69 |
switch (argv[i][1]) { |
70 |
case 'c': /* produce color PostScript */ |
71 |
docolor++; |
72 |
break; |
73 |
case 'e': /* exposure adjustment */ |
74 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
75 |
goto userr; |
76 |
bradj = atoi(argv[++i]); |
77 |
break; |
78 |
case 'n': /* number of copies */ |
79 |
ncopies = atoi(argv[++i]); |
80 |
break; |
81 |
default: |
82 |
goto userr; |
83 |
84 |
else |
85 |
break; |
86 |
87 |
if (i < argc-2) |
88 |
goto userr; |
89 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
90 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
91 |
progname, argv[i]); |
92 |
exit(1); |
93 |
94 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
95 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
96 |
progname, argv[i+1]); |
97 |
exit(1); |
98 |
99 |
#ifdef MSDOS |
100 |
setmode(fileno(stdin), O_BINARY); |
101 |
#endif |
102 |
/* get our header */ |
103 |
getheader(stdin, headline, NULL); |
104 |
if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0) |
105 |
quiterr("bad picture format"); |
106 |
/* write header */ |
107 |
PSheader(i <= argc-1 ? argv[i] : "<stdin>"); |
108 |
/* convert file */ |
109 |
ra2ps(); |
110 |
/* write trailer */ |
111 |
PStrailer(); |
112 |
exit(0); |
113 |
userr: |
114 |
fprintf(stderr, "Usage: %s [-c][-e +/-stops] [input [output]]\n", |
115 |
progname); |
116 |
exit(1); |
117 |
118 |
119 |
120 |
quiterr(err) /* print message and exit */ |
121 |
char *err; |
122 |
123 |
if (err != NULL) { |
124 |
fprintf(stderr, "%s: %s\n", progname, err); |
125 |
exit(1); |
126 |
127 |
exit(0); |
128 |
129 |
130 |
131 |
PSheader(name) /* print PostScript header */ |
132 |
char *name; |
133 |
134 |
int landscape = 0; |
135 |
double pwidth, pheight; |
136 |
double iwidth, iheight; |
137 |
/* EPS comments */ |
138 |
puts("%!PS-Adobe-2.0 EPSF-2.0"); |
139 |
printf("%%%%Title: %s\n", name); |
140 |
printf("%%%%Creator: %s = %s\n", progname, SCCSid); |
141 |
printf("%%%%Pages: %d\n", ncopies); |
142 |
if (landscape = xmax > pixaspect*ymax) |
143 |
puts("%%Orientation: Landscape"); |
144 |
else |
145 |
puts("%%Orientation: Portrait"); |
146 |
if (PWIDTH > PHEIGHT ^ landscape) { |
147 |
pwidth = PHEIGHT; |
148 |
pheight = PWIDTH; |
149 |
} else { |
150 |
pwidth = PWIDTH; |
151 |
pheight = PHEIGHT; |
152 |
153 |
if (pheight/pwidth > pixaspect*ymax/xmax) { |
154 |
iwidth = pwidth; |
155 |
iheight = pwidth*pixaspect*ymax/xmax; |
156 |
} else { |
157 |
iheight = pheight; |
158 |
iwidth = pheight*xmax/(pixaspect*ymax); |
159 |
160 |
if (pwidth == PHEIGHT) |
161 |
printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n", |
162 |
HMARGIN+(pheight-iheight)*.5, |
163 |
VMARGIN+(pwidth-iwidth)*.5, |
164 |
HMARGIN+(pheight-iheight)*.5+iheight, |
165 |
VMARGIN+(pwidth-iwidth)*.5+iwidth); |
166 |
else |
167 |
168 |
HMARGIN+(pwidth-iwidth)*.5, |
169 |
VMARGIN+(pheight-iheight)*.5, |
