root/radiance/ray/src/px/ra_ps.c
Revision: 2.31
Committed: Sat Dec 28 18:05:14 2019 UTC (5 years, 6 months ago) by greg
Changes since 2.30: +1 -3 lines
2 static const char RCSid[] = "$Id: ra_ps.c,v 2.30 2018/08/02 18:33:47 greg Exp $";
5 * Radiance picture to PostScript file translator -- one way!
6 */
7
8 #include <math.h>
9 #include <ctype.h>
10
11 #include "platform.h"
12 #include "rtio.h"
13 #include "color.h"
14 #include "resolu.h"
15
16 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
17
18 #define CODE6GAM 1.47 /* gamma for 6-bit codes */
19 #define DEFGGAM 1.0 /* greyscale device gamma */
20 #define DEFCGAM 1.8 /* color device gamma */
21
22 #define GRY -1 /* artificial index for grey */
23
24 #define DEFMARG 0.5 /* default margin (inches) */
25 #define DEFWIDTH 8.5 /* default page width */
26 #define DEFHEIGHT 11 /* default page height */
27 #define HMARGIN (hmarg*72) /* horizontal margin */
28 #define VMARGIN (vmarg*72) /* vertical margin */
29 #define PWIDTH (width*72-2*HMARGIN) /* width of device */
30 #define PHEIGHT (height*72-2*VMARGIN) /* height of device */
31
32 #define RUNCHR '*' /* character to start rle */
33 #define MINRUN 4 /* minimum run-length */
34 #define RSTRT '!' /* character for MINRUN */
35 #define MAXRUN (MINRUN+'~'-RSTRT) /* maximum run-length */
36
37 char code[] = /* 6-bit code lookup table */
38 "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+";
39
40 int wrongformat = 0; /* input in wrong format? */
41 double pixaspect = 1.0; /* pixel aspect ratio */
42
43 double devgam = 0.; /* device gamma response */
44 double hmarg = DEFMARG,
45 vmarg = DEFMARG; /* horizontal and vertical margins */
46 double width = DEFWIDTH,
47 height = DEFHEIGHT; /* default paper width and height */
48 double dpi = 0; /* print density (0 if unknown) */
49 int docolor = 1; /* produce color image? */
50 int bradj = 0; /* brightness adjustment */
51 int ncopies = 1; /* number of copies */
52
53 char *progname;
54 int xmax, ymax; /* input image dimensions */
55
56 typedef void putprimf_t(COLR *scn, int pri);
57
58 static gethfunc headline;
59 static putprimf_t Aputprim, Bputprim, Cputprim;
60
61 static double unit2inch(register char *s);
62 static int matchid(char *name, char *id);
63 static void parsepaper(char *ps);
64 static void quiterr(char *err);
65 static void PSheader(int ac, char **av);
66 static void PStrailer(void);
67 static void PSprocdef(char *nam);
68 static void ra2ps(void);
69 static void putrle(int cnt, int cod);
70
71
72 putprimf_t *putprim = Aputprim; /* function for writing scanline */
73
74
75 static int
76 headline( /* check header line */
77 char *s,
78 void *p
79 )
80 {
81 char fmt[MAXFMTLEN];
82
83 if (isformat(s)) {
84 formatval(fmt, s);
85 wrongformat = strcmp(fmt, COLRFMT);
86 } else if (isaspect(s))
87 pixaspect *= aspectval(s);
88 return(0);
89 }
90
91 int
92 main(int argc, char *argv[])
93 {
94 int i;
95 double d;
96
97 progname = argv[0];
98
99 for (i = 1; i < argc; i++)
100 if (argv[i][0] == '-')
101 switch (argv[i][1]) {
102 case 'b': /* produce b&w PostScript */
103 docolor = 0;
104 break;
105 case 'c': /* produce color PostScript */
106 docolor = 1;
107 break;
108 case 'A': /* standard ASCII encoding */
109 putprim = Aputprim;
110 break;
111 case 'B': /* standard binary encoding */
112 putprim = Bputprim;
113 break;
114 case 'C': /* compressed ASCII encoding */
115 putprim = Cputprim;
116 break;
117 case 'd': /* print density */
118 dpi = atof(argv[++i]);
119 break;
120 case 'g': /* device gamma adjustment */
