Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor compiler warning fixes
renamed gamma to gamcor to avoid conflict with math library
fixed scanline rounding to 16-bit boundaries
Changes for PC port
changed default gamma correction to 2.2
added -rgb option
fixed error message
added -e +/-stops option
added input compatibility with RT_FORMAT_RGB
corrected byte ordering (BGR not RGB!)
changed gamma correction to colrops calls
fixed bug in gamma table in ra2pr
