root/radiance/ray/src/px/ra_ps.c
Revision: 2.6
Committed: Mon Sep 21 12:15:08 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.5: +12 -4 lines
Changes for PC port
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Radiance picture to PostScript file translator -- one way!
9 */
10
11 #include <stdio.h>
12 #ifdef MSDOS
13 #include <fcntl.h>
14 #endif
15 #include "color.h"
16 #include "random.h"
17
18 #define HMARGIN (.5*72) /* horizontal margin */
19 #define VMARGIN (.5*72) /* vertical margin */
20 #define PWIDTH (8.5*72-2*HMARGIN) /* width of device */
21 #define PHEIGHT (11*72-2*VMARGIN) /* height of device */
22
23 char code[] = /* 6-bit code lookup table */
24 "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+";
25
26 int wrongformat = 0; /* input in wrong format? */
27 double pixaspect = 1.0; /* pixel aspect ratio */
28
29 int bradj = 0; /* brightness adjustment */
30 int ncopies = 1; /* number of copies */
31
32 char *progname;
33
34 int xmax, ymax;
35
36 extern char *malloc();
37
38
39 headline(s) /* check header line */
40 char *s;
41 {
42 char fmt[32];
43
44 if (isformat(s)) {
45 formatval(fmt, s);
46 wrongformat = strcmp(fmt, COLRFMT);
47 } else if (isaspect(s))
48 pixaspect *= aspectval(s);
49 }
50
51
52 main(argc, argv)
53 int argc;
54 char *argv[];
55 {
56 int i;
57
58 progname = argv[0];
59
60 for (i = 1; i < argc; i++)
61 if (argv[i][0] == '-')
62 switch (argv[i][1]) {
63 case 'e': /* exposure adjustment */
64 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
65 goto userr;
66 bradj = atoi(argv[++i]);
67 break;
68 case 'n': /* number of copies */
69 ncopies = atoi(argv[++i]);
70 break;
71 default:
72 goto userr;
73 }
74 else
75 break;
76
77 if (i < argc-2)
78 goto userr;
79 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
80 fprintf(stderr, "%s: can't open input \"%s\"\n",
81 progname, argv[i]);
82 exit(1);
83 }
84 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
85 fprintf(stderr, "can't open output \"%s\"\n",
86 progname, argv[i+1]);
87 exit(1);
88 }
89 #ifdef MSDOS
90 setmode(fileno(stdin), O_BINARY);
91 #endif
92 /* get our header */
93 getheader(stdin, headline, NULL);
94 if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0)
95 quiterr("bad picture format");
96 /* write header */
97 PSheader(i <= argc-1 ? argv[i] : "<stdin>");
98 /* convert file */
99 ra2ps();
100 /* write trailer */
101 PStrailer();
102 exit(0);
103 userr:
104 fprintf(stderr, "Usage: %s [-e +/-stops] [input [output]]\n", progname);
105 exit(1);
106 }
107
108
109 quiterr(err) /* print message and exit */
110 char *err;
111 {
112 if (err != NULL) {
113 fprintf(stderr, "%s: %s\n", progname, err);
114 exit(1);
115 }
116 exit(0);
117 }
118
119
120 PSheader(name) /* print PostScript header */
121 char *name;
122 {
123 int landscape = 0;
124 double pwidth, pheight;
125 double iwidth, iheight;
126
127 printf("%%!\n");
128 printf("%%%%Title: %s\n", name);
129 printf("%%%%Creator: %s\n", progname);
130 printf("%%%%Pages: %d\n", ncopies);
131 if (landscape = xmax > pixaspect*ymax)
132 printf("%%%%Landscape\n");
133 else
134 printf("%%%%Portrait\n");
135 printf("%%%%EndComments\n");
136 printf("64 dict begin\n");
137 /* define image reader */
138 PSprocdef("read6bit");
139 /* set up transformation matrix */
140 printf("%f %f translate\n", HMARGIN, VMARGIN);
141 if (PWIDTH > PHEIGHT ^ landscape) {
142 printf("0 %f translate\n", PHEIGHT);
143 printf("-90 rotate\n");
144 pwidth = PHEIGHT;
145 pheight = PWIDTH;
146 } else {
147 pwidth = PWIDTH;
148 pheight = PHEIGHT;
149 }
150 if (pheight/pwidth > pixaspect*ymax/xmax) {
151 iwidth = pwidth;
152 iheight = pwidth*pixaspect*ymax/xmax;
153 } else {
154 iheight = pheight;
155 iwidth = pheight*xmax/(pixaspect*ymax);
156 }
157 printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5);
158 printf("%f %f scale\n", iwidth, iheight);
159 printf("%%%%EndProlog\n");
160 /* start image procedure */
161 printf("%d %d 8 [%d 0 0 %d 0 %d] {read6bit} image", xmax, ymax,
162 xmax, -ymax, ymax);
163 }
164
165
166 PStrailer() /* print PostScript trailer */
167 {
168 puts("%%Trailer");
169 if (ncopies > 1)
170 printf("/#copies %d def\n", ncopies);
171 puts("showpage");
172 puts("end");
173 puts("%%EOF");
174 }
175
176
177 PSprocdef(nam) /* define PS procedure to read image */
178 char *nam;
179 {
180 short itab[128];
181 register int i;
182 /* assign code values */
183 for (i = 0; i < 128; i++) /* clear */
184 itab[i] = -1;
185 for (i = 1; i < 63; i++) /* assign greys */
186 itab[code[i]] = i<<2 | 2;
187 itab[code[0]] = 0; /* black is black */
188 itab[code[63]] = 255; /* and white is white */
189 printf("/decode [");
190 for (i = 0; i < 128; i++) {
191 if (!(i & 0xf))
192 putchar('\n');
193 printf(" %3d", itab[i]);
194 }
195 printf("\n] def\n");
196 printf("/scanline %d string def\n", xmax);
197 printf("/%s {\n", nam);
198 printf("\t{ 0 1 %d { scanline exch\n", xmax-1);
199 printf("\t\t{ decode currentfile read not {stop} if get\n");
200 printf("\tdup 0 lt {pop} {exit} ifelse } loop put } for\n");
201 printf("} stopped {pop pop pop 0 string} {scanline} ifelse } def\n");
202 }
203
204
205 ra2ps() /* convert Radiance scanlines to 6-bit */
206 {
207 COLR *scanin;
208 register int col = 0;
209 register int c;
210 register int x;
211 int y;
212 /* allocate scanline */
213 scanin = (COLR *)malloc(xmax*sizeof(COLR));
214 if (scanin == NULL)
215 quiterr("out of memory in ra2ps");
216 /* convert image */
217 for (y = ymax-1; y >= 0; y--) {
218 if (freadcolrs(scanin, xmax, stdin) < 0)
219 quiterr("error reading Radiance picture");
220 normcolrs(scanin, xmax, bradj); /* normalize */
221 for (x = 0; x < xmax; x++) {
222 if (!(col++ & 0x3f))
223 putchar('\n');
224 c = normbright(scanin[x]) + (random()&3);
225 if (c > 255) c = 255;
226 putchar(code[c>>2]);
227 }
228 if (ferror(stdout))
229 quiterr("error writing PostScript file");
230 }
231 putchar('\n');
232 /* free scanline */
233 free((char *)scanin);
234 }