121 devgam = atof(argv[++i]);
122 break;
123 case 'p': /* paper size */
124 parsepaper(argv[++i]);
125 break;
126 case 'm': /* margin */
127 d = atof(argv[i+1]);
128 d *= unit2inch(argv[i+1]);
129 switch (argv[i][2]) {
130 case '\0':
131 hmarg = vmarg = d;
132 break;
133 case 'h':
134 hmarg = d;
135 break;
136 case 'v':
137 vmarg = d;
138 break;
139 default:
140 goto userr;
141 }
142 i++;
143 break;
144 case 'e': /* exposure adjustment */
145 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
146 goto userr;
147 bradj = atoi(argv[++i]);
148 break;
149 case 'n': /* number of copies */
150 ncopies = atoi(argv[++i]);
151 break;
152 default:
153 goto userr;
154 }
155 else
156 break;
157
158 if (i < argc-2)
159 goto userr;
160 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
161 fprintf(stderr, "%s: can't open input \"%s\"\n",
162 progname, argv[i]);
163 exit(1);
164 }
165 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
166 fprintf(stderr, "%s: can't open output \"%s\"\n",
167 progname, argv[i+1]);
168 exit(1);
169 }
170 SET_FILE_BINARY(stdin);
171 /* get our header */
172 getheader(stdin, headline, NULL);
173 if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0)
174 quiterr("bad picture format");
175 /* gamma compression */
176 if (devgam <= 0.05)
177 devgam = docolor ? DEFCGAM : DEFGGAM;
178 if (putprim == Cputprim)
179 setcolrgam(CODE6GAM);
180 else if (devgam != 1.)
181 setcolrgam(devgam);
182 /* write header */
183 PSheader(argc, argv);
184 /* convert file */
185 ra2ps();
186 /* write trailer */
187 PStrailer();
188 exit(0);
189 userr:
190 fprintf(stderr,
191 "Usage: %s [-b|c][-A|B|C][-e +/-stops][-p paper][-m[h|v] margin][-d dpi][-g gamma] [input [output]]\n",
192 progname);
193 exit(1);
194 }
195
196
197 static double
198 unit2inch( /* determine unit */
199 register char *s
200 )
201 {
202 static struct unit {char n; float f;} u[] = {
203 {'i', 1.},
204 {'m', 1./25.4},
205 {'c', 1./2.54},
206 {'\0',0} };
207 register struct unit *up;
208
209 while (*s && !isalpha(*s))
210 s++;
211 for (up = u; up->n; up++)
212 if (up->n == *s)
213 return(up->f);
214 return(1.);
215 }
216
217
218 static int
219 matchid( /* see if name matches id (case insensitive) */
220 char *name,
221 register char *id
222 )
223 {
224 register char *s = name;
225
226 while (*s) {
227 if (isalpha(*s)) {
228 if (!isalpha(*id) || UPPER(*s) != UPPER(*id))
229 return(0);
230 } else if (*s != *id)
231 return(0);
232 s++; id++;
233 }
234 return(!*id || s-name >= 3); /* substrings >= 3 chars OK */
235 }
236
237
238 static void
239 parsepaper( /* determine paper size from name */
240 char *ps
241 )
242 {
243 static struct psize {char n[12]; float w,h;} p[] = {
244 {"envelope", 4.12, 9.5},
245 {"executive", 7.25, 10.5},
246 {"letter", 8.5, 11.},
247 {"lettersmall", 7.68, 10.16},
248 {"legal", 8.5, 14.},
249 {"monarch", 3.87, 7.5},
250 {"statement", 5.5, 8.5},
251 {"tabloid", 11., 17.},
252 {"A3", 11.69, 16.54},
253 {"A4", 8.27, 11.69},
254 {"A4small", 7.47, 10.85},
255 {"A5", 6.00, 8.27},
256 {"A6", 4.13, 6.00},
257 {"B4", 10.12, 14.33},
258 {"B5", 7.17, 10.12},
259 {"C5", 6.38, 9.01},
260 {"C6", 4.49, 6.38},
261 {"DL", 4.33, 8.66},
262 {"hagaki", 3.94, 5.83},
263 {"",0.0,0.0} };
264 register struct psize *pp;
265 register char *s = ps;
266 double d;
267
268 if (isdigit(*s)) { /* check for WWxHH specification */
269 width = atof(s);
270 while (*s && !isalpha(*s))
271 s++;
272 d = unit2inch(s);
273 height = atof(++s);
274 width *= d;
275 height *= d;
276 if ((width >= 1.) & (height >= 1.))
