| 1 |
greg |
2.1 |
#ifndef lint
| 2 |
greg |
2.30 |
static const char RCSid[] = "$Id: ra_ps.c,v 2.29 2018/03/20 18:45:04 greg Exp $";
| 3 |
greg |
2.1 |
#endif
| 4 |
| 5 |
* Radiance picture to PostScript file translator -- one way!
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
schorsch |
2.27 |
#include <string.h>
| 10 |
greg |
2.13 |
#include <math.h>
| 11 |
gregl |
2.18 |
#include <ctype.h>
| 12 |
schorsch |
2.25 |
| 13 |
#include "platform.h"
| 14 |
greg |
2.29 |
#include "rtio.h"
| 15 |
greg |
2.1 |
#include "color.h"
| 16 |
schorsch |
2.27 |
#include "resolu.h"
| 17 |
greg |
2.1 |
| 18 |
gregl |
2.18 |
#define UPPER(c) ((c)&~0x20) /* ASCII trick */
| 19 |
| 20 |
gregl |
2.17 |
#define CODE6GAM 1.47 /* gamma for 6-bit codes */
| 21 |
gwlarson |
2.21 |
#define DEFGGAM 1.0 /* greyscale device gamma */
| 22 |
#define DEFCGAM 1.8 /* color device gamma */
| 23 |
greg |
2.13 |
| 24 |
greg |
2.11 |
#define GRY -1 /* artificial index for grey */
| 25 |
| 26 |
gregl |
2.18 |
#define DEFMARG 0.5 /* default margin (inches) */
| 27 |
#define DEFWIDTH 8.5 /* default page width */
| 28 |
#define DEFHEIGHT 11 /* default page height */
| 29 |
#define HMARGIN (hmarg*72) /* horizontal margin */
| 30 |
#define VMARGIN (vmarg*72) /* vertical margin */
| 31 |
#define PWIDTH (width*72-2*HMARGIN) /* width of device */
| 32 |
#define PHEIGHT (height*72-2*VMARGIN) /* height of device */
| 33 |
greg |
2.1 |
| 34 |
greg |
2.9 |
#define RUNCHR '*' /* character to start rle */
| 35 |
#define MINRUN 4 /* minimum run-length */
| 36 |
#define RSTRT '!' /* character for MINRUN */
| 37 |
#define MAXRUN (MINRUN+'~'-RSTRT) /* maximum run-length */
| 38 |
| 39 |
greg |
2.1 |
char code[] = /* 6-bit code lookup table */
| 40 |
"0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+";
| 41 |
| 42 |
int wrongformat = 0; /* input in wrong format? */
| 43 |
greg |
2.6 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 44 |
greg |
2.1 |
| 45 |
gwlarson |
2.21 |
double devgam = 0.; /* device gamma response */
| 46 |
gregl |
2.18 |
double hmarg = DEFMARG,
| 47 |
vmarg = DEFMARG; /* horizontal and vertical margins */
| 48 |
double width = DEFWIDTH,
| 49 |
height = DEFHEIGHT; /* default paper width and height */
| 50 |
gregl |
2.20 |
double dpi = 0; /* print density (0 if unknown) */
| 51 |
gwlarson |
2.21 |
int docolor = 1; /* produce color image? */
| 52 |
greg |
2.1 |
int bradj = 0; /* brightness adjustment */
| 53 |
greg |
2.4 |
int ncopies = 1; /* number of copies */
| 54 |
greg |
2.1 |
| 55 |
schorsch |
2.28 |
char *progname;
| 56 |
int xmax, ymax; /* input image dimensions */
| 57 |
greg |
2.15 |
| 58 |
schorsch |
2.28 |
typedef void putprimf_t(COLR *scn, int pri);
| 59 |
greg |
2.15 |
| 60 |
schorsch |
2.28 |
static gethfunc headline;
| 61 |
static putprimf_t Aputprim, Bputprim, Cputprim;
| 62 |
greg |
2.1 |
| 63 |
schorsch |
2.28 |
static double unit2inch(register char *s);
| 64 |
static int matchid(char *name, char *id);
| 65 |
static void parsepaper(char *ps);
| 66 |
static void quiterr(char *err);
| 67 |
static void PSheader(int ac, char **av);
| 68 |
static void PStrailer(void);
| 69 |
static void PSprocdef(char *nam);
| 70 |
static void ra2ps(void);
| 71 |
static void putrle(int cnt, int cod);
| 72 |
greg |
2.1 |
| 73 |
| 74 |
schorsch |
2.28 |
