root/radiance/ray/src/px/ra_ps.c
Revision: 2.10
Committed: Wed Sep 27 13:29:52 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.9: +30 -14 lines
added appropriate comments and save/restore for EPS conformation
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Radiance picture to PostScript file translator -- one way!
9 */
10
11 #include <stdio.h>
12 #ifdef MSDOS
13 #include <fcntl.h>
14 #endif
15 #include "color.h"
16
17 #define HMARGIN (.5*72) /* horizontal margin */
18 #define VMARGIN (.5*72) /* vertical margin */
19 #define PWIDTH (8.5*72-2*HMARGIN) /* width of device */
20 #define PHEIGHT (11*72-2*VMARGIN) /* height of device */
21
22 #define RUNCHR '*' /* character to start rle */
23 #define MINRUN 4 /* minimum run-length */
24 #define RSTRT '!' /* character for MINRUN */
25 #define MAXRUN (MINRUN+'~'-RSTRT) /* maximum run-length */
26
27 char code[] = /* 6-bit code lookup table */
28 "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+";
29
30 int wrongformat = 0; /* input in wrong format? */
31 double pixaspect = 1.0; /* pixel aspect ratio */
32
33 int bradj = 0; /* brightness adjustment */
34 int ncopies = 1; /* number of copies */
35
36 char *progname;
37
38 int xmax, ymax;
39
40 extern char *malloc();
41
42
43 headline(s) /* check header line */
44 char *s;
45 {
46 char fmt[32];
47
48 if (isformat(s)) {
49 formatval(fmt, s);
50 wrongformat = strcmp(fmt, COLRFMT);
51 } else if (isaspect(s))
52 pixaspect *= aspectval(s);
53 }
54
55
56 main(argc, argv)
57 int argc;
58 char *argv[];
59 {
60 int i;
61
62 progname = argv[0];
63
64 for (i = 1; i < argc; i++)
65 if (argv[i][0] == '-')
66 switch (argv[i][1]) {
67 case 'e': /* exposure adjustment */
68 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
69 goto userr;
70 bradj = atoi(argv[++i]);
71 break;
72 case 'n': /* number of copies */
73 ncopies = atoi(argv[++i]);
74 break;
75 default:
76 goto userr;
77 }
78 else
79 break;
80
81 if (i < argc-2)
82 goto userr;
83 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
84 fprintf(stderr, "%s: can't open input \"%s\"\n",
85 progname, argv[i]);
86 exit(1);
87 }
88 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
89 fprintf(stderr, "%s: can't open output \"%s\"\n",
90 progname, argv[i+1]);
91 exit(1);
92 }
93 #ifdef MSDOS
94 setmode(fileno(stdin), O_BINARY);
95 #endif
96 /* get our header */
97 getheader(stdin, headline, NULL);
98 if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0)
99 quiterr("bad picture format");
100 /* write header */
101 PSheader(i <= argc-1 ? argv[i] : "<stdin>");
102 /* convert file */
103 ra2ps();
104 /* write trailer */
105 PStrailer();
106 exit(0);
107 userr:
108 fprintf(stderr, "Usage: %s [-e +/-stops] [input [output]]\n", progname);
109 exit(1);
110 }
111
112
113 quiterr(err) /* print message and exit */
114 char *err;
115 {
116 if (err != NULL) {
117 fprintf(stderr, "%s: %s\n", progname, err);
118 exit(1);
119 }
120 exit(0);
121 }
122
123
124 PSheader(name) /* print PostScript header */
125 char *name;
126 {
127 int landscape = 0;
128 double pwidth, pheight;
129 double iwidth, iheight;
130 /* EPS comments */
131 puts("%%!PS-Adobe-2.0 EPSF-2.0");
132 printf("%%%%Title: %s\n", name);
133 printf("%%%%Creator: %s = %s\n", progname, SCCSid);
134 printf("%%%%Pages: %d\n", ncopies);
135 if (landscape = xmax > pixaspect*ymax)
136 puts("%%Orientation: Landscape");
137 else
138 puts("%%Orientation: Portrait");
139 if (PWIDTH > PHEIGHT ^ landscape) {
140 pwidth = PHEIGHT;
141 pheight = PWIDTH;
142 } else {
143 pwidth = PWIDTH;
144 pheight = PHEIGHT;
145 }
146 if (pheight/pwidth > pixaspect*ymax/xmax) {
147 iwidth = pwidth;
148 iheight = pwidth*pixaspect*ymax/xmax;
149 } else {
150 iheight = pheight;
151 iwidth = pheight*xmax/(pixaspect*ymax);
152 }
153 if (pwidth == PHEIGHT)
154 printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
155 HMARGIN+(pheight-iheight)*.5,