170 |
HMARGIN+(pwidth-iwidth)*.5+iwidth, |
171 |
VMARGIN+(pheight-iheight)*.5+iheight); |
172 |
puts("%%EndComments"); |
173 |
puts("save"); |
174 |
puts("64 dict begin"); |
175 |
/* define image reader */ |
176 |
if (docolor) { |
177 |
printf("/redline %d string def\n", xmax); |
178 |
printf("/grnline %d string def\n", xmax); |
179 |
printf("/bluline %d string def\n", xmax); |
180 |
printf("/rgbline %d string def\n", 3*xmax); |
181 |
PSprocdef("read6bitRLE", "interleave"); |
182 |
} else { |
183 |
printf("/greyline %d string def\n", xmax); |
184 |
PSprocdef("read6bitRLE", NULL); |
185 |
186 |
/* set up transformation matrix */ |
187 |
printf("%f %f translate\n", HMARGIN, VMARGIN); |
188 |
if (pwidth == PHEIGHT) { |
189 |
printf("0 %f translate\n", PHEIGHT); |
190 |
puts("-90 rotate"); |
191 |
192 |
printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5); |
193 |
printf("%f %f scale\n", iwidth, iheight); |
194 |
puts("%%EndProlog"); |
195 |
/* start image procedure */ |
196 |
printf("%d %d 8 [%d 0 0 %d 0 %d] ", xmax, ymax, xmax, -ymax, ymax); |
197 |
if (docolor) { |
198 |
puts("{redline read6bitRLE grnline read6bitRLE"); |
199 |
puts("\tbluline read6bitRLE rgbline interleave} false 3 colorimage"); |
200 |
} else |
201 |
puts("{greyline read6bitRLE} image"); |
202 |
203 |
204 |
205 |
PStrailer() /* print PostScript trailer */ |
206 |
207 |
puts("%%Trailer"); |
208 |
if (ncopies > 1) |
209 |
printf("/#copies %d def\n", ncopies); |
210 |
puts("showpage"); |
211 |
puts("end"); |
212 |
puts("restore"); |
213 |
puts("%%EOF"); |
214 |
215 |
216 |
217 |
PSprocdef(nam, inam) /* define PS procedure to read image */ |
218 |
char *nam, *inam; |
219 |
220 |
short itab[128]; |
221 |
register int i; |
222 |
/* assign code values */ |
223 |
for (i = 0; i < 128; i++) /* clear */ |
224 |
itab[i] = -1; |
225 |
for (i = 1; i < 63; i++) /* assign greys */ |
226 |
itab[code[i]] = i<<2 | 2; |
227 |
itab[code[0]] = 0; /* black is black */ |
228 |
itab[code[63]] = 255; /* and white is white */ |
229 |
printf("/codetab ["); |
230 |
for (i = 0; i < 128; i++) { |
231 |
if (!(i & 0xf)) |
232 |
putchar('\n'); |
233 |
printf(" %3d", itab[i]); |
234 |
235 |
printf("\n] def\n"); |
236 |
printf("/nrept 0 def\n"); |
237 |
printf("/readbyte { currentfile read not {stop} if } bind def\n"); |
238 |
printf("/decode { codetab exch get } bind def\n"); |
239 |
printf("/%s {\t%% scanbuffer\n", nam); |
240 |
printf("\t/scanline exch def\n"); |
241 |
printf("\t{ 0 1 %d { scanline exch\n", xmax-1); |
242 |
printf("\t\tnrept 0 le\n"); |
243 |
printf("\t\t\t{ { readbyte dup %d eq\n", RUNCHR); |
244 |
printf("\t\t\t\t\t{ pop /nrept readbyte %d sub def\n", RSTRT-MINRUN+1); |
245 |
printf("\t\t\t\t\t\t/reptv readbyte decode def\n"); |
246 |
printf("\t\t\t\t\t\treptv exit }\n"); |
247 |
printf("\t\t\t\t\t{ decode dup 0 lt {pop} {exit} ifelse }\n"); |