putprimf_t *putprim = Aputprim; /* function for writing scanline */
| 75 |
greg |
2.6 |
| 76 |
schorsch |
2.27 |
| 77 |
static int
| 78 |
headline( /* check header line */
| 79 |
char *s,
| 80 |
void *p
| 81 |
| 82 |
greg |
2.1 |
| 83 |
greg |
2.30 |
char fmt[MAXFMTLEN];
| 84 |
greg |
2.1 |
| 85 |
if (isformat(s)) {
| 86 |
formatval(fmt, s);
| 87 |
wrongformat = strcmp(fmt, COLRFMT);
| 88 |
} else if (isaspect(s))
| 89 |
pixaspect *= aspectval(s);
| 90 |
gwlarson |
2.22 |
return(0);
| 91 |
greg |
2.1 |
| 92 |
| 93 |
schorsch |
2.28 |
int
| 94 |
main(int argc, char *argv[])
| 95 |
greg |
2.1 |
| 96 |
int i;
| 97 |
gregl |
2.18 |
double d;
| 98 |
greg |
2.1 |
| 99 |
progname = argv[0];
| 100 |
| 101 |
for (i = 1; i < argc; i++)
| 102 |
if (argv[i][0] == '-')
| 103 |
switch (argv[i][1]) {
| 104 |
greg |
2.15 |
case 'b': /* produce b&w PostScript */
| 105 |
docolor = 0;
| 106 |
break;
| 107 |
greg |
2.11 |
case 'c': /* produce color PostScript */
| 108 |
greg |
2.15 |
docolor = 1;
| 109 |
greg |
2.11 |
break;
| 110 |
greg |
2.15 |
case 'A': /* standard ASCII encoding */
| 111 |
putprim = Aputprim;
| 112 |
break;
| 113 |
case 'B': /* standard binary encoding */
| 114 |
putprim = Bputprim;
| 115 |
break;
| 116 |
case 'C': /* compressed ASCII encoding */
| 117 |
putprim = Cputprim;
| 118 |
break;
| 119 |
gregl |
2.20 |
case 'd': /* print density */
| 120 |
dpi = atof(argv[++i]);
| 121 |
break;
| 122 |
gregl |
2.18 |
case 'g': /* device gamma adjustment */
| 123 |
gregl |
2.17 |
devgam = atof(argv[++i]);
| 124 |
break;
| 125 |
gregl |
2.18 |
case 'p': /* paper size */
| 126 |
parsepaper(argv[++i]);
| 127 |
break;
| 128 |
case 'm': /* margin */
| 129 |
d = atof(argv[i+1]);
| 130 |
d *= unit2inch(argv[i+1]);
| 131 |
switch (argv[i][2]) {
| 132 |
case '\0':
| 133 |
hmarg = vmarg = d;
| 134 |
break;
| 135 |
case 'h':
| 136 |
hmarg = d;
| 137 |
break;
| 138 |
case 'v':
| 139 |
vmarg = d;
| 140 |
break;
| 141 |
default:
| 142 |
goto userr;
| 143 |
| 144 |
i++;
| 145 |
break;
| 146 |
greg |
2.1 |
case 'e': /* exposure adjustment */
| 147 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
| 148 |
goto userr;
| 149 |
bradj = atoi(argv[++i]);
| 150 |
break;
| 151 |
greg |
2.4 |
case 'n': /* number of copies */
| 152 |
ncopies = atoi(argv[++i]);
| 153 |
break;
| 154 |
greg |
2.1 |
default:
| 155 |
goto userr;
| 156 |
| 157 |
else
| 158 |
break;
| 159 |
| 160 |
if (i < argc-2)
| 161 |
goto userr;
| 162 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
| 163 |
fprintf(stderr, "%s: can't open input \"%s\"\n",
| 164 |
progname, argv[i]);
| 165 |
exit(1);
| 166 |
| 167 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
| 168 |
greg |
2.7 |
fprintf(stderr, "%s: can't open output \"%s\"\n",
| 169 |
greg |
2.1 |
progname, argv[i+1]);
| 170 |
exit(1);
| 171 |
| 172 |
schorsch |
2.25 |
SET_FILE_BINARY(stdin);
| 173 |
greg |
2.1 |
/* get our header */
| 174 |
getheader(stdin, headline, NULL);
| 175 |
if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0)
| 176 |
quiterr("bad picture format");
| 177 |
greg |
2.13 |
/* gamma compression */
| 178 |
gwlarson |
2.21 |
if (devgam <= 0.05)
| 179 |
devgam = docolor ? DEFCGAM : DEFGGAM;
| 180 |
greg |
2.15 |
if (putprim == Cputprim)
| 181 |
gregl |
2.19 |
setcolrgam(CODE6GAM);
| 182 |
gregl |
2.17 |
else if (devgam != 1.)
