| 1 |
/* Copyright (c) 1990 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* program to convert between RADIANCE and 24-bit rasterfiles.
| 9 |
| 10 |
| 11 |
#include <stdio.h>
| 12 |
| 13 |
#include "rasterfile.h"
| 14 |
| 15 |
#include "color.h"
| 16 |
| 17 |
extern double atof(), pow();
| 18 |
| 19 |
double gamma = 2.0; /* gamma correction */
| 20 |
| 21 |
char *progname;
| 22 |
| 23 |
int xmax, ymax;
| 24 |
| 25 |
| 26 |
main(argc, argv)
| 27 |
int argc;
| 28 |
char *argv[];
| 29 |
| 30 |
struct rasterfile head;
| 31 |
int reverse = 0;
| 32 |
int i;
| 33 |
| 34 |
progname = argv[0];
| 35 |
| 36 |
for (i = 1; i < argc; i++)
| 37 |
if (argv[i][0] == '-')
| 38 |
switch (argv[i][1]) {
| 39 |
case 'g':
| 40 |
gamma = atof(argv[++i]);
| 41 |
break;
| 42 |
case 'r':
| 43 |
reverse = !reverse;
| 44 |
break;
| 45 |
default:
| 46 |
goto userr;
| 47 |
| 48 |
else
| 49 |
break;
| 50 |
| 51 |
if (i < argc-2)
| 52 |
goto userr;
| 53 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
| 54 |
fprintf(stderr, "%s: can't open input \"%s\"\n",
| 55 |
progname, argv[i]);
| 56 |
exit(1);
| 57 |
| 58 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
| 59 |
fprintf(stderr, "can't open output \"%s\"\n",
| 60 |
progname, argv[i+1]);
| 61 |
exit(1);
| 62 |
| 63 |
if (reverse) {
| 64 |
/* get header */
| 65 |
if (fread((char *)&head, sizeof(head), 1, stdin) != 1)
| 66 |
quiterr("missing header");
| 67 |
if (head.ras_magic != RAS_MAGIC)
| 68 |
quiterr("bad raster format");
| 69 |
xmax = head.ras_width;
| 70 |
ymax = head.ras_height;
| 71 |
if (head.ras_type != RT_STANDARD ||
| 72 |
head.ras_maptype != RMT_NONE ||
| 73 |
head.ras_depth != 24)
| 74 |
quiterr("incompatible format");
| 75 |
/* put header */
| 76 |
printargs(i, argv, stdout);
| 77 |
putchar('\n');
| 78 |
fputresolu(YMAJOR|YDECR, xmax, ymax, stdout);
| 79 |
/* convert file */
| 80 |
pr2ra();
| 81 |
} else {
| 82 |
/* discard input header */
| 83 |
getheader(stdin, NULL);
| 84 |
/* get resolution */
| 85 |
if (fgetresolu(&xmax, &ymax, stdin) != (YMAJOR|YDECR))
| 86 |
quiterr("bad picture size");
| 87 |
/* write rasterfile header */
| 88 |
head.ras_magic = RAS_MAGIC;
| 89 |
head.ras_width = xmax;
| 90 |
head.ras_height = ymax;
| 91 |
head.ras_depth = 24;
| 92 |
head.ras_length = xmax*ymax*3;
| 93 |
head.ras_type = RT_STANDARD;
| 94 |
head.ras_maptype = RMT_NONE;
| 95 |
head.ras_maplength = 0;
| 96 |
fwrite((char *)&head, sizeof(head), 1, stdout);
| 97 |
/* convert file */
| 98 |
ra2pr();
| 99 |
| 100 |
exit(0);
| 101 |
userr:
| 102 |
fprintf(stderr, "Usage: %s [-r][-g gamma] [input [output]]\n",
| 103 |
progname);
| 104 |
exit(1);
| 105 |
| 106 |
| 107 |
| 108 |
quiterr(err) /* print message and exit */
| 109 |
char *err;
| 110 |
| 111 |
if (err != NULL) {
| 112 |
fprintf(stderr, "%s: %s\n", progname, err);
| 113 |
exit(1);
| 114 |
| 115 |
exit(0);
| 116 |
| 117 |
| 118 |
| 119 |
pr2ra() /* convert 24-bit scanlines to Radiance picture */
| 120 |
| 121 |
float gmap[256];
| 122 |
int r, g, b;
| 123 |
COLOR *scanout;
| 124 |
register int x;
| 125 |
int y;
| 126 |
/* allocate scanline */
| 127 |
scanout = (COLOR *)malloc(xmax*sizeof(COLOR));
| 128 |
if (scanout == NULL)
| 129 |
quiterr("out of memory in pr2ra");
| 130 |
/* compute gamma correction */
| 131 |
for (x = 0; x < 256; x++)
| 132 |
gmap[x] = pow((x+.5)/256., gamma);
| 133 |
/* convert image */
| 134 |
for (y = ymax-1; y >= 0; y--) {
| 135 |
for (x = 0; x < xmax; x++) {
| 136 |
r = getc(stdin); g = getc(stdin);
| 137 |
if ((b = getc(stdin)) == EOF)
| 138 |
quiterr("error reading rasterfile");
| 139 |
setcolor(scanout[x], gmap[r], gmap[g], gmap[b]);
| 140 |
| 141 |
if (fwritescan(scanout, xmax, stdout) < 0)
| 142 |
quiterr("error writing Radiance picture");
| 143 |
| 144 |
/* free scanline */
| 145 |
free((char *)scanout);
| 146 |
| 147 |
| 148 |
| 149 |
ra2pr() /* convert Radiance scanlines to 24-bit rasterfile */
| 150 |
| 151 |
#define map(v) ((v)>=1.0 ? 255 : gmap[(int)(1024.*(v))])
| 152 |
unsigned char gmap[1024];
| 153 |
COLOR *scanin;
| 154 |
register int x;
| 155 |
register int c;
| 156 |
int y;
| 157 |
| 158 |
scanin = (COLOR *)malloc(xmax*sizeof(COLOR));
| 159 |
if (scanin == NULL)
| 160 |
| 161 |
| 162 |
| 163 |
gmap[x] = 256.*pow((x+.5)/1024., 1./gamma);
| 164 |
/* convert image */
| 165 |
| 166 |
if (freadscan(scanin, xmax, stdin) < 0)
| 167 |
quiterr("error reading Radiance picture");
| 168 |
| 169 |
c = map(colval(scanin[x],RED));
| 170 |
putc(c, stdout);
| 171 |
c = map(colval(scanin[x],GRN));
| 172 |
putc(c, stdout);
| 173 |
c = map(colval(scanin[x],BLU));
| 174 |
putc(c, stdout);
| 175 |
| 176 |
if (ferror(stdout))
| 177 |
quiterr("error writing rasterfile");
| 178 |
| 179 |
/* free scanline */
| 180 |
free((char *)scanin);
| 181 |
#undef map
| 182 |