277 return;
278 } else /* check for match to standard size */
279 for (pp = p; pp->n[0]; pp++)
280 if (matchid(s, pp->n)) {
281 width = pp->w;
282 height = pp->h;
283 return;
284 }
285 fprintf(stderr, "%s: unknown paper size \"%s\" -- known sizes:\n",
286 progname, ps);
287 fprintf(stderr, "_Name________Width_Height_(inches)\n");
288 for (pp = p; pp->n[0]; pp++)
289 fprintf(stderr, "%-11s %5.2f %5.2f\n", pp->n, pp->w, pp->h);
290 fprintf(stderr, "Or use WWxHH size specification\n");
291 exit(1);
292 }
293
294
295 static void
296 quiterr( /* print message and exit */
297 char *err
298 )
299 {
300 if (err != NULL) {
301 fprintf(stderr, "%s: %s\n", progname, err);
302 exit(1);
303 }
304 exit(0);
305 }
306
307
308 static void
309 PSheader( /* print PostScript header */
310 int ac,
311 char **av
312 )
313 {
314 char *rstr;
315 int landscape, rotate, n;
316 double pwidth, pheight;
317 double iwidth, iheight;
318 /* EPS comments */
319 puts("%!PS-Adobe-2.0 EPSF-2.0");
320 printf("%%%%Title: "); printargs(ac, av, stdout);
321 printf("%%%%Creator: %s\n", progname);
322 printf("%%%%Pages: %d\n", ncopies);
323 if ( (landscape = xmax > pixaspect*ymax) )
324 puts("%%Orientation: Landscape");
325 else
326 puts("%%Orientation: Portrait");
327 if ( (rotate = (PWIDTH > PHEIGHT) ^ landscape) ) {
328 pwidth = PHEIGHT;
329 pheight = PWIDTH;
330 } else {
331 pwidth = PWIDTH;
332 pheight = PHEIGHT;
333 }
334 if (dpi > 100 && (pixaspect >= 0.99) & (pixaspect <= 1.01))
335 if (pheight/pwidth > ymax/xmax) {
336 n = pwidth*dpi/xmax; /* floor */
337 iwidth = n > 0 ? (double)(n*xmax)/dpi : pwidth;
338 iheight = iwidth*ymax/xmax;
339 } else {
340 n = pheight*dpi/ymax; /* floor */
341 iheight = n > 0 ? (double)(n*ymax)/dpi : pheight;
342 iwidth = iheight*xmax/ymax;
343 }
344 else
345 if (pheight/pwidth > pixaspect*ymax/xmax) {
346 iwidth = pwidth;
347 iheight = iwidth*pixaspect*ymax/xmax;
348 } else {
349 iheight = pheight;
350 iwidth = iheight*xmax/(pixaspect*ymax);
351 }
352 if (rotate)
353 printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
354 HMARGIN+(pheight-iheight)*.5,
355 VMARGIN+(pwidth-iwidth)*.5,
356 HMARGIN+(pheight-iheight)*.5+iheight,
357 VMARGIN+(pwidth-iwidth)*.5+iwidth);
358 else
359 printf("%%%%BoundingBox: %.0f %.0f %.0f %.0f\n",
360 HMARGIN+(pwidth-iwidth)*.5,
361 VMARGIN+(pheight-iheight)*.5,
362 HMARGIN+(pwidth-iwidth)*.5+iwidth,
363 VMARGIN+(pheight-iheight)*.5+iheight);
364 puts("%%EndComments");
365 puts("gsave save");
366 puts("17 dict begin");
367 /* define image reader */
368 if (docolor) {
369 printf("/redline %d string def\n", xmax);
370 printf("/grnline %d string def\n", xmax);
371 printf("/bluline %d string def\n", xmax);
372 } else
373 printf("/gryline %d string def\n", xmax);
374 /* use compressed encoding? */