| 183 |
gregl |
2.19 |
setcolrgam(devgam);
| 184 |
greg |
2.1 |
/* write header */
| 185 |
gwlarson |
2.21 |
PSheader(argc, argv);
| 186 |
greg |
2.1 |
/* convert file */
| 187 |
ra2ps();
| 188 |
/* write trailer */
| 189 |
PStrailer();
| 190 |
exit(0);
| 191 |
userr:
| 192 |
gregl |
2.18 |
fprintf(stderr,
| 193 |
gregl |
2.20 |
"Usage: %s [-b|c][-A|B|C][-e +/-stops][-p paper][-m[h|v] margin][-d dpi][-g gamma] [input [output]]\n",
| 194 |
greg |
2.11 |
progname);
| 195 |
gregl |
2.18 |
exit(1);
| 196 |
| 197 |
| 198 |
| 199 |
schorsch |
2.28 |
static double
| 200 |
unit2inch( /* determine unit */
| 201 |
register char *s
| 202 |
| 203 |
gregl |
2.18 |
| 204 |
gwlarson |
2.23 |
static struct unit {char n; float f;} u[] = {
| 205 |
schorsch |
2.27 |
{'i', 1.},
| 206 |
{'m', 1./25.4},
| 207 |
{'c', 1./2.54},
| 208 |
{'\0',0} };
| 209 |
gregl |
2.18 |
register struct unit *up;
| 210 |
| 211 |
while (*s && !isalpha(*s))
| 212 |
s++;
| 213 |
for (up = u; up->n; up++)
| 214 |
if (up->n == *s)
| 215 |
return(up->f);
| 216 |
return(1.);
| 217 |
| 218 |
| 219 |
| 220 |
schorsch |
2.28 |
static int
| 221 |
matchid( /* see if name matches id (case insensitive) */
| 222 |
char *name,
| 223 |
register char *id
| 224 |
| 225 |
gregl |
2.18 |
| 226 |
register char *s = name;
| 227 |
| 228 |
while (*s) {
| 229 |
if (isalpha(*s)) {
| 230 |
if (!isalpha(*id) || UPPER(*s) != UPPER(*id))
| 231 |
return(0);
| 232 |
} else if (*s != *id)
| 233 |
return(0);
| 234 |
s++; id++;
| 235 |
| 236 |
return(!*id || s-name >= 3); /* substrings >= 3 chars OK */
| 237 |
| 238 |
| 239 |
| 240 |
schorsch |
2.28 |
static void
| 241 |
parsepaper( /* determine paper size from name */
| 242 |
char *ps
| 243 |
| 244 |
gregl |
2.18 |
| 245 |
static struct psize {char n[12]; float w,h;} p[] = {
| 246 |
schorsch |
2.27 |
{"envelope", 4.12, 9.5},
| 247 |
{"executive", 7.25, 10.5},
| 248 |
{"letter", 8.5, 11.},
| 249 |
{"lettersmall", 7.68, 10.16},
| 250 |
{"legal", 8.5, 14.},
| 251 |
{"monarch", 3.87, 7.5},
| 252 |
{"statement", 5.5, 8.5},
| 253 |
{"tabloid", 11., 17.},
| 254 |
{"A3", 11.69, 16.54},
| 255 |
{"A4", 8.27, 11.69},
| 256 |
{"A4small", 7.47, 10.85},
| 257 |
{"A5", 6.00, 8.27},
| 258 |
{"A6", 4.13, 6.00},
| 259 |
{"B4", 10.12, 14.33},
| 260 |
{"B5", 7.17, 10.12},
| 261 |
{"C5", 6.38, 9.01},
| 262 |
{"C6", 4.49, 6.38},
| 263 |
{"DL", 4.33, 8.66},
| 264 |
{"hagaki", 3.94, 5.83},
| 265 |
{"",0.0,0.0} };
| 266 |
gregl |
2.18 |
register struct psize *pp;
| 267 |
register char *s = ps;
| 268 |
double d;
| 269 |
| 270 |
if (isdigit(*s)) { /* check for WWxHH specification */
| 271 |
width = atof(s);
| 272 |
| 273 |
s++;
| 274 |
d = unit2inch(s);
| 275 |
height = atof(++s);
| 276 |
width *= d;
| 277 |
height *= d;
| 278 |
schorsch |
2.26 |
if ((width >= 1.) & (height >= 1.))
