--- ray/src/px/ra_pr24.c 1991/10/14 17:06:49 1.9 +++ ray/src/px/ra_pr24.c 2003/07/03 22:41:44 2.11 @@ -1,23 +1,22 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ra_pr24.c,v 2.11 2003/07/03 22:41:44 schorsch Exp $"; #endif - /* * program to convert between RADIANCE and 24-bit rasterfiles. */ #include +#include +#include +#include +#include "platform.h" #include "rasterfile.h" - #include "color.h" +#include "resolu.h" -extern double atof(), pow(); +double gamcor = 2.2; /* gamma correction */ -double gamma = 2.0; /* gamma correction */ - int bradj = 0; /* brightness adjustment */ char *progname; @@ -32,7 +31,9 @@ char *argv[]; struct rasterfile head; int reverse = 0; int i; - + SET_DEFAULT_BINARY(); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); progname = argv[0]; head.ras_type = RT_STANDARD; @@ -40,7 +41,7 @@ char *argv[]; if (argv[i][0] == '-') switch (argv[i][1]) { case 'g': - gamma = atof(argv[++i]); + gamcor = atof(argv[++i]); break; case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-') @@ -67,11 +68,11 @@ char *argv[]; exit(1); } if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { - fprintf(stderr, "can't open output \"%s\"\n", + fprintf(stderr, "%s: can't open output \"%s\"\n", progname, argv[i+1]); exit(1); } - setcolrgam(gamma); + setcolrgam(gamcor); if (reverse) { /* get header */ if (fread((char *)&head, sizeof(head), 1, stdin) != 1) @@ -86,28 +87,29 @@ char *argv[]; || head.ras_depth != 24) quiterr("incompatible format"); /* put header */ + newheader("RADIANCE", stdout); printargs(i, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); - fputresolu(YMAJOR|YDECR, xmax, ymax, stdout); + fprtresolu(xmax, ymax, stdout); /* convert file */ - pr2ra(head.ras_type); + pr2ra(head.ras_type, head.ras_length/ymax - xmax*3); } else { /* get header info. */ if (checkheader(stdin, COLRFMT, NULL) < 0 || - fgetresolu(&xmax, &ymax, stdin) != (YMAJOR|YDECR)) + fgetresolu(&xmax, &ymax, stdin) < 0) quiterr("bad picture format"); /* write rasterfile header */ head.ras_magic = RAS_MAGIC; - head.ras_width = xmax; + head.ras_width = xmax + (xmax&1); head.ras_height = ymax; head.ras_depth = 24; - head.ras_length = xmax*ymax*3; + head.ras_length = head.ras_width*head.ras_height*3; head.ras_maptype = RMT_NONE; head.ras_maplength = 0; fwrite((char *)&head, sizeof(head), 1, stdout); /* convert file */ - ra2pr(head.ras_type); + ra2pr(head.ras_type, head.ras_length/ymax - xmax*3); } exit(0); userr: @@ -128,8 +130,9 @@ char *err; } -pr2ra(rf) /* convert 24-bit scanlines to Radiance picture */ +pr2ra(rf, pad) /* convert 24-bit scanlines to Radiance picture */ int rf; +int pad; { COLR *scanout; register int x; @@ -152,6 +155,7 @@ int rf; scanout[x][GRN] = getc(stdin); scanout[x][RED] = getc(stdin); } + for (x = pad; x--; getc(stdin)); if (feof(stdin) || ferror(stdin)) quiterr("error reading rasterfile"); gambs_colrs(scanout, xmax); @@ -161,13 +165,15 @@ int rf; quiterr("error writing Radiance picture"); } /* free scanline */ - free((char *)scanout); + free((void *)scanout); } -ra2pr(rf) /* convert Radiance scanlines to 24-bit rasterfile */ -int rf; +ra2pr(rf, pad) /* convert Radiance scanlines to 24-bit rasterfile */ +int rf; +int pad; { + int ord[3]; COLR *scanin; register int x; int y; @@ -175,6 +181,11 @@ int rf; scanin = (COLR *)malloc(xmax*sizeof(COLR)); if (scanin == NULL) quiterr("out of memory in ra2pr"); + if (rf == RT_FORMAT_RGB) { + ord[0] = RED; ord[1] = GRN; ord[2] = BLU; + } else { + ord[0] = BLU; ord[1] = GRN; ord[2] = RED; + } /* convert image */ for (y = ymax-1; y >= 0; y--) { if (freadcolrs(scanin, xmax, stdin) < 0) @@ -194,9 +205,11 @@ int rf; putc(scanin[x][GRN], stdout); putc(scanin[x][RED], stdout); } + for (x = 0; x < pad; x++) + putc(scanin[xmax-1][ord[x%3]], stdout); if (ferror(stdout)) quiterr("error writing rasterfile"); } /* free scanline */ - free((char *)scanin); + free((void *)scanin); }
