root/radiance/ray/src/px/ra_pr24.c
Changes since 2.11: +21 -15 lines
Thu Jul 3 22:41:44 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.9: +5 -15 lines
Changes since 2.8: +5 -8 lines
Sun Feb 27 10:17:15 1994 UTC (30 years, 3 months ago) by greg
Thu Nov 18 09:55:14 1993 UTC (30 years, 7 months ago) by greg
minor compiler warning fixes
Fri Oct 30 09:08:33 1992 UTC (31 years, 7 months ago) by greg
renamed gamma to gamcor to avoid conflict with math library
Fri Oct 2 16:25:49 1992 UTC (31 years, 8 months ago) by greg
Wed Sep 23 09:17:53 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.3: +18 -7 lines
fixed scanline rounding to 16-bit boundaries
Mon Sep 21 12:15:02 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.2: +13 -2 lines
Changes for PC port
Thu Dec 19 14:52:17 1991 UTC (32 years, 6 months ago) by greg
Tue Nov 12 16:04:46 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.11 , to selected 2.12
Mon Nov 11 14:01:51 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.10 , to selected 2.12
Mon Oct 14 17:09:39 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.9 , to selected 2.12
changed default gamma correction to 2.2
Mon Oct 14 17:06:49 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.8: +25 -12 lines
Diff to previous 1.8 , to selected 2.12
added -rgb option
Thu Aug 15 12:38:24 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.7 , to selected 2.12
fixed error message
Wed Aug 7 08:36:33 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.6: +13 -2 lines
Diff to previous 1.6 , to selected 2.12
added -e +/-stops option
Mon Apr 29 11:14:10 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.5: +17 -10 lines
Diff to previous 1.5 , to selected 2.12
added input compatibility with RT_FORMAT_RGB
Thu Apr 18 14:35:40 1991 UTC (33 years, 2 months ago) by greg
Changes since 1.4: +5 -5 lines
Diff to previous 1.4 , to selected 2.12
Wed Jan 9 15:33:20 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.3 , to selected 2.12
corrected byte ordering (BGR not RGB!)
Sat Oct 20 11:41:29 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.2: +17 -28 lines
Diff to previous 1.2 , to selected 2.12
changed gamma correction to colrops calls
Thu Oct 18 12:21:33 1990 UTC (33 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 2.12
fixed bug in gamma table in ra2pr
Thu Oct 18 12:00:48 1990 UTC (33 years, 8 months ago) by greg
Diff to selected 2.12