| 279 |
gregl |
2.18 |
return;
| 280 |
} else /* check for match to standard size */
| 281 |
for (pp = p; pp->n[0]; pp++)
| 282 |
if (matchid(s, pp->n)) {
| 283 |
width = pp->w;
| 284 |
height = pp->h;
| 285 |
return;
| 286 |
| 287 |
fprintf(stderr, "%s: unknown paper size \"%s\" -- known sizes:\n",
| 288 |
progname, ps);
| 289 |
fprintf(stderr, "_Name________Width_Height_(inches)\n");
| 290 |
| 291 |
fprintf(stderr, "%-11s %5.2f %5.2f\n", pp->n, pp->w, pp->h);
| 292 |
gregl |
2.19 |
fprintf(stderr, "Or use WWxHH size specification\n");
| 293 |
greg |
2.1 |
exit(1);
| 294 |
| 295 |
| 296 |
| 297 |
schorsch |
2.28 |
static void
| 298 |
quiterr( /* print message and exit */
| 299 |
char *err
| 300 |
| 301 |
greg |
2.1 |
| 302 |
if (err != NULL) {
| 303 |
fprintf(stderr, "%s: %s\n", progname, err);
| 304 |
exit(1);
| 305 |
| 306 |
exit(0);
| 307 |
| 308 |
| 309 |
| 310 |
schorsch |
2.28 |
static void
| 311 |
PSheader( /* print PostScript header */
| 312 |
int ac,
| 313 |
char **av
| 314 |
| 315 |
greg |
2.1 |
| 316 |
greg |
2.15 |
char *rstr;
| 317 |
gregl |
2.20 |
int landscape, rotate, n;
| 318 |
greg |
2.6 |
double pwidth, pheight;
| 319 |
double iwidth, iheight;
| 320 |
greg |
2.10 |
/* EPS comments */
| 321 |
greg |
2.11 |
puts("%!PS-Adobe-2.0 EPSF-2.0");
| 322 |
gwlarson |
2.21 |
printf("%%%%Title: "); printargs(ac, av, stdout);
| 323 |
greg |
2.24 |
printf("%%%%Creator: %s\n", progname);
| 324 |
greg |
2.4 |
printf("%%%%Pages: %d\n", ncopies);
| 325 |
schorsch |
2.26 |
if ( (landscape = xmax > pixaspect*ymax) )
| 326 |
greg |
2.10 |
puts("%%Orientation: Landscape");
| 327 |
greg |
2.1 |
else
| 328 |
greg |
2.10 |
puts("%%Orientation: Portrait");
| 329 |
schorsch |
2.26 |
if ( (rotate = (PWIDTH > PHEIGHT) ^ landscape) ) {
| 330 |
greg |
2.1 |
pwidth = PHEIGHT;
| 331 |
pheight = PWIDTH;
| 332 |
} else {
| 333 |
pwidth = PWIDTH;
| 334 |
pheight = PHEIGHT;
| 335 |
| 336 |
schorsch |
2.26 |
if (dpi > 100 && (pixaspect >= 0.99) & (pixaspect <= 1.01))
| 337 |
gregl |
2.20 |
if (pheight/pwidth > ymax/xmax) {
| 338 |
n = pwidth*dpi/xmax; /* floor */
| 339 |
iwidth = n > 0 ? (double)(n*xmax)/dpi : pwidth;
| 340 |
iheight = iwidth*ymax/xmax;
| 341 |
} else {
| 342 |
n = pheight*dpi/ymax; /* floor */
| 343 |
iheight = n > 0 ? (double)(n*ymax)/dpi : pheight;
| 344 |
iwidth = iheight*xmax/ymax;
| 345 |
| 346 |
else
| 347 |
if (pheight/pwidth > pixaspect*ymax/xmax) {
| 348 |
iwidth = pwidth;
| 349 |
iheight = iwidth*pixaspect*ymax/xmax;
| 350 |
} else {
| 351 |
iheight = pheight;
| 352 |
iwidth = iheight*xmax/(pixaspect*ymax);
| 353 |
| 354 |
if (rotate)
| 355 |
