--- ray/src/px/ra_ps.c 1997/09/26 14:20:38 2.20 +++ ray/src/px/ra_ps.c 1998/08/28 10:03:46 2.21 @@ -19,7 +19,8 @@ static char SCCSid[] = "$SunId$ SGI"; #define UPPER(c) ((c)&~0x20) /* ASCII trick */ #define CODE6GAM 1.47 /* gamma for 6-bit codes */ -#define DEFDGAM 1.0 /* default device gamma */ +#define DEFGGAM 1.0 /* greyscale device gamma */ +#define DEFCGAM 1.8 /* color device gamma */ #define GRY -1 /* artificial index for grey */ @@ -42,13 +43,13 @@ char code[] = /* 6-bit code lookup table */ int wrongformat = 0; /* input in wrong format? */ double pixaspect = 1.0; /* pixel aspect ratio */ -double devgam = DEFDGAM; /* device gamma response */ +double devgam = 0.; /* device gamma response */ double hmarg = DEFMARG, vmarg = DEFMARG; /* horizontal and vertical margins */ double width = DEFWIDTH, height = DEFHEIGHT; /* default paper width and height */ double dpi = 0; /* print density (0 if unknown) */ -int docolor = 0; /* produce color image? */ +int docolor = 1; /* produce color image? */ int bradj = 0; /* brightness adjustment */ int ncopies = 1; /* number of copies */ @@ -165,12 +166,14 @@ char *argv[]; if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0) quiterr("bad picture format"); /* gamma compression */ + if (devgam <= 0.05) + devgam = docolor ? DEFCGAM : DEFGGAM; if (putprim == Cputprim) setcolrgam(CODE6GAM); else if (devgam != 1.) setcolrgam(devgam); /* write header */ - PSheader(i <= argc-1 ? argv[i] : ""); + PSheader(argc, argv); /* convert file */ ra2ps(); /* write trailer */ @@ -289,8 +292,9 @@ char *err; } -PSheader(name) /* print PostScript header */ -char *name; +PSheader(ac, av) /* print PostScript header */ +int ac; +char **av; { char *rstr; int landscape, rotate, n; @@ -298,8 +302,8 @@ char *name; double iwidth, iheight; /* EPS comments */ puts("%!PS-Adobe-2.0 EPSF-2.0"); - printf("%%%%Title: %s\n", name); - printf("%%%%Creator: %s = %s\n", progname, SCCSid); + printf("%%%%Title: "); printargs(ac, av, stdout); + printf("%%%%Creator: %s\n", SCCSid); printf("%%%%Pages: %d\n", ncopies); if (landscape = xmax > pixaspect*ymax) puts("%%Orientation: Landscape");
