root/radiance/ray/src/px/ra_pr24.c
Revision: 2.5
Committed: Fri Oct 2 16:25:49 1992 UTC (31 years, 8 months ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * program to convert between RADIANCE and 24-bit rasterfiles.
9 */
10
11 #include <stdio.h>
12
13 #ifdef MSDOS
14 #include <fcntl.h>
15 #endif
16
17 #include <math.h>
18
19 #include "rasterfile.h"
20
21 #include "color.h"
22
23 #include "resolu.h"
24
25 extern char *malloc();
26
27 double gamma = 2.2; /* gamma correction */
28
29 int bradj = 0; /* brightness adjustment */
30
31 char *progname;
32
33 int xmax, ymax;
34
35
36 main(argc, argv)
37 int argc;
38 char *argv[];
39 {
40 struct rasterfile head;
41 int reverse = 0;
42 int i;
43 #ifdef MSDOS
44 extern int _fmode;
45 _fmode = O_BINARY;
46 setmode(fileno(stdin), O_BINARY);
47 setmode(fileno(stdout), O_BINARY);
48 #endif
49 progname = argv[0];
50
51 head.ras_type = RT_STANDARD;
52 for (i = 1; i < argc; i++)
53 if (argv[i][0] == '-')
54 switch (argv[i][1]) {
55 case 'g':
56 gamma = atof(argv[++i]);
57 break;
58 case 'e':
59 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
60 goto userr;
61 bradj = atoi(argv[++i]);
62 break;
63 case 'r':
64 if (!strcmp(argv[i], "-rgb"))
65 head.ras_type = RT_FORMAT_RGB;
66 else
67 reverse = 1;
68 break;
69 default:
70 goto userr;
71 }
72 else
73 break;
74
75 if (i < argc-2)
76 goto userr;
77 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
78 fprintf(stderr, "%s: can't open input \"%s\"\n",
79 progname, argv[i]);
80 exit(1);
81 }
82 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
83 fprintf(stderr, "can't open output \"%s\"\n",
84 progname, argv[i+1]);
85 exit(1);
86 }
87 setcolrgam(gamma);
88 if (reverse) {
89 /* get header */
90 if (fread((char *)&head, sizeof(head), 1, stdin) != 1)
91 quiterr("missing header");
92 if (head.ras_magic != RAS_MAGIC)
93 quiterr("bad raster format");
94 xmax = head.ras_width;
95 ymax = head.ras_height;
96 if ((head.ras_type != RT_STANDARD
97 && head.ras_type != RT_FORMAT_RGB)
98 || head.ras_maptype != RMT_NONE
99 || head.ras_depth != 24)
100 quiterr("incompatible format");
101 /* put header */
102 printargs(i, argv, stdout);
103 fputformat(COLRFMT, stdout);
104 putchar('\n');
105 fprtresolu(xmax, ymax, stdout);
106 /* convert file */
107 pr2ra(head.ras_type, head.ras_length/ymax - xmax*3);
108 } else {
109 /* get header info. */
110 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
111 fgetresolu(&xmax, &ymax, stdin) < 0)
112 quiterr("bad picture format");
113 /* write rasterfile header */
114 head.ras_magic = RAS_MAGIC;
115 head.ras_width = xmax + (xmax&1);
116 head.ras_height = ymax;
117 head.ras_depth = 24;
118 head.ras_length = head.ras_width*head.ras_height*3;
119 head.ras_maptype = RMT_NONE;
120 head.ras_maplength = 0;
121 fwrite((char *)&head, sizeof(head), 1, stdout);
122 /* convert file */
123 ra2pr(head.ras_type, head.ras_length/ymax - xmax*3);
124 }
125 exit(0);
126 userr:
127 fprintf(stderr, "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
128 progname);
129 exit(1);
130 }
131
132
133 quiterr(err) /* print message and exit */
134 char *err;
135 {
136 if (err != NULL) {
137 fprintf(stderr, "%s: %s\n", progname, err);
138 exit(1);
139 }
140 exit(0);
141 }
142
143
144 pr2ra(rf, pad) /* convert 24-bit scanlines to Radiance picture */
145 int rf;
146 int pad;
147 {
148 COLR *scanout;
149 register int x;
150 int y;
151 /* allocate scanline */
152 scanout = (COLR *)malloc(xmax*sizeof(COLR));
153 if (scanout == NULL)
154 quiterr("out of memory in pr2ra");
155 /* convert image */
156 for (y = ymax-1; y >= 0; y--) {
157 if (rf == RT_FORMAT_RGB)
158 for (x = 0; x < xmax; x++) {
159 scanout[x][RED] = getc(stdin);
160 scanout[x][GRN] = getc(stdin);
161 scanout[x][BLU] = getc(stdin);
162 }
163 else
164 for (x = 0; x < xmax; x++) {
165 scanout[x][BLU] = getc(stdin);
166 scanout[x][GRN] = getc(stdin);
167 scanout[x][RED] = getc(stdin);
168 }
169 for (x = pad; x--; getc(stdin));
170 if (feof(stdin) || ferror(stdin))
171 quiterr("error reading rasterfile");
172 gambs_colrs(scanout, xmax);
173 if (bradj)
174 shiftcolrs(scanout, xmax, bradj);
175 if (fwritecolrs(scanout, xmax, stdout) < 0)
176 quiterr("error writing Radiance picture");
177 }
178 /* free scanline */
179 free((char *)scanout);
180 }
181
182
183 ra2pr(rf, pad) /* convert Radiance scanlines to 24-bit rasterfile */
184 int rf;
185 int pad;
186 {
187 int ord[3];
188 COLR *scanin;
189 register int x;
190 int y;
191 /* allocate scanline */
192 scanin = (COLR *)malloc(xmax*sizeof(COLR));
193 if (scanin == NULL)
194 quiterr("out of memory in ra2pr");
195 if (rf == RT_FORMAT_RGB) {
196 ord[0] = RED; ord[1] = GRN; ord[2] = BLU;
197 } else {
198 ord[0] = BLU; ord[1] = GRN; ord[2] = RED;
199 }
200 /* convert image */
201 for (y = ymax-1; y >= 0; y--) {
202 if (freadcolrs(scanin, xmax, stdin) < 0)
203 quiterr("error reading Radiance picture");
204 if (bradj)
205 shiftcolrs(scanin, xmax, bradj);
206 colrs_gambs(scanin, xmax);
207 if (rf == RT_FORMAT_RGB)
208 for (x = 0; x < xmax; x++) {
209 putc(scanin[x][RED], stdout);
210 putc(scanin[x][GRN], stdout);
211 putc(scanin[x][BLU], stdout);
212 }
213 else
214 for (x = 0; x < xmax; x++) {
215 putc(scanin[x][BLU], stdout);
216 putc(scanin[x][GRN], stdout);
217 putc(scanin[x][RED], stdout);
218 }
219 for (x = 0; x < pad; x++)
220 putc(scanin[xmax-1][ord[x%3]], stdout);
221 if (ferror(stdout))
222 quiterr("error writing rasterfile");
223 }
224 /* free scanline */
225 free((char *)scanin);
226 }
