Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added missing semicolon to union declaration
made different gamma defaults for color and greyscale
added -d option to match printer density to pixels
fixed gamma correction and added new pages sizes
added -m and -p options to specify paper size and margins
added gamma correction for non-linear PostScript devices
fixed problem with -c -C output
added -A, -B and -C options for different output types removed interleave procedure since it seems unnecessary for colorimage
changed landscape orientation for ghostview
added gamma compression to reduce quantization errors
minor comment fix
added -c option for color output
added appropriate comments and save/restore for EPS conformation
added run-length compression
added bind command to main PostScript procedure definition
minor compiler warning fixes
Changes for PC port
set black to black and white to white
added -n option for number of copies to print
moved commands around a little
changed and fixed image transformation