greg |
2.10 |
printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
| 356 |
HMARGIN+(pheight-iheight)*.5,
| 357 |
VMARGIN+(pwidth-iwidth)*.5,
| 358 |
HMARGIN+(pheight-iheight)*.5+iheight,
| 359 |
VMARGIN+(pwidth-iwidth)*.5+iwidth);
| 360 |
else
| 361 |
| 362 |
HMARGIN+(pwidth-iwidth)*.5,
| 363 |
VMARGIN+(pheight-iheight)*.5,
| 364 |
HMARGIN+(pwidth-iwidth)*.5+iwidth,
| 365 |
VMARGIN+(pheight-iheight)*.5+iheight);
| 366 |
puts("%%EndComments");
| 367 |
greg |
2.13 |
puts("gsave save");
| 368 |
greg |
2.15 |
puts("17 dict begin");
| 369 |
greg |
2.10 |
/* define image reader */
| 370 |
greg |
2.11 |
if (docolor) {
| 371 |
printf("/redline %d string def\n", xmax);
| 372 |
printf("/grnline %d string def\n", xmax);
| 373 |
printf("/bluline %d string def\n", xmax);
| 374 |
greg |
2.15 |
} else
| 375 |
printf("/gryline %d string def\n", xmax);
| 376 |
/* use compressed encoding? */
| 377 |
| 378 |
PSprocdef("read6bitRLE");
| 379 |
greg |
2.10 |
/* set up transformation matrix */
| 380 |
printf("%f %f translate\n", HMARGIN, VMARGIN);
| 381 |
gregl |
2.20 |
if (rotate) {
| 382 |
greg |
2.14 |
printf("%f 0 translate\n", PWIDTH);
| 383 |
puts("90 rotate");
| 384 |
greg |
2.10 |
| 385 |
greg |
2.2 |
printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5);
| 386 |
printf("%f %f scale\n", iwidth, iheight);
| 387 |
greg |
2.12 |
puts("%%EndProlog");
| 388 |
greg |
2.3 |
/* start image procedure */
| 389 |
greg |
2.15 |
printf("%d %d 8 [%d 0 0 %d 0 %d]\n", xmax, ymax, xmax, -ymax, ymax);
| 390 |
if (putprim == Cputprim) {
| 391 |
if (docolor) {
| 392 |
greg |
2.16 |
puts("{redline read6bitRLE}");
| 393 |
puts("{grnline read6bitRLE}");
| 394 |
puts("{bluline read6bitRLE}");
| 395 |
puts("true 3 colorimage");
| 396 |
greg |
2.15 |
} else
| 397 |
puts("{gryline read6bitRLE} image");
| 398 |
} else {
| 399 |
rstr = putprim==Aputprim ? "readhexstring" : "readstring";
| 400 |
if (docolor) {
| 401 |
printf("{currentfile redline %s pop}\n", rstr);
| 402 |
printf("{currentfile grnline %s pop}\n", rstr);
| 403 |
printf("{currentfile bluline %s pop}\n", rstr);
| 404 |
| 405 |
} else
| 406 |
printf("{currentfile gryline %s pop} image\n", rstr);
| 407 |
| 408 |
greg |
2.1 |
| 409 |
| 410 |
| 411 |
schorsch |
2.28 |
static void
| 412 |
PStrailer(void) /* print PostScript trailer */
| 413 |
greg |
2.1 |
| 414 |
puts("%%Trailer");
| 415 |
greg |
2.4 |
if (ncopies > 1)
| 416 |
printf("/#copies %d def\n", ncopies);
| 417 |
puts("showpage");
| 418 |
greg |
2.1 |
puts("end");
| 419 |
greg |
2.13 |
puts("restore grestore");
| 420 |
greg |
2.1 |
puts("%%EOF");
| 421 |
| 422 |