156 VMARGIN+(pwidth-iwidth)*.5,
157 HMARGIN+(pheight-iheight)*.5+iheight,
158 VMARGIN+(pwidth-iwidth)*.5+iwidth);
159 else
160 printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
161 HMARGIN+(pwidth-iwidth)*.5,
162 VMARGIN+(pheight-iheight)*.5,
163 HMARGIN+(pwidth-iwidth)*.5+iwidth,
164 VMARGIN+(pheight-iheight)*.5+iheight);
165 puts("%%EndComments");
166 puts("save");
167 puts("64 dict begin");
168 /* define image reader */
169 PSprocdef("read6bitRLE");
170 /* set up transformation matrix */
171 printf("%f %f translate\n", HMARGIN, VMARGIN);
172 if (pwidth == PHEIGHT) {
173 printf("0 %f translate\n", PHEIGHT);
174 puts("-90 rotate");
175 }
176 printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5);
177 printf("%f %f scale\n", iwidth, iheight);
178 puts("%%%%EndProlog");
179 /* start image procedure */
180 printf("%d %d 8 [%d 0 0 %d 0 %d] {read6bitRLE} image\n", xmax, ymax,
181 xmax, -ymax, ymax);
182 }
183
184
185 PStrailer() /* print PostScript trailer */
186 {
187 puts("%%Trailer");
188 if (ncopies > 1)
189 printf("/#copies %d def\n", ncopies);
190 puts("showpage");
191 puts("end");
192 puts("restore");
193 puts("%%EOF");
194 }
195
196
197 PSprocdef(nam) /* define PS procedure to read image */
198 char *nam;
199 {
200 short itab[128];
201 register int i;
202 /* assign code values */
203 for (i = 0; i < 128; i++) /* clear */
204 itab[i] = -1;
205 for (i = 1; i < 63; i++) /* assign greys */
206 itab[code[i]] = i<<2 | 2;
207 itab[code[0]] = 0; /* black is black */
208 itab[code[63]] = 255; /* and white is white */
209 printf("/codetab [");
210 for (i = 0; i < 128; i++) {
211 if (!(i & 0xf))
212 putchar('\n');
213 printf(" %3d", itab[i]);
214 }
215 printf("\n] def\n");
216 printf("/scanline %d string def\n", xmax);
217 printf("/nrept 0 def\n");
218 printf("/readbyte { currentfile read not {stop} if } def\n");
219 printf("/decode { codetab exch get } def\n");
220 printf("/%s {\n", nam);
221 printf("\t{ 0 1 %d { scanline exch\n", xmax-1);
222 printf("\t\tnrept 0 le\n");
223 printf("\t\t\t{ { readbyte dup %d eq\n", RUNCHR);
224 printf("\t\t\t\t\t{ pop /nrept readbyte %d sub def\n", RSTRT-MINRUN+1);
225 printf("\t\t\t\t\t\t/reptv readbyte decode def\n");
226 printf("\t\t\t\t\t\treptv exit }\n");
227 printf("\t\t\t\t\t{ decode dup 0 lt {pop} {exit} ifelse }\n");
228 printf("\t\t\t\tifelse } loop }\n");
229 printf("\t\t\t{ /nrept nrept 1 sub def reptv }\n");
230 printf("\t\tifelse put\n");
231 printf("\t\t} for\n");
232 printf("\t} stopped {pop pop 0 string} {scanline} ifelse\n");
233 printf("} bind def\n");
234 }
235
236
237 ra2ps() /* convert Radiance scanlines to 6-bit */
238 {
239 register COLR *scanin;
240 register int c;
241 int lastc, cnt;
242 register int x;
243 int y;
244 /* allocate scanline */
245 scanin = (COLR *)malloc(xmax*sizeof(COLR));
246 if (scanin == NULL)
247 quiterr("out of memory in ra2ps");
248 /* convert image */
249 for (y = ymax-1; y >= 0; y--) {
250 if (freadcolrs(scanin, xmax, stdin) < 0)
251 quiterr("error reading Radiance picture");
252 normcolrs(scanin, xmax, bradj); /* normalize */
253 lastc = -1; cnt = 0;
254 for (x = 0; x < xmax; x++) {
255 c = normbright(scanin[x]) + 2;
256 if (c > 255) c = 255;
257 c = code[c>>2];
258 if (c == lastc && cnt < MAXRUN)
259 cnt++;
260 else {
261 putrle(cnt, lastc);
262 lastc = c;
263 cnt = 1;
264 }
265 }
266 putrle(cnt, lastc);
267 if (ferror(stdout))
268 quiterr("error writing PostScript file");
269 }
270 putchar('\n');
271 /* free scanline */
272 free((char *)scanin);
273 }
274
275
276 putrle(cnt, cod) /* put out cnt of cod */
277 register int cnt, cod;
278 {
279 static int col = 0;
280
281 if (cnt >= MINRUN) {
282 col += 3;
283 putchar(RUNCHR);
284 putchar(RSTRT-MINRUN+cnt);
285 putchar(cod);
286 } else {
287 col += cnt;
288 while (cnt-- > 0)
289 putchar(cod);
290 }
291 if (col >= 72) {
292 putchar('\n');
293 col = 0;
294 }
295 }
