root/radiance/ray/src/px/ra_pr24.c
Revision: 2.9
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.8: +5 -8 lines
5 * program to convert between RADIANCE and 24-bit rasterfiles.
6 */
7
8 #include <stdio.h>
9
10 #ifdef MSDOS
11 #include <fcntl.h>
12 #endif
13
14 #include <time.h>
15
16 #include <math.h>
17
18 #include "rasterfile.h"
19
20 #include "color.h"
21
22 #include "resolu.h"
23
24 double gamcor = 2.2; /* gamma correction */
25
26 int bradj = 0; /* brightness adjustment */
27
28 char *progname;
29
30 int xmax, ymax;
31
32
33 main(argc, argv)
34 int argc;
35 char *argv[];
36 {
37 struct rasterfile head;
38 int reverse = 0;
39 int i;
40 #ifdef MSDOS
41 extern int _fmode;
42 _fmode = O_BINARY;
43 setmode(fileno(stdin), O_BINARY);
44 setmode(fileno(stdout), O_BINARY);
45 #endif
46 progname = argv[0];
47
48 head.ras_type = RT_STANDARD;
49 for (i = 1; i < argc; i++)
50 if (argv[i][0] == '-')
51 switch (argv[i][1]) {
52 case 'g':
53 gamcor = atof(argv[++i]);
54 break;
55 case 'e':
56 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
57 goto userr;
58 bradj = atoi(argv[++i]);
59 break;
60 case 'r':
61 if (!strcmp(argv[i], "-rgb"))
62 head.ras_type = RT_FORMAT_RGB;
63 else
64 reverse = 1;
65 break;
66 default:
67 goto userr;
68 }
69 else
70 break;
71
72 if (i < argc-2)
73 goto userr;
74 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
75 fprintf(stderr, "%s: can't open input \"%s\"\n",
76 progname, argv[i]);
77 exit(1);
78 }
79 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
80 fprintf(stderr, "%s: can't open output \"%s\"\n",
81 progname, argv[i+1]);
82 exit(1);
83 }
84 setcolrgam(gamcor);
85 if (reverse) {
86 /* get header */
87 if (fread((char *)&head, sizeof(head), 1, stdin) != 1)
88 quiterr("missing header");
89 if (head.ras_magic != RAS_MAGIC)
90 quiterr("bad raster format");
91 xmax = head.ras_width;
92 ymax = head.ras_height;
93 if ((head.ras_type != RT_STANDARD
94 && head.ras_type != RT_FORMAT_RGB)
95 || head.ras_maptype != RMT_NONE
96 || head.ras_depth != 24)
97 quiterr("incompatible format");
98 /* put header */
99 newheader("RADIANCE", stdout);
100 printargs(i, argv, stdout);
101 fputformat(COLRFMT, stdout);
102 putchar('\n');
103 fprtresolu(xmax, ymax, stdout);
104 /* convert file */
105 pr2ra(head.ras_type, head.ras_length/ymax - xmax*3);
106 } else {
107 /* get header info. */
108 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
109 fgetresolu(&xmax, &ymax, stdin) < 0)
110 quiterr("bad picture format");
111 /* write rasterfile header */
112 head.ras_magic = RAS_MAGIC;
113 head.ras_width = xmax + (xmax&1);
114 head.ras_height = ymax;
115 head.ras_depth = 24;
116 head.ras_length = head.ras_width*head.ras_height*3;
117 head.ras_maptype = RMT_NONE;
118 head.ras_maplength = 0;
119 fwrite((char *)&head, sizeof(head), 1, stdout);
120 /* convert file */
121 ra2pr(head.ras_type, head.ras_length/ymax - xmax*3);
122 }
123 exit(0);
124 userr:
125 fprintf(stderr, "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
126 progname);
127 exit(1);
128 }
129
130
131 quiterr(err) /* print message and exit */
132 char *err;
133 {
134 if (err != NULL) {
135 fprintf(stderr, "%s: %s\n", progname, err);
136 exit(1);
137 }
138 exit(0);
139 }
140
141
142 pr2ra(rf, pad) /* convert 24-bit scanlines to Radiance picture */
143 int rf;
144 int pad;
145 {
146 COLR *scanout;
147 register int x;
148 int y;
149 /* allocate scanline */
150 scanout = (COLR *)malloc(xmax*sizeof(COLR));
151 if (scanout == NULL)
152 quiterr("out of memory in pr2ra");
153 /* convert image */
154 for (y = ymax-1; y >= 0; y--) {
155 if (rf == RT_FORMAT_RGB)
156 for (x = 0; x < xmax; x++) {
157 scanout[x][RED] = getc(stdin);
158 scanout[x][GRN] = getc(stdin);
159 scanout[x][BLU] = getc(stdin);
160 }
161 else
162 for (x = 0; x < xmax; x++) {
163 scanout[x][BLU] = getc(stdin);
164 scanout[x][GRN] = getc(stdin);
165 scanout[x][RED] = getc(stdin);
166 }
167 for (x = pad; x--; getc(stdin));
168 if (feof(stdin) || ferror(stdin))
169 quiterr("error reading rasterfile");
170 gambs_colrs(scanout, xmax);
171 if (bradj)
172 shiftcolrs(scanout, xmax, bradj);
173 if (fwritecolrs(scanout, xmax, stdout) < 0)
174 quiterr("error writing Radiance picture");
175 }
176 /* free scanline */
177 free((void *)scanout);
178 }
179
180
181 ra2pr(rf, pad) /* convert Radiance scanlines to 24-bit rasterfile */
182 int rf;
183 int pad;
184 {
185 int ord[3];
186 COLR *scanin;
187 register int x;
188 int y;
189 /* allocate scanline */
190 scanin = (COLR *)malloc(xmax*sizeof(COLR));
191 if (scanin == NULL)
192 quiterr("out of memory in ra2pr");
193 if (rf == RT_FORMAT_RGB) {
194 ord[0] = RED; ord[1] = GRN; ord[2] = BLU;
195 } else {
196 ord[0] = BLU; ord[1] = GRN; ord[2] = RED;
197 }
198 /* convert image */
199 for (y = ymax-1; y >= 0; y--) {
200 if (freadcolrs(scanin, xmax, stdin) < 0)
201 quiterr("error reading Radiance picture");
202 if (bradj)
203 shiftcolrs(scanin, xmax, bradj);
204 colrs_gambs(scanin, xmax);
205 if (rf == RT_FORMAT_RGB)
206 for (x = 0; x < xmax; x++) {
207 putc(scanin[x][RED], stdout);
208 putc(scanin[x][GRN], stdout);
209 putc(scanin[x][BLU], stdout);
210 }
211 else
212 for (x = 0; x < xmax; x++) {
213 putc(scanin[x][BLU], stdout);
214 putc(scanin[x][GRN], stdout);
215 putc(scanin[x][RED], stdout);
216 }
217 for (x = 0; x < pad; x++)
218 putc(scanin[xmax-1][ord[x%3]], stdout);
219 if (ferror(stdout))
220 quiterr("error writing rasterfile");
221 }
222 /* free scanline */
223 free((void *)scanin);
224 }
