--- ray/src/px/ra_pr24.c 1991/08/15 12:38:24 1.8 +++ ray/src/px/ra_pr24.c 2004/03/28 20:33:14 2.12 @@ -1,45 +1,47 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ra_pr24.c,v 2.12 2004/03/28 20:33:14 schorsch Exp $"; #endif - /* * program to convert between RADIANCE and 24-bit rasterfiles. */ #include +#include +#include +#include +#include "platform.h" #include "rasterfile.h" - #include "color.h" +#include "resolu.h" -extern double atof(), pow(); - -double gamma = 2.0; /* gamma correction */ - +double gamcor = 2.2; /* gamma correction */ int bradj = 0; /* brightness adjustment */ - char *progname; - int xmax, ymax; +static void quiterr(char *err); +static void pr2ra(int rf, int pad); +static void ra2pr(int rf, int pad); -main(argc, argv) -int argc; -char *argv[]; + +int +main(int argc, char *argv[]) { struct rasterfile head; int reverse = 0; int i; - + SET_DEFAULT_BINARY(); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); progname = argv[0]; + head.ras_type = RT_STANDARD; for (i = 1; i < argc; i++) if (argv[i][0] == '-') switch (argv[i][1]) { case 'g': - gamma = atof(argv[++i]); + gamcor = atof(argv[++i]); break; case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-') @@ -47,7 +49,10 @@ char *argv[]; bradj = atoi(argv[++i]); break; case 'r': - reverse = !reverse; + if (!strcmp(argv[i], "-rgb")) + head.ras_type = RT_FORMAT_RGB; + else + reverse = 1; break; default: goto userr; @@ -63,11 +68,11 @@ char *argv[]; exit(1); } if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { - fprintf(stderr, "can't open output \"%s\"\n", + fprintf(stderr, "%s: can't open output \"%s\"\n", progname, argv[i+1]); exit(1); } - setcolrgam(gamma); + setcolrgam(gamcor); if (reverse) { /* get header */ if (fread((char *)&head, sizeof(head), 1, stdin) != 1) @@ -82,29 +87,29 @@ char *argv[]; || head.ras_depth != 24) quiterr("incompatible format"); /* put header */ + newheader("RADIANCE", stdout); printargs(i, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); - fputresolu(YMAJOR|YDECR, xmax, ymax, stdout); + fprtresolu(xmax, ymax, stdout); /* convert file */ - pr2ra(head.ras_type); + pr2ra(head.ras_type, head.ras_length/ymax - xmax*3); } else { /* get header info. */ if (checkheader(stdin, COLRFMT, NULL) < 0 || - fgetresolu(&xmax, &ymax, stdin) != (YMAJOR|YDECR)) + fgetresolu(&xmax, &ymax, stdin) < 0) quiterr("bad picture format"); /* write rasterfile header */ head.ras_magic = RAS_MAGIC; - head.ras_width = xmax; + head.ras_width = xmax + (xmax&1); head.ras_height = ymax; head.ras_depth = 24; - head.ras_length = xmax*ymax*3; - head.ras_type = RT_STANDARD; + head.ras_length = head.ras_width*head.ras_height*3; head.ras_maptype = RMT_NONE; head.ras_maplength = 0; fwrite((char *)&head, sizeof(head), 1, stdout); /* convert file */ - ra2pr(); + ra2pr(head.ras_type, head.ras_length/ymax - xmax*3); } exit(0); userr: @@ -114,8 +119,10 @@ userr: } -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { if (err != NULL) { fprintf(stderr, "%s: %s\n", progname, err); @@ -125,8 +132,11 @@ char *err; } -pr2ra(rf) /* convert 24-bit scanlines to Radiance picture */ -int rf; +static void +pr2ra( /* convert 24-bit scanlines to Radiance picture */ + int rf, + int pad +) { COLR *scanout; register int x; @@ -137,16 +147,19 @@ int rf; quiterr("out of memory in pr2ra"); /* convert image */ for (y = ymax-1; y >= 0; y--) { - for (x = 0; x < xmax; x++) - if (rf == RT_FORMAT_RGB) { + if (rf == RT_FORMAT_RGB) + for (x = 0; x < xmax; x++) { scanout[x][RED] = getc(stdin); scanout[x][GRN] = getc(stdin); scanout[x][BLU] = getc(stdin); - } else { + } + else + for (x = 0; x < xmax; x++) { scanout[x][BLU] = getc(stdin); scanout[x][GRN] = getc(stdin); scanout[x][RED] = getc(stdin); } + for (x = pad; x--; getc(stdin)); if (feof(stdin) || ferror(stdin)) quiterr("error reading rasterfile"); gambs_colrs(scanout, xmax); @@ -156,12 +169,17 @@ int rf; quiterr("error writing Radiance picture"); } /* free scanline */ - free((char *)scanout); + free((void *)scanout); } -ra2pr() /* convert Radiance scanlines to 24-bit rasterfile */ +static void +ra2pr( /* convert Radiance scanlines to 24-bit rasterfile */ + int rf, + int pad +) { + int ord[3]; COLR *scanin; register int x; int y; @@ -169,6 +187,11 @@ ra2pr() /* convert Radiance scanlines to 24-bit rast scanin = (COLR *)malloc(xmax*sizeof(COLR)); if (scanin == NULL) quiterr("out of memory in ra2pr"); + if (rf == RT_FORMAT_RGB) { + ord[0] = RED; ord[1] = GRN; ord[2] = BLU; + } else { + ord[0] = BLU; ord[1] = GRN; ord[2] = RED; + } /* convert image */ for (y = ymax-1; y >= 0; y--) { if (freadcolrs(scanin, xmax, stdin) < 0) @@ -176,14 +199,23 @@ ra2pr() /* convert Radiance scanlines to 24-bit rast if (bradj) shiftcolrs(scanin, xmax, bradj); colrs_gambs(scanin, xmax); - for (x = 0; x < xmax; x++) { - putc(scanin[x][BLU], stdout); - putc(scanin[x][GRN], stdout); - putc(scanin[x][RED], stdout); - } + if (rf == RT_FORMAT_RGB) + for (x = 0; x < xmax; x++) { + putc(scanin[x][RED], stdout); + putc(scanin[x][GRN], stdout); + putc(scanin[x][BLU], stdout); + } + else + for (x = 0; x < xmax; x++) { + putc(scanin[x][BLU], stdout); + putc(scanin[x][GRN], stdout); + putc(scanin[x][RED], stdout); + } + for (x = 0; x < pad; x++) + putc(scanin[xmax-1][ord[x%3]], stdout); if (ferror(stdout)) quiterr("error writing rasterfile"); } /* free scanline */ - free((char *)scanin); + free((void *)scanin); }