248 |
printf("\t\t\t\tifelse } loop }\n"); |
249 |
printf("\t\t\t{ /nrept nrept 1 sub def reptv }\n"); |
250 |
printf("\t\tifelse put\n"); |
251 |
printf("\t\t} for\n"); |
252 |
printf("\t} stopped {pop pop 0 string} {scanline} ifelse\n"); |
253 |
printf("} bind def\n"); |
254 |
if (inam == NULL) |
255 |
return; |
256 |
/* define interleaving procedure */ |
257 |
printf("/%s {\t%% redscn grnscn bluscn rgbscn\n", inam); |
258 |
printf("\t/rgbscan exch def /bscan exch def\n"); |
259 |
printf("\t/gscan exch def /rscan exch def\n"); |
260 |
printf("\trscan length %d eq gscan length %d eq and ", xmax, xmax); |
261 |
printf("bscan length %d eq and \n", xmax); |
262 |
printf("\t{ 0 1 %d { /ndx exch def\n", xmax-1); |
263 |
printf("\t\trgbscan ndx 3 mul rscan ndx get put\n"); |
264 |
printf("\t\trgbscan ndx 3 mul 1 add gscan ndx get put\n"); |
265 |
printf("\t\trgbscan ndx 3 mul 2 add bscan ndx get put\n"); |
266 |
printf("\t\t} for rgbscan }\n"); |
267 |
printf("\t{0 string} ifelse\n"); |
268 |
269 |
270 |
271 |
272 |
ra2ps() /* convert Radiance scanlines to 6-bit */ |
273 |
274 |
register COLR *scanin; |
275 |
int y; |
276 |
/* allocate scanline */ |
277 |
scanin = (COLR *)malloc(xmax*sizeof(COLR)); |
278 |
if (scanin == NULL) |
279 |
quiterr("out of memory in ra2ps"); |
280 |
/* convert image */ |
281 |
for (y = ymax-1; y >= 0; y--) { |
282 |
if (freadcolrs(scanin, xmax, stdin) < 0) |
283 |
quiterr("error reading Radiance picture"); |
284 |
normcolrs(scanin, xmax, bradj); /* normalize */ |
285 |
if (docolor) { |
286 |
putprim(scanin, RED); |
287 |
putprim(scanin, GRN); |
288 |
putprim(scanin, BLU); |
289 |
} else |
290 |
putprim(scanin, GRY); |
291 |
if (ferror(stdout)) |
292 |
quiterr("error writing PostScript file"); |
293 |
294 |
putchar('\n'); |
295 |
/* free scanline */ |
296 |
free((char *)scanin); |
297 |
298 |
299 |
300 |
putprim(scn, pri) /* put out one primary from scanline */ |
301 |
COLR *scn; |
302 |
int pri; |
303 |
304 |
register int c; |
305 |
register int x; |
306 |
int lastc, cnt; |
307 |
308 |
lastc = -1; cnt = 0; |
309 |
for (x = 0; x < xmax; x++) { |
310 |
if (pri == GRY) |
311 |
c = normbright(scn[x]) + 2; |
312 |
else |
313 |
c = scn[x][pri] + 2; |
314 |
if (c > 255) c = 255; |
315 |
c = code[c>>2]; |
316 |
if (c == lastc && cnt < MAXRUN) |
317 |
cnt++; |
318 |
else { |
319 |
putrle(cnt, lastc); |
320 |
lastc = c; |
321 |
cnt = 1; |
322 |
323 |
324 |
325 |
326 |
327 |
328 |
putrle(cnt, cod) /* put out cnt of cod */ |
329 |
register int cnt, cod; |
330 |
331 |
static int col = 0; |
332 |
333 |
if (cnt >= MINRUN) { |
334 |
col += 3; |
335 |
putchar(RUNCHR); |
336 |
putchar(RSTRT-MINRUN+cnt); |
337 |
putchar(cod); |
338 |
} else { |
339 |
col += cnt; |
340 |
while (cnt-- > 0) |
341 |
putchar(cod); |
342 |
343 |
if (col >= 72) { |
344 |
putchar('\n'); |
345 |
col = 0; |
346 |
347 |
