1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* ra_pr.c - program to convert between RADIANCE and pixrect picture format. |
9 |
10 |
* 11/10/87 |
11 |
* 3/1/88 Added Paul Heckbert's color map allocation |
12 |
13 |
14 |
#include <stdio.h> |
15 |
16 |
#include <math.h> |
17 |
18 |
#include "rasterfile.h" |
19 |
20 |
#include "color.h" |
21 |
22 |
#include "resolu.h" |
23 |
24 |
#include "pic.h" |
25 |
26 |
/* descriptor for a picture file or frame buffer */ |
27 |
typedef struct { |
28 |
char *name; /* file name */ |
29 |
FILE *fp; /* file pointer */ |
30 |
int nexty; /* file positioning */ |
31 |
int bytes_line; /* 0 == variable length lines */ |
32 |
union { |
33 |
long b; /* initial scanline */ |
34 |
long *y; /* individual scanline */ |
35 |
} pos; /* position(s) */ |
36 |
} pic; |
37 |
38 |
extern pic *openinput(), *openoutput(); |
39 |
40 |
extern char *ecalloc(), *emalloc(); |
41 |
42 |
extern long ftell(); |
43 |
44 |
double gamcor = 2.2; /* gamma correction */ |
45 |
46 |
int bradj = 0; /* brightness adjustment */ |
47 |
48 |
pic *inpic, *outpic; |
49 |
50 |
char *progname; |
51 |
52 |
char errmsg[128]; |
53 |
54 |
COLR *inl; |
55 |
56 |
int xmax, ymax; |
57 |
58 |
59 |
main(argc, argv) |
60 |
int argc; |
61 |
char *argv[]; |
62 |
63 |
colormap rasmap; |
64 |
struct rasterfile head; |
65 |
int dither = 1; |
66 |
int reverse = 0; |
67 |
int ncolors = 256; |
68 |
int greyscale = 0; |
69 |
int i; |
70 |
71 |
progname = argv[0]; |
72 |
73 |
for (i = 1; i < argc; i++) |
74 |
if (argv[i][0] == '-') |
75 |
switch (argv[i][1]) { |
76 |
case 'd': |
77 |
dither = !dither; |
78 |
break; |
79 |
case 'g': |
80 |
gamcor = atof(argv[++i]); |
81 |
break; |
82 |
case 'b': |
83 |
greyscale = !greyscale; |
84 |
break; |
85 |
case 'e': |
86 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
87 |
goto userr; |
88 |
bradj = atoi(argv[++i]); |
89 |
break; |
90 |
case 'r': |
91 |
reverse = !reverse; |
92 |
break; |
93 |
case 'c': |
94 |
ncolors = atoi(argv[++i]); |
95 |
break; |
96 |
default: |
97 |
goto userr; |
98 |
99 |
else |
100 |
break; |
101 |
102 |
if (reverse) { |
103 |
if (i < argc-2) |
104 |
goto userr; |
105 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
106 |
sprintf(errmsg, "can't open input \"%s\"", argv[i]); |
107 |
quiterr(errmsg); |
108 |
109 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
110 |
sprintf(errmsg, "can't open output \"%s\"", argv[i+1]); |
111 |
quiterr(errmsg); |
112 |
113 |
/* get header */ |
114 |
if (fread((char *)&head, sizeof(head), 1, stdin) != 1) |
115 |
quiterr("missing header"); |
116 |
if (head.ras_magic != RAS_MAGIC) |
117 |
quiterr("bad raster format"); |
118 |
xmax = head.ras_width; |
119 |
ymax = head.ras_height; |
120 |
if (head.ras_type != RT_STANDARD || |
121 |
head.ras_maptype != RMT_EQUAL_RGB || |
122 |
head.ras_depth != 8) |
123 |
quiterr("incompatible format"); |
124 |
/* put header */ |
125 |
newheader("RADIANCE", stdout); |
126 |
printargs(i, argv, stdout); |
127 |
fputformat(COLRFMT, stdout); |
128 |
putchar('\n'); |
129 |
fprtresolu(xmax, ymax, stdout); |
130 |
/* convert file */ |
131 |
pr2ra(&head); |
132 |
} else { |
133 |
if (i < argc-2 || (!greyscale && i > argc-1)) |
134 |
goto userr; |
135 |
if ((inpic = openinput(argv[i], &head)) == NULL) { |
136 |