375 if (putprim == Cputprim)
376 PSprocdef("read6bitRLE");
377 /* set up transformation matrix */
378 printf("%f %f translate\n", HMARGIN, VMARGIN);
379 if (rotate) {
380 printf("%f 0 translate\n", PWIDTH);
381 puts("90 rotate");
382 }
383 printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5);
384 printf("%f %f scale\n", iwidth, iheight);
385 puts("%%EndProlog");
386 /* start image procedure */
387 printf("%d %d 8 [%d 0 0 %d 0 %d]\n", xmax, ymax, xmax, -ymax, ymax);
388 if (putprim == Cputprim) {
389 if (docolor) {
390 puts("{redline read6bitRLE}");
391 puts("{grnline read6bitRLE}");
392 puts("{bluline read6bitRLE}");
393 puts("true 3 colorimage");
394 } else
395 puts("{gryline read6bitRLE} image");
396 } else {
397 rstr = putprim==Aputprim ? "readhexstring" : "readstring";
398 if (docolor) {
399 printf("{currentfile redline %s pop}\n", rstr);
400 printf("{currentfile grnline %s pop}\n", rstr);
401 printf("{currentfile bluline %s pop}\n", rstr);
402 puts("true 3 colorimage");
403 } else
404 printf("{currentfile gryline %s pop} image\n", rstr);
405 }
406 }
407
408
409 static void
410 PStrailer(void) /* print PostScript trailer */
411 {
412 puts("%%Trailer");
413 if (ncopies > 1)
414 printf("/#copies %d def\n", ncopies);
415 puts("showpage");
416 puts("end");
417 puts("restore grestore");
418 puts("%%EOF");
419 }
420
421
422 static void
423 PSprocdef( /* define PS procedure to read image */
424 char *nam
425 )
426 {
427 short itab[128];
428 register int i;
429 /* assign code values */
430 for (i = 0; i < 128; i++) /* clear */
431 itab[i] = -1;
432 for (i = 1; i < 63; i++) /* assign greys */
433 itab[(int)code[i]] = 256.0*pow((i+.5)/64.0, CODE6GAM/devgam);
434 itab[(int)code[0]] = 0; /* black is black */
435 itab[(int)code[63]] = 255; /* and white is white */
436 printf("/codetab [");
437 for (i = 0; i < 128; i++) {
438 if (!(i & 0xf))
439 putchar('\n');
440 printf(" %3d", itab[i]);
441 }
442 printf("\n] def\n");
443 printf("/nrept 0 def\n");
444 printf("/readbyte { currentfile read not {stop} if } bind def\n");
445 printf("/decode { codetab exch get } bind def\n");
446 printf("/%s {\t%% scanbuffer\n", nam);
447 printf("\t/scanline exch def\n");
448 printf("\t{ 0 1 %d { scanline exch\n", xmax-1);
449 printf("\t\tnrept 0 le\n");
450 printf("\t\t\t{ { readbyte dup %d eq\n", RUNCHR);
451 printf("\t\t\t\t\t{ pop /nrept readbyte %d sub def\n", RSTRT-MINRUN+1);
452 printf("\t\t\t\t\t\t/reptv readbyte decode def\n");
453 printf("\t\t\t\t\t\treptv exit }\n");
454 printf("\t\t\t\t\t{ decode dup 0 lt {pop} {exit} ifelse }\n");
455 printf("\t\t\t\tifelse } loop }\n");
456 printf("\t\t\t{ /nrept nrept 1 sub def reptv }\n");
457 printf("\t\tifelse put\n");
458 printf("\t\t} for\n");
