root/radiance/ray/src/px/ra_ps.c
Revision: 2.5
Committed: Fri Aug 14 14:04:09 1992 UTC (32 years, 11 months ago) by greg
set black to black and white to white
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Radiance picture to PostScript file translator -- one way!
9 */
10
11 #include <stdio.h>
12 #include "color.h"
13 #include "random.h"
14
15 #define HMARGIN (.5*72) /* horizontal margin */
16 #define VMARGIN (.5*72) /* vertical margin */
17 #define PWIDTH (8.5*72-2*HMARGIN) /* width of device */
18 #define PHEIGHT (11*72-2*VMARGIN) /* height of device */
19
20 char code[] = /* 6-bit code lookup table */
21 "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ@+";
22
23 int wrongformat = 0; /* input in wrong format? */
24 double pixaspect = 1.0; /* pixel aspect ratio */
25
26 int bradj = 0; /* brightness adjustment */
27 int ncopies = 1; /* number of copies */
28
29 char *progname;
30
31 int xmax, ymax;
32
33
34 headline(s) /* check header line */
35 char *s;
36 {
37 char fmt[32];
38
39 if (isformat(s)) {
40 formatval(fmt, s);
41 wrongformat = strcmp(fmt, COLRFMT);
42 } else if (isaspect(s))
43 pixaspect *= aspectval(s);
44 }
45
46
47 main(argc, argv)
48 int argc;
49 char *argv[];
50 {
51 int i;
52
53 progname = argv[0];
54
55 for (i = 1; i < argc; i++)
56 if (argv[i][0] == '-')
57 switch (argv[i][1]) {
58 case 'e': /* exposure adjustment */
59 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
60 goto userr;
61 bradj = atoi(argv[++i]);
62 break;
63 case 'n': /* number of copies */
64 ncopies = atoi(argv[++i]);
65 break;
66 default:
67 goto userr;
68 }
69 else
70 break;
71
72 if (i < argc-2)
73 goto userr;
74 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
75 fprintf(stderr, "%s: can't open input \"%s\"\n",
76 progname, argv[i]);
77 exit(1);
78 }
79 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
80 fprintf(stderr, "can't open output \"%s\"\n",
81 progname, argv[i+1]);
82 exit(1);
83 }
84 /* get our header */
85 getheader(stdin, headline, NULL);
86 if (wrongformat || fgetresolu(&xmax, &ymax, stdin) < 0)
87 quiterr("bad picture format");
88 /* write header */
89 PSheader(i <= argc-1 ? argv[i] : "<stdin>");
90 /* convert file */
91 ra2ps();
92 /* write trailer */
93 PStrailer();
94 exit(0);
95 userr:
96 fprintf(stderr, "Usage: %s [-e +/-stops] [input [output]]\n", progname);
97 exit(1);
98 }
99
100
101 quiterr(err) /* print message and exit */
102 char *err;
103 {
104 if (err != NULL) {
105 fprintf(stderr, "%s: %s\n", progname, err);
106 exit(1);
107 }
108 exit(0);
109 }
110
111
112 PSheader(name) /* print PostScript header */
113 char *name;
114 {
115 int landscape = 0;
116 double pwidth, pheight;
117 double iwidth, iheight;
118
119 printf("%%!\n");
120 printf("%%%%Title: %s\n", name);
121 printf("%%%%Creator: %s\n", progname);
122 printf("%%%%Pages: %d\n", ncopies);
123 if (landscape = xmax > pixaspect*ymax)
124 printf("%%%%Landscape\n");
125 else
126 printf("%%%%Portrait\n");
127 printf("%%%%EndComments\n");
128 printf("64 dict begin\n");
129 /* define image reader */
130 PSprocdef("read6bit");
131 /* set up transformation matrix */
132 printf("%f %f translate\n", HMARGIN, VMARGIN);
133 if (PWIDTH > PHEIGHT ^ landscape) {
134 printf("0 %f translate\n", PHEIGHT);
135 printf("-90 rotate\n");
136 pwidth = PHEIGHT;
137 pheight = PWIDTH;
138 } else {
139 pwidth = PWIDTH;
140 pheight = PHEIGHT;
141 }
142 if (pheight/pwidth > pixaspect*ymax/xmax) {
143 iwidth = pwidth;
144 iheight = pwidth*pixaspect*ymax/xmax;
145 } else {
146 iheight = pheight;
147 iwidth = pheight*xmax/(pixaspect*ymax);
148 }
149 printf("%f %f translate\n", (pwidth-iwidth)*.5, (pheight-iheight)*.5);
150 printf("%f %f scale\n", iwidth, iheight);
151 printf("%%%%EndProlog\n");
152 /* start image procedure */
153 printf("%d %d 8 [%d 0 0 %d 0 %d] {read6bit} image", xmax, ymax,
154 xmax, -ymax, ymax);
155 }
156
157
158 PStrailer() /* print PostScript trailer */
159 {
160 puts("%%Trailer");
161 if (ncopies > 1)
162 printf("/#copies %d def\n", ncopies);
163 puts("showpage");
164 puts("end");
165 puts("%%EOF");
166 }
167
168
169 PSprocdef(nam) /* define PS procedure to read image */
170 char *nam;
171 {
172 short itab[128];
173 register int i;
174 /* assign code values */
175 for (i = 0; i < 128; i++) /* clear */
176 itab[i] = -1;
177 for (i = 1; i < 63; i++) /* assign greys */
178 itab[code[i]] = i<<2 | 2;
179 itab[code[0]] = 0; /* black is black */
180 itab[code[63]] = 255; /* and white is white */
181 printf("/decode [");
182 for (i = 0; i < 128; i++) {
183 if (!(i & 0xf))
184 putchar('\n');
185 printf(" %3d", itab[i]);
186 }
187 printf("\n] def\n");
188 printf("/scanline %d string def\n", xmax);
189 printf("/%s {\n", nam);
190 printf("\t{ 0 1 %d { scanline exch\n", xmax-1);
191 printf("\t\t{ decode currentfile read not {stop} if get\n");
192 printf("\tdup 0 lt {pop} {exit} ifelse } loop put } for\n");
193 printf("} stopped {pop pop pop 0 string} {scanline} ifelse } def\n");
194 }
195
196
197 ra2ps() /* convert Radiance scanlines to 6-bit */
198 {
199 COLR *scanin;
200 register int col = 0;
201 register int c;
202 register int x;
203 int y;
204 /* allocate scanline */
205 scanin = (COLR *)malloc(xmax*sizeof(COLR));
206 if (scanin == NULL)
207 quiterr("out of memory in ra2ps");
208 /* convert image */
209 for (y = ymax-1; y >= 0; y--) {
210 if (freadcolrs(scanin, xmax, stdin) < 0)
211 quiterr("error reading Radiance picture");
212 normcolrs(scanin, xmax, bradj); /* normalize */
213 for (x = 0; x < xmax; x++) {
214 if (!(col++ & 0x3f))
215 putchar('\n');
216 c = normbright(scanin[x]) + (random()&3);
217 if (c > 255) c = 255;
218 putchar(code[c>>2]);
219 }
220 if (ferror(stdout))
221 quiterr("error writing PostScript file");
222 }
223 putchar('\n');
224 /* free scanline */
225 free((char *)scanin);
226 }