137 |
quiterr(errmsg); |
138 |
139 |
if ((outpic = openoutput(i==argc-2 ? argv[i+1] : (char *)NULL, |
140 |
141 |
142 |
quiterr(errmsg); |
143 |
144 |
145 |
if (greyscale) |
146 |
biq(dither,ncolors,1,rasmap); |
147 |
else |
148 |
ciq(dither,ncolors,1,rasmap); |
149 |
150 |
quiterr(NULL); |
151 |
userr: |
152 |
fprintf(stderr, |
153 |
"Usage: %s [-d][-c ncolors][-b][-g gamma][-e +/-stops] input [output]\n", |
154 |
progname); |
155 |
fprintf(stderr, " Or: %s -r [-g gamma][-e +/-stops] [input [output]]\n", |
156 |
progname); |
157 |
exit(1); |
158 |
159 |
160 |
161 |
quiterr(err) /* print message and exit */ |
162 |
char *err; |
163 |
164 |
if (err != NULL) { |
165 |
fprintf(stderr, "%s: %s\n", progname, err); |
166 |
exit(1); |
167 |
168 |
exit(0); |
169 |
170 |
171 |
172 |
eputs(s) |
173 |
char *s; |
174 |
175 |
fputs(s, stderr); |
176 |
177 |
178 |
179 |
quit(code) |
180 |
int code; |
181 |
182 |
exit(code); |
183 |
184 |
185 |
186 |
pic * |
187 |
openinput(fname, h) /* open RADIANCE input file */ |
188 |
char *fname; |
189 |
register struct rasterfile *h; |
190 |
191 |
register pic *p; |
192 |
193 |
p = (pic *)emalloc(sizeof(pic)); |
194 |
p->name = fname; |
195 |
if (fname == NULL) |
196 |
p->fp = stdin; |
197 |
else if ((p->fp = fopen(fname, "r")) == NULL) |
198 |
return(NULL); |
199 |
/* check header */ |
200 |
if (checkheader(p->fp, COLRFMT, NULL) < 0 || |
201 |
fgetresolu(&xmax, &ymax, p->fp) < 0) |
202 |
quiterr("bad picture format"); |
203 |
p->nexty = 0; |
204 |
p->bytes_line = 0; /* variable length lines */ |
205 |
p->pos.y = (long *)ecalloc(ymax, sizeof(long)); |
206 |
p->pos.y[0] = ftell(p->fp); |
207 |
/* assign header */ |
208 |
h->ras_magic = RAS_MAGIC; |
209 |
h->ras_width = xmax + (xmax&1); /* round to 16 bits */ |
210 |
h->ras_height = ymax; |
211 |
h->ras_depth = 8; |
212 |
h->ras_type = RT_STANDARD; |
213 |
h->ras_length = h->ras_width*h->ras_height; |
214 |
h->ras_maptype = RMT_EQUAL_RGB; |
215 |
h->ras_maplength = 256*3; |
216 |
/* allocate scanline */ |
217 |
inl = (COLR *)emalloc(xmax*sizeof(COLR)); |
218 |
219 |
return(p); |
220 |
221 |
222 |
223 |
pic * |
224 |
openoutput(fname, h) /* open output rasterfile */ |
225 |
char *fname; |
226 |
227 |
228 |
register pic *p; |
229 |
230 |
231 |
p->name = fname; |
232 |
233 |
p->fp = stdout; |
234 |
else if ((p->fp = fopen(fname, "w")) == NULL) |
235 |
return(NULL); |
236 |
/* write header */ |
237 |
fwrite((char *)h, sizeof(*h), 1, p->fp); |
238 |
p->nexty = -1; /* needs color map */ |
239 |
p->bytes_line = h->ras_width; |
240 |
p->pos.b = 0; |
241 |
242 |
return(p); |
243 |
244 |
245 |
246 |
pr2ra(h) /* pixrect file to RADIANCE file */ |
247 |
248 |
249 |
BYTE cmap[3][256]; |
250 |
COLR ctab[256]; |
251 |
COLR *scanline; |
252 |
register int i, j, c; |
253 |
254 |
scanline = (COLR *)emalloc(xmax*sizeof(COLR)); |
255 |
/* get color table */ |
256 |
for (i = 0; i < 3; i ++) |
257 |
if (fread((char *)cmap[i], h->ras_maplength/3, 1, stdin) != 1) |
258 |
quiterr("error reading color table"); |
259 |
/* convert table */ |
260 |
for (i = 0; i < h->ras_maplength/3; i++) |
261 |
setcolr(ctab[i], |
262 |
pow((cmap[0][i]+.5)/256.,gamcor), |
263 |
pow((cmap[1][i]+.5)/256.,gamcor), |
264 |
pow((cmap[2][i]+.5)/256.,gamcor)); |
265 |
if (bradj) |
266 |
