--- ray/src/px/ra_ps.c 2004/01/02 12:47:01 2.27 +++ ray/src/px/ra_ps.c 2018/08/02 18:33:47 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ra_ps.c,v 2.27 2004/01/02 12:47:01 schorsch Exp $"; +static const char RCSid[] = "$Id: ra_ps.c,v 2.30 2018/08/02 18:33:47 greg Exp $"; #endif /* * Radiance picture to PostScript file translator -- one way! @@ -11,6 +11,7 @@ static const char RCSid[] = "$Id: ra_ps.c,v 2.27 2004/ #include #include "platform.h" +#include "rtio.h" #include "color.h" #include "resolu.h" @@ -51,26 +52,35 @@ int docolor = 1; /* produce color image? */ int bradj = 0; /* brightness adjustment */ int ncopies = 1; /* number of copies */ -extern int Aputprim(), Bputprim(), Cputprim(); - -int (*putprim)() = Aputprim; /* function for writing scanline */ - char *progname; - int xmax, ymax; /* input image dimensions */ -extern double unit2inch(); +typedef void putprimf_t(COLR *scn, int pri); static gethfunc headline; +static putprimf_t Aputprim, Bputprim, Cputprim; +static double unit2inch(register char *s); +static int matchid(char *name, char *id); +static void parsepaper(char *ps); +static void quiterr(char *err); +static void PSheader(int ac, char **av); +static void PStrailer(void); +static void PSprocdef(char *nam); +static void ra2ps(void); +static void putrle(int cnt, int cod); + +putprimf_t *putprim = Aputprim; /* function for writing scanline */ + + static int headline( /* check header line */ char *s, void *p ) { - char fmt[32]; + char fmt[MAXFMTLEN]; if (isformat(s)) { formatval(fmt, s); @@ -80,10 +90,8 @@ headline( /* check header line */ return(0); } - -main(argc, argv) -int argc; -char *argv[]; +int +main(int argc, char *argv[]) { int i; double d; @@ -188,9 +196,10 @@ userr: } -double -unit2inch(s) /* determine unit */ -register char *s; +static double +unit2inch( /* determine unit */ + register char *s +) { static struct unit {char n; float f;} u[] = { {'i', 1.}, @@ -208,10 +217,11 @@ register char *s; } -int -matchid(name, id) /* see if name matches id (case insensitive) */ -char *name; -register char *id; +static int +matchid( /* see if name matches id (case insensitive) */ + char *name, + register char *id +) { register char *s = name; @@ -227,8 +237,10 @@ register char *id; } -parsepaper(ps) /* determine paper size from name */ -char *ps; +static void +parsepaper( /* determine paper size from name */ + char *ps +) { static struct psize {char n[12]; float w,h;} p[] = { {"envelope", 4.12, 9.5}, @@ -282,8 +294,10 @@ char *ps; } -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { if (err != NULL) { fprintf(stderr, "%s: %s\n", progname, err); @@ -293,9 +307,11 @@ char *err; } -PSheader(ac, av) /* print PostScript header */ -int ac; -char **av; +static void +PSheader( /* print PostScript header */ + int ac, + char **av +) { char *rstr; int landscape, rotate, n; @@ -392,7 +408,8 @@ char **av; } -PStrailer() /* print PostScript trailer */ +static void +PStrailer(void) /* print PostScript trailer */ { puts("%%Trailer"); if (ncopies > 1) @@ -404,8 +421,10 @@ PStrailer() /* print PostScript trailer */ } -PSprocdef(nam) /* define PS procedure to read image */ -char *nam; +static void +PSprocdef( /* define PS procedure to read image */ + char *nam +) { short itab[128]; register int i; @@ -413,9 +432,9 @@ char *nam; for (i = 0; i < 128; i++) /* clear */ itab[i] = -1; for (i = 1; i < 63; i++) /* assign greys */ - itab[code[i]] = 256.0*pow((i+.5)/64.0, CODE6GAM/devgam); - itab[code[0]] = 0; /* black is black */ - itab[code[63]] = 255; /* and white is white */ + itab[(int)code[i]] = 256.0*pow((i+.5)/64.0, CODE6GAM/devgam); + itab[(int)code[0]] = 0; /* black is black */ + itab[(int)code[63]] = 255; /* and white is white */ printf("/codetab ["); for (i = 0; i < 128; i++) { if (!(i & 0xf)) @@ -444,7 +463,8 @@ char *nam; } -ra2ps() /* convert Radiance scanlines to 6-bit */ +static void +ra2ps(void) /* convert Radiance scanlines to 6-bit */ { register COLR *scanin; int y; @@ -477,10 +497,11 @@ ra2ps() /* convert Radiance scanlines to 6-bit */ } -int -Aputprim(scn, pri) /* put out hex ASCII primary from scanline */ -COLR *scn; -int pri; +static void +Aputprim( /* put out hex ASCII primary from scanline */ + COLR *scn, + int pri +) { static char hexdigit[] = "0123456789ABCDEF"; static int col = 0; @@ -502,10 +523,11 @@ int pri; } -int -Bputprim(scn, pri) /* put out binary primary from scanline */ -COLR *scn; -int pri; +static void +Bputprim( /* put out binary primary from scanline */ + COLR *scn, + int pri +) { register int x, c; @@ -520,10 +542,11 @@ int pri; } -int -Cputprim(scn, pri) /* put out compressed primary from scanline */ -COLR *scn; -int pri; +static void +Cputprim( /* put out compressed primary from scanline */ + COLR *scn, + int pri +) { register int c; register int x; @@ -549,8 +572,11 @@ int pri; } -putrle(cnt, cod) /* put out cnt of cod */ -register int cnt, cod; +static void +putrle( /* put out cnt of cod */ + register int cnt, + register int cod +) { static int col = 0;