| 423 |
| 424 |
schorsch |
2.28 |
static void
| 425 |
PSprocdef( /* define PS procedure to read image */
| 426 |
char *nam
| 427 |
| 428 |
greg |
2.1 |
| 429 |
short itab[128];
| 430 |
register int i;
| 431 |
greg |
2.5 |
/* assign code values */
| 432 |
for (i = 0; i < 128; i++) /* clear */
| 433 |
greg |
2.1 |
itab[i] = -1;
| 434 |
greg |
2.5 |
for (i = 1; i < 63; i++) /* assign greys */
| 435 |
schorsch |
2.28 |
itab[(int)code[i]] = 256.0*pow((i+.5)/64.0, CODE6GAM/devgam);
| 436 |
itab[(int)code[0]] = 0; /* black is black */
| 437 |
itab[(int)code[63]] = 255; /* and white is white */
| 438 |
greg |
2.9 |
printf("/codetab [");
| 439 |
greg |
2.1 |
for (i = 0; i < 128; i++) {
| 440 |
if (!(i & 0xf))
| 441 |
putchar('\n');
| 442 |
printf(" %3d", itab[i]);
| 443 |
| 444 |
printf("\n] def\n");
| 445 |
greg |
2.9 |
printf("/nrept 0 def\n");
| 446 |
greg |
2.11 |
printf("/readbyte { currentfile read not {stop} if } bind def\n");
| 447 |
printf("/decode { codetab exch get } bind def\n");
| 448 |
printf("/%s {\t%% scanbuffer\n", nam);
| 449 |
printf("\t/scanline exch def\n");
| 450 |
greg |
2.1 |
printf("\t{ 0 1 %d { scanline exch\n", xmax-1);
| 451 |
greg |
2.9 |
printf("\t\tnrept 0 le\n");
| 452 |
printf("\t\t\t{ { readbyte dup %d eq\n", RUNCHR);
| 453 |
printf("\t\t\t\t\t{ pop /nrept readbyte %d sub def\n", RSTRT-MINRUN+1);
| 454 |
printf("\t\t\t\t\t\t/reptv readbyte decode def\n");
| 455 |
printf("\t\t\t\t\t\treptv exit }\n");
| 456 |
printf("\t\t\t\t\t{ decode dup 0 lt {pop} {exit} ifelse }\n");
| 457 |
printf("\t\t\t\tifelse } loop }\n");
| 458 |
printf("\t\t\t{ /nrept nrept 1 sub def reptv }\n");
| 459 |
printf("\t\tifelse put\n");
| 460 |
printf("\t\t} for\n");
| 461 |
printf("\t} stopped {pop pop 0 string} {scanline} ifelse\n");
| 462 |
greg |
2.8 |
printf("} bind def\n");
| 463 |
greg |
2.1 |
| 464 |
| 465 |
| 466 |
schorsch |
2.28 |
static void
| 467 |
ra2ps(void) /* convert Radiance scanlines to 6-bit */
| 468 |
greg |
2.1 |
| 469 |
greg |
2.9 |
register COLR *scanin;
| 470 |
greg |
2.1 |
int y;
| 471 |
/* allocate scanline */
| 472 |
scanin = (COLR *)malloc(xmax*sizeof(COLR));
| 473 |
if (scanin == NULL)
| 474 |
quiterr("out of memory in ra2ps");
| 475 |
/* convert image */
| 476 |
for (y = ymax-1; y >= 0; y--) {
| 477 |
if (freadcolrs(scanin, xmax, stdin) < 0)
| 478 |
quiterr("error reading Radiance picture");
| 479 |
gregl |
2.17 |
if (putprim == Cputprim || devgam != 1.) {
| 480 |
greg |
2.15 |
if (bradj) /* adjust exposure */
| 481 |
shiftcolrs(scanin, xmax, bradj);
| 482 |
colrs_gambs(scanin, xmax); /* gamma compression */
| 483 |
} else
| 484 |