shiftcolrs(ctab, 256, bradj); |
267 |
268 |
for (i = 0; i < ymax; i++) { |
269 |
for (j = 0; j < xmax; j++) { |
270 |
if ((c = getc(stdin)) == EOF) |
271 |
quiterr("error reading rasterfile"); |
272 |
copycolr(scanline[j], ctab[c]); |
273 |
274 |
if (xmax & 1) /* extra byte */ |
275 |
getc(stdin); |
276 |
if (fwritecolrs(scanline, xmax, stdout) < 0) |
277 |
quiterr("error writing RADIANCE file"); |
278 |
279 |
free((char *)scanline); |
280 |
281 |
282 |
283 |
picreadline3(y, l3) /* read in 3-byte scanline */ |
284 |
int y; |
285 |
register rgbpixel *l3; |
286 |
287 |
register int i; |
288 |
289 |
if (inpic->nexty != y) { /* find scanline */ |
290 |
if (inpic->bytes_line == 0) { |
291 |
if (inpic->pos.y[y] == 0) { |
292 |
while (inpic->nexty < y) { |
293 |
if (freadcolrs(inl, xmax, inpic->fp) < 0) |
294 |
quiterr("read error in picreadline3"); |
295 |
inpic->pos.y[++inpic->nexty] = ftell(inpic->fp); |
296 |
297 |
} else if (fseek(inpic->fp, inpic->pos.y[y], 0) == EOF) |
298 |
quiterr("seek error in picreadline3"); |
299 |
} else if (fseek(inpic->fp, y*inpic->bytes_line+inpic->pos.b, 0) == EOF) |
300 |
301 |
} else if (inpic->bytes_line == 0 && inpic->pos.y[inpic->nexty] == 0) |
302 |
inpic->pos.y[inpic->nexty] = ftell(inpic->fp); |
303 |
if (freadcolrs(inl, xmax, inpic->fp) < 0) /* read scanline */ |
304 |
305 |
inpic->nexty = y+1; |
306 |
/* convert scanline */ |
307 |
normcolrs(inl, xmax, bradj); |
308 |
for (i = 0; i < xmax; i++) { |
309 |
l3[i].r = inl[i][RED]; |
310 |
l3[i].g = inl[i][GRN]; |
311 |
l3[i].b = inl[i][BLU]; |
312 |
313 |
314 |
315 |
316 |
picwriteline(y, l) /* write out scanline */ |
317 |
int y; |
318 |
register pixel *l; |
319 |
320 |
if (outpic->nexty != y) { /* seek to scanline */ |
321 |
if (outpic->bytes_line == 0) { |
322 |
if (outpic->pos.y[y] == 0) |
323 |
quiterr("cannot seek in picwriteline"); |
324 |
else if (fseek(outpic->fp, outpic->pos.y[y], 0) == EOF) |
325 |
quiterr("seek error in picwriteline"); |
326 |
} else if (fseek(outpic->fp, y*outpic->bytes_line+outpic->pos.b, 0) == EOF) |
327 |
328 |
329 |
/* write scanline */ |
330 |
if (fwrite((char *)l, sizeof(pixel), xmax, outpic->fp) != xmax) |
331 |
quiterr("write error in picwriteline"); |
332 |
if (xmax&1) /* on 16-bit boundary */ |
333 |
putc(l[xmax-1], outpic->fp); |
334 |
outpic->nexty = y+1; |
335 |
if (outpic->bytes_line == 0 && outpic->pos.y[outpic->nexty] == 0) |
336 |
outpic->pos.y[outpic->nexty] = ftell(outpic->fp); |
337 |
338 |
339 |
340 |
picwritecm(cm) /* write out color map */ |
341 |
colormap cm; |
342 |
343 |
register int i, j; |
344 |
345 |
if (outpic->nexty != -1 && |
346 |
fseek(outpic->fp, (long)sizeof(struct rasterfile), 0) == EOF) |
347 |
quiterr("seek error in picwritecm"); |
348 |
for (i = 0; i < 3; i++) |
349 |
for (j = 0; j < 256; j++) |
350 |
putc(cm[i][j], outpic->fp); |
351 |
outpic->nexty = 0; |
352 |
if (outpic->bytes_line == 0) |
353 |
outpic->pos.y[0] = ftell(outpic->fp); |
354 |
else |
355 |
outpic->pos.b = ftell(outpic->fp); |
356 |
357 |
358 |
359 |
picreadcm(map) /* do gamma correction if requested */ |
360 |
colormap map; |
361 |
362 |
register int i, val; |
363 |
364 |
for (i = 0; i < 256; i++) { |
365 |
val = pow((i+0.5)/256.0, 1.0/gamcor) * 256.0; |
366 |
map[0][i] = map[1][i] = map[2][i] = val; |
367 |
368 |
