root/radiance/ray/src/px/ra_ps.c
Changes since 2.27: +71 -46 lines
Diff to previous 2.27 , to selected 2.11
Fri Jan 2 12:47:01 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.26: +34 -28 lines
Diff to previous 2.26 , to selected 2.11
Changes since 2.25: +5 -5 lines
Diff to previous 2.25 , to selected 2.11
Changes since 2.24: +4 -7 lines
Diff to previous 2.24 , to selected 2.11
Changes since 2.23: +3 -7 lines
Diff to previous 2.23 , to selected 2.11
Mon Jul 19 09:53:06 1999 UTC (24 years, 10 months ago) by gwlarson
Diff to previous 2.22 , to selected 2.11
added missing semicolon to union declaration
Tue Oct 27 09:08:27 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to previous 2.21 , to selected 2.11
Fri Aug 28 10:03:46 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.20: +12 -8 lines
Diff to previous 2.20 , to selected 2.11
made different gamma defaults for color and greyscale
Fri Sep 26 14:20:38 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.19: +28 -13 lines
Diff to previous 2.19 , to selected 2.11
added -d option to match printer density to pixels
Tue Sep 23 16:52:23 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.18: +10 -6 lines
fixed gamma correction and added new pages sizes
Thu Sep 18 18:01:24 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.17: +130 -6 lines
added -m and -p options to specify paper size and margins
Thu Sep 18 15:16:23 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.16: +14 -7 lines
added gamma correction for non-linear PostScript devices
Fri Oct 6 12:38:38 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.15: +4 -2 lines
fixed problem with -c -C output
Thu Oct 5 09:53:47 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.14: +104 -44 lines
 added -A, -B and -C options for different output types
removed interleave procedure since it seems unnecessary for colorimage
Wed Oct 4 16:01:32 1995 UTC (28 years, 8 months ago) by greg
changed landscape orientation for ghostview
Wed Oct 4 12:30:58 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.12: +11 -4 lines
added gamma compression to reduce quantization errors
Thu Sep 28 16:34:30 1995 UTC (28 years, 8 months ago) by greg
minor comment fix
Thu Sep 28 11:23:42 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.10: +80 -28 lines
added -c option for color output
Wed Sep 27 13:29:52 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.9: +30 -14 lines
added appropriate comments and save/restore for EPS conformation
Thu Feb 10 21:59:53 1994 UTC (30 years, 3 months ago) by greg
Changes since 2.8: +57 -13 lines
added run-length compression
Thu Feb 10 15:40:12 1994 UTC (30 years, 3 months ago) by greg
added bind command to main PostScript procedure definition
Thu Nov 18 09:55:17 1993 UTC (30 years, 6 months ago) by greg
minor compiler warning fixes
Mon Sep 21 12:15:08 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.5: +12 -4 lines
Changes for PC port
Fri Aug 14 14:04:09 1992 UTC (31 years, 9 months ago) by greg
set black to black and white to white
Fri Aug 14 13:27:52 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.3: +8 -3 lines
added -n option for number of copies to print
Mon Jul 13 10:53:42 1992 UTC (31 years, 10 months ago) by greg
moved commands around a little
Mon Jul 13 09:53:14 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.1: +11 -18 lines
changed and fixed image transformation
Mon Jul 13 09:28:01 1992 UTC (31 years, 10 months ago) by greg
Diff to selected 2.11