normcolrs(scanin, xmax, bradj);
| 485 |
greg |
2.11 |
if (docolor) {
| 486 |
greg |
2.15 |
(*putprim)(scanin, RED);
| 487 |
(*putprim)(scanin, GRN);
| 488 |
(*putprim)(scanin, BLU);
| 489 |
greg |
2.11 |
} else
| 490 |
greg |
2.15 |
(*putprim)(scanin, GRY);
| 491 |
greg |
2.1 |
if (ferror(stdout))
| 492 |
quiterr("error writing PostScript file");
| 493 |
| 494 |
putchar('\n');
| 495 |
/* free scanline */
| 496 |
greg |
2.24 |
free((void *)scanin);
| 497 |
greg |
2.11 |
| 498 |
| 499 |
| 500 |
schorsch |
2.28 |
static void
| 501 |
Aputprim( /* put out hex ASCII primary from scanline */
| 502 |
COLR *scn,
| 503 |
int pri
| 504 |
| 505 |
greg |
2.15 |
| 506 |
static char hexdigit[] = "0123456789ABCDEF";
| 507 |
static int col = 0;
| 508 |
register int x, c;
| 509 |
| 510 |
for (x = 0; x < xmax; x++) {
| 511 |
if (pri == GRY)
| 512 |
c = normbright(scn[x]);
| 513 |
else
| 514 |
c = scn[x][pri];
| 515 |
if (c > 255) c = 255;
| 516 |
putchar(hexdigit[c>>4]);
| 517 |
putchar(hexdigit[c&0xf]);
| 518 |
if ((col += 2) >= 72) {
| 519 |
putchar('\n');
| 520 |
col = 0;
| 521 |
| 522 |
| 523 |
| 524 |
| 525 |
| 526 |
schorsch |
2.28 |
static void
| 527 |
Bputprim( /* put out binary primary from scanline */
| 528 |
COLR *scn,
| 529 |
int pri
| 530 |
| 531 |
greg |
2.15 |
| 532 |
register int x, c;
| 533 |
| 534 |
| 535 |
if (pri == GRY)
| 536 |
| 537 |
else
| 538 |
c = scn[x][pri];
| 539 |
| 540 |
putchar(c);
| 541 |
| 542 |
| 543 |
| 544 |
| 545 |
schorsch |
2.28 |
static void
| 546 |
Cputprim( /* put out compressed primary from scanline */
| 547 |
COLR *scn,
| 548 |
int pri
| 549 |
| 550 |
greg |
2.11 |
| 551 |
register int c;
| 552 |
register int x;
| 553 |
int lastc, cnt;
| 554 |
| 555 |
lastc = -1; cnt = 0;
| 556 |
| 557 |
if (pri == GRY)
| 558 |
c = normbright(scn[x]) + 2;
| 559 |
else
| 560 |
c = scn[x][pri] + 2;
| 561 |
| 562 |
c = code[c>>2];
| 563 |
if (c == lastc && cnt < MAXRUN)
| 564 |
cnt++;
| 565 |
else {
| 566 |
putrle(cnt, lastc);
| 567 |
lastc = c;
| 568 |
cnt = 1;
| 569 |
| 570 |
| 571 |
putrle(cnt, lastc);
| 572 |
greg |
2.9 |
| 573 |
| 574 |
| 575 |
schorsch |
2.28 |
static void
| 576 |
putrle( /* put out cnt of cod */
| 577 |
register int cnt,
| 578 |
register int cod
| 579 |
| 580 |
greg |
2.9 |
| 581 |
static int col = 0;
| 582 |
| 583 |
if (cnt >= MINRUN) {
| 584 |
col += 3;
| 585 |
putchar(RUNCHR);
| 586 |
putchar(RSTRT-MINRUN+cnt);
| 587 |
putchar(cod);
| 588 |
} else {
| 589 |
col += cnt;
| 590 |
while (cnt-- > 0)
| 591 |
putchar(cod);
| 592 |
| 593 |
if (col >= 72) {
| 594 |
putchar('\n');
| 595 |
col = 0;
| 596 |
| 597 |
greg |
2.1 |
