--- ray/src/px/ra_pr24.c 1991/11/12 16:04:46 2.1 +++ ray/src/px/ra_pr24.c 1993/11/18 09:55:14 2.7 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -10,15 +10,21 @@ static char SCCSid[] = "$SunId$ LBL"; #include +#ifdef MSDOS +#include +#endif + +#include + #include "rasterfile.h" #include "color.h" #include "resolu.h" -extern double atof(), pow(); +extern char *malloc(); -double gamma = 2.2; /* gamma correction */ +double gamcor = 2.2; /* gamma correction */ int bradj = 0; /* brightness adjustment */ @@ -34,7 +40,12 @@ char *argv[]; struct rasterfile head; int reverse = 0; int i; - +#ifdef MSDOS + extern int _fmode; + _fmode = O_BINARY; + setmode(fileno(stdin), O_BINARY); + setmode(fileno(stdout), O_BINARY); +#endif progname = argv[0]; head.ras_type = RT_STANDARD; @@ -42,7 +53,7 @@ char *argv[]; if (argv[i][0] == '-') switch (argv[i][1]) { case 'g': - gamma = atof(argv[++i]); + gamcor = atof(argv[++i]); break; case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-') @@ -69,11 +80,11 @@ char *argv[]; exit(1); } if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { - fprintf(stderr, "can't open output \"%s\"\n", + fprintf(stderr, "%s: can't open output \"%s\"\n", progname, argv[i+1]); exit(1); } - setcolrgam(gamma); + setcolrgam(gamcor); if (reverse) { /* get header */ if (fread((char *)&head, sizeof(head), 1, stdin) != 1) @@ -93,7 +104,7 @@ char *argv[]; putchar('\n'); fprtresolu(xmax, ymax, stdout); /* convert file */ - pr2ra(head.ras_type); + pr2ra(head.ras_type, head.ras_length/ymax - xmax*3); } else { /* get header info. */ if (checkheader(stdin, COLRFMT, NULL) < 0 || @@ -101,15 +112,15 @@ char *argv[]; quiterr("bad picture format"); /* write rasterfile header */ head.ras_magic = RAS_MAGIC; - head.ras_width = xmax; + head.ras_width = xmax + (xmax&1); head.ras_height = ymax; head.ras_depth = 24; - head.ras_length = xmax*ymax*3; + head.ras_length = head.ras_width*head.ras_height*3; head.ras_maptype = RMT_NONE; head.ras_maplength = 0; fwrite((char *)&head, sizeof(head), 1, stdout); /* convert file */ - ra2pr(head.ras_type); + ra2pr(head.ras_type, head.ras_length/ymax - xmax*3); } exit(0); userr: @@ -130,8 +141,9 @@ char *err; } -pr2ra(rf) /* convert 24-bit scanlines to Radiance picture */ +pr2ra(rf, pad) /* convert 24-bit scanlines to Radiance picture */ int rf; +int pad; { COLR *scanout; register int x; @@ -154,6 +166,7 @@ int rf; scanout[x][GRN] = getc(stdin); scanout[x][RED] = getc(stdin); } + for (x = pad; x--; getc(stdin)); if (feof(stdin) || ferror(stdin)) quiterr("error reading rasterfile"); gambs_colrs(scanout, xmax); @@ -167,9 +180,11 @@ int rf; } -ra2pr(rf) /* convert Radiance scanlines to 24-bit rasterfile */ -int rf; +ra2pr(rf, pad) /* convert Radiance scanlines to 24-bit rasterfile */ +int rf; +int pad; { + int ord[3]; COLR *scanin; register int x; int y; @@ -177,6 +192,11 @@ int rf; scanin = (COLR *)malloc(xmax*sizeof(COLR)); if (scanin == NULL) quiterr("out of memory in ra2pr"); + if (rf == RT_FORMAT_RGB) { + ord[0] = RED; ord[1] = GRN; ord[2] = BLU; + } else { + ord[0] = BLU; ord[1] = GRN; ord[2] = RED; + } /* convert image */ for (y = ymax-1; y >= 0; y--) { if (freadcolrs(scanin, xmax, stdin) < 0) @@ -196,6 +216,8 @@ int rf; putc(scanin[x][GRN], stdout); putc(scanin[x][RED], stdout); } + for (x = 0; x < pad; x++) + putc(scanin[xmax-1][ord[x%3]], stdout); if (ferror(stdout)) quiterr("error writing rasterfile"); }