459 printf("\t} stopped {pop pop 0 string} {scanline} ifelse\n");
460 printf("} bind def\n");
461 }
462
463
464 static void
465 ra2ps(void) /* convert Radiance scanlines to 6-bit */
466 {
467 register COLR *scanin;
468 int y;
469 /* allocate scanline */
470 scanin = (COLR *)malloc(xmax*sizeof(COLR));
471 if (scanin == NULL)
472 quiterr("out of memory in ra2ps");
473 /* convert image */
474 for (y = ymax-1; y >= 0; y--) {
475 if (freadcolrs(scanin, xmax, stdin) < 0)
476 quiterr("error reading Radiance picture");
477 if (putprim == Cputprim || devgam != 1.) {
478 if (bradj) /* adjust exposure */
479 shiftcolrs(scanin, xmax, bradj);
480 colrs_gambs(scanin, xmax); /* gamma compression */
481 } else
482 normcolrs(scanin, xmax, bradj);
483 if (docolor) {
484 (*putprim)(scanin, RED);
485 (*putprim)(scanin, GRN);
486 (*putprim)(scanin, BLU);
487 } else
488 (*putprim)(scanin, GRY);
489 if (ferror(stdout))
490 quiterr("error writing PostScript file");
491 }
492 putchar('\n');
493 /* free scanline */
494 free((void *)scanin);
495 }
496
497
498 static void
499 Aputprim( /* put out hex ASCII primary from scanline */
500 COLR *scn,
501 int pri
502 )
503 {
504 static char hexdigit[] = "0123456789ABCDEF";
505 static int col = 0;
506 register int x, c;
507
508 for (x = 0; x < xmax; x++) {
509 if (pri == GRY)
510 c = normbright(scn[x]);
511 else
512 c = scn[x][pri];
513 if (c > 255) c = 255;
514 putchar(hexdigit[c>>4]);
515 putchar(hexdigit[c&0xf]);
516 if ((col += 2) >= 72) {
517 putchar('\n');
518 col = 0;
519 }
520 }
521 }
522
523
524 static void
525 Bputprim( /* put out binary primary from scanline */
526 COLR *scn,
527 int pri
528 )
529 {
530 register int x, c;
531
532 for (x = 0; x < xmax; x++) {
533 if (pri == GRY)
534 c = normbright(scn[x]);
535 else
536 c = scn[x][pri];
537 if (c > 255) c = 255;
538 putchar(c);
539 }
540 }
541
542
543 static void
544 Cputprim( /* put out compressed primary from scanline */
545 COLR *scn,
546 int pri
547 )
548 {
549 register int c;
550 register int x;
551 int lastc, cnt;
552
553 lastc = -1; cnt = 0;
554 for (x = 0; x < xmax; x++) {
555 if (pri == GRY)
556 c = normbright(scn[x]) + 2;
557 else
558 c = scn[x][pri] + 2;
559 if (c > 255) c = 255;
560 c = code[c>>2];
561 if (c == lastc && cnt < MAXRUN)
562 cnt++;
563 else {
564 putrle(cnt, lastc);
565 lastc = c;
566 cnt = 1;
567 }
568 }
569 putrle(cnt, lastc);
570 }
571
572
573 static void
574 putrle( /* put out cnt of cod */
575 register int cnt,
576 register int cod
577 )
578 {
579 static int col = 0;
580
581 if (cnt >= MINRUN) {
582 col += 3;
583 putchar(RUNCHR);
584 putchar(RSTRT-MINRUN+cnt);
585 putchar(cod);
586 } else {
587 col += cnt;
588 while (cnt-- > 0)
589 putchar(cod);
590 }
591 if (col >= 72) {
592 putchar('\n');
593 col = 0;
594 }
595 }
