root/radiance/ray/src/px/ra_pr24.c
Revision: 2.10
Committed: Thu Jun 5 19:29:34 2003 UTC (21 years ago) by schorsch
Changes since 2.9: +5 -15 lines
2 static const char RCSid[] = "$Id: ra_pr24.c,v 2.9 2003/02/22 02:07:28 greg Exp $";
5 * program to convert between RADIANCE and 24-bit rasterfiles.
6 */
7
8 #include <stdio.h>
9 #include <time.h>
10 #include <math.h>
11
12 #include "platform.h"
13 #include "rasterfile.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 double gamcor = 2.2; /* gamma correction */
18
19 int bradj = 0; /* brightness adjustment */
20
21 char *progname;
22
23 int xmax, ymax;
24
25
26 main(argc, argv)
27 int argc;
28 char *argv[];
29 {
30 struct rasterfile head;
31 int reverse = 0;
32 int i;
33 SET_DEFAULT_BINARY();
34 SET_FILE_BINARY(stdin);
35 SET_FILE_BINARY(stdout);
36 progname = argv[0];
37
38 head.ras_type = RT_STANDARD;
39 for (i = 1; i < argc; i++)
40 if (argv[i][0] == '-')
41 switch (argv[i][1]) {
42 case 'g':
43 gamcor = atof(argv[++i]);
44 break;
45 case 'e':
46 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
47 goto userr;
48 bradj = atoi(argv[++i]);
49 break;
50 case 'r':
51 if (!strcmp(argv[i], "-rgb"))
52 head.ras_type = RT_FORMAT_RGB;
53 else
54 reverse = 1;
55 break;
56 default:
57 goto userr;
58 }
59 else
60 break;
61
62 if (i < argc-2)
63 goto userr;
64 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
65 fprintf(stderr, "%s: can't open input \"%s\"\n",
66 progname, argv[i]);
67 exit(1);
68 }
69 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
70 fprintf(stderr, "%s: can't open output \"%s\"\n",
71 progname, argv[i+1]);
72 exit(1);
73 }
74 setcolrgam(gamcor);
75 if (reverse) {
76 /* get header */
77 if (fread((char *)&head, sizeof(head), 1, stdin) != 1)
78 quiterr("missing header");
79 if (head.ras_magic != RAS_MAGIC)
80 quiterr("bad raster format");
81 xmax = head.ras_width;
82 ymax = head.ras_height;
83 if ((head.ras_type != RT_STANDARD
84 && head.ras_type != RT_FORMAT_RGB)
85 || head.ras_maptype != RMT_NONE
86 || head.ras_depth != 24)
87 quiterr("incompatible format");
88 /* put header */
89 newheader("RADIANCE", stdout);
90 printargs(i, argv, stdout);
91 fputformat(COLRFMT, stdout);
92 putchar('\n');
93 fprtresolu(xmax, ymax, stdout);
94 /* convert file */
95 pr2ra(head.ras_type, head.ras_length/ymax - xmax*3);
96 } else {
97 /* get header info. */
98 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
99 fgetresolu(&xmax, &ymax, stdin) < 0)
100 quiterr("bad picture format");
101 /* write rasterfile header */
102 head.ras_magic = RAS_MAGIC;
103 head.ras_width = xmax + (xmax&1);
104 head.ras_height = ymax;
105 head.ras_depth = 24;
106 head.ras_length = head.ras_width*head.ras_height*3;
107 head.ras_maptype = RMT_NONE;
108 head.ras_maplength = 0;
109 fwrite((char *)&head, sizeof(head), 1, stdout);
110 /* convert file */
111 ra2pr(head.ras_type, head.ras_length/ymax - xmax*3);
112 }
113 exit(0);
114 userr:
115 fprintf(stderr, "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
116 progname);
117 exit(1);
118 }
119
120
121 quiterr(err) /* print message and exit */
122 char *err;
123 {
124 if (err != NULL) {
125 fprintf(stderr, "%s: %s\n", progname, err);
126 exit(1);
127 }
128 exit(0);
129 }
130
131
132 pr2ra(rf, pad) /* convert 24-bit scanlines to Radiance picture */
133 int rf;
134 int pad;
135 {
136 COLR *scanout;
137 register int x;
138 int y;
139 /* allocate scanline */
140 scanout = (COLR *)malloc(xmax*sizeof(COLR));
141 if (scanout == NULL)
142 quiterr("out of memory in pr2ra");
143 /* convert image */
144 for (y = ymax-1; y >= 0; y--) {
145 if (rf == RT_FORMAT_RGB)
146 for (x = 0; x < xmax; x++) {
147 scanout[x][RED] = getc(stdin);
148 scanout[x][GRN] = getc(stdin);
149 scanout[x][BLU] = getc(stdin);
150 }
151 else
152 for (x = 0; x < xmax; x++) {
153 scanout[x][BLU] = getc(stdin);
154 scanout[x][GRN] = getc(stdin);
155 scanout[x][RED] = getc(stdin);
156 }
157 for (x = pad; x--; getc(stdin));
158 if (feof(stdin) || ferror(stdin))
159 quiterr("error reading rasterfile");
160 gambs_colrs(scanout, xmax);
161 if (bradj)
162 shiftcolrs(scanout, xmax, bradj);
163 if (fwritecolrs(scanout, xmax, stdout) < 0)
164 quiterr("error writing Radiance picture");
165 }
166 /* free scanline */
167 free((void *)scanout);
168 }
169
170
171 ra2pr(rf, pad) /* convert Radiance scanlines to 24-bit rasterfile */
172 int rf;
173 int pad;
174 {
175 int ord[3];
176 COLR *scanin;
177 register int x;
178 int y;
179 /* allocate scanline */
180 scanin = (COLR *)malloc(xmax*sizeof(COLR));
181 if (scanin == NULL)
182 quiterr("out of memory in ra2pr");
183 if (rf == RT_FORMAT_RGB) {
184 ord[0] = RED; ord[1] = GRN; ord[2] = BLU;
185 } else {
186 ord[0] = BLU; ord[1] = GRN; ord[2] = RED;
187 }
188 /* convert image */
189 for (y = ymax-1; y >= 0; y--) {
190 if (freadcolrs(scanin, xmax, stdin) < 0)
191 quiterr("error reading Radiance picture");
192 if (bradj)
193 shiftcolrs(scanin, xmax, bradj);
194 colrs_gambs(scanin, xmax);
195 if (rf == RT_FORMAT_RGB)
196 for (x = 0; x < xmax; x++) {
197 putc(scanin[x][RED], stdout);
198 putc(scanin[x][GRN], stdout);
199 putc(scanin[x][BLU], stdout);
200 }
201 else
202 for (x = 0; x < xmax; x++) {
203 putc(scanin[x][BLU], stdout);
204 putc(scanin[x][GRN], stdout);
205 putc(scanin[x][RED], stdout);
206 }
207 for (x = 0; x < pad; x++)
208 putc(scanin[xmax-1][ord[x%3]], stdout);
209 if (ferror(stdout))
210 quiterr("error writing rasterfile");
211 }
212 /* free scanline */
213 free((void *)scanin);
214 }
