root/radiance/ray/src/px/ra_pr.c
Revision: 2.2
Committed: Thu Dec 19 14:52:14 1991 UTC (32 years, 6 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ra_pr.c - program to convert between RADIANCE and pixrect picture format.
9 *
10 * 11/10/87
11 * 3/1/88 Added Paul Heckbert's color map allocation
12 */
13
14 #include <stdio.h>
15
16 #include "rasterfile.h"
17
18 #include "color.h"
19
20 #include "resolu.h"
21
22 #include "pic.h"
23
24 /* descriptor for a picture file or frame buffer */
25 typedef struct {
26 char *name; /* file name */
27 FILE *fp; /* file pointer */
28 int nexty; /* file positioning */
29 int bytes_line; /* 0 == variable length lines */
30 union {
31 long b; /* initial scanline */
32 long *y; /* individual scanline */
33 } pos; /* position(s) */
34 } pic;
35
36 extern pic *openinput(), *openoutput();
37
38 extern char *ecalloc(), *emalloc();
39
40 extern long ftell();
41
42 extern double pow();
43
44 double gamma = 2.2; /* gamma correction */
45
46 int bradj = 0; /* brightness adjustment */
47
48 pic *inpic, *outpic;
49
50 char *progname;
51
52 char errmsg[128];
53
54 COLR *inl;
55
56 int xmax, ymax;
57
58
59 main(argc, argv)
60 int argc;
61 char *argv[];
62 {
63 colormap rasmap;
64 struct rasterfile head;
65 int dither = 1;
66 int reverse = 0;
67 int ncolors = 256;
68 int greyscale = 0;
69 int i;
70
71 progname = argv[0];
72
73 for (i = 1; i < argc; i++)
74 if (argv[i][0] == '-')
75 switch (argv[i][1]) {
76 case 'd':
77 dither = !dither;
78 break;
79 case 'g':
80 gamma = atof(argv[++i]);
81 break;
82 case 'b':
83 greyscale = !greyscale;
84 break;
85 case 'e':
86 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
87 goto userr;
88 bradj = atoi(argv[++i]);
89 break;
90 case 'r':
91 reverse = !reverse;
92 break;
93 case 'c':
94 ncolors = atoi(argv[++i]);
95 break;
96 default:
97 goto userr;
98 }
99 else
100 break;
101
102 if (reverse) {
103 if (i < argc-2)
104 goto userr;
105 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
106 sprintf(errmsg, "can't open input \"%s\"", argv[i]);
107 quiterr(errmsg);
108 }
109 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
110 sprintf(errmsg, "can't open output \"%s\"", argv[i+1]);
111 quiterr(errmsg);
112 }
113 /* get header */
114 if (fread((char *)&head, sizeof(head), 1, stdin) != 1)
115 quiterr("missing header");
116 if (head.ras_magic != RAS_MAGIC)
117 quiterr("bad raster format");
118 xmax = head.ras_width;
119 ymax = head.ras_height;
120 if (head.ras_type != RT_STANDARD ||
121 head.ras_maptype != RMT_EQUAL_RGB ||
122 head.ras_depth != 8)
123 quiterr("incompatible format");
124 /* put header */
125 printargs(i, argv, stdout);
126 fputformat(COLRFMT, stdout);
127 putchar('\n');
128 fprtresolu(xmax, ymax, stdout);
129 /* convert file */
130 pr2ra(&head);
131 } else {
132 if (i < argc-2 || (!greyscale && i > argc-1))
133 goto userr;
134 if ((inpic = openinput(argv[i], &head)) == NULL) {
135 sprintf(errmsg, "can't open input \"%s\"", argv[i]);
136 quiterr(errmsg);
137 }
138 if ((outpic = openoutput(i==argc-2 ? argv[i+1] : (char *)NULL,
139 &head)) == NULL) {
140 sprintf(errmsg, "can't open output \"%s\"", argv[i+1]);
141 quiterr(errmsg);
142 }
143 /* convert file */
144 if (greyscale)
145 biq(dither,ncolors,1,rasmap);
146 else
147 ciq(dither,ncolors,1,rasmap);
148 }
149 quiterr(NULL);
150 userr:
151 fprintf(stderr,
152 "Usage: %s [-d][-c ncolors][-b][-g gamma][-e +/-stops] input [output]\n",
153 progname);
154 fprintf(stderr, " Or: %s -r [-g gamma][-e +/-stops] [input [output]]\n",
155 progname);
156 exit(1);
157 }
158
159
160 quiterr(err) /* print message and exit */
161 char *err;
162 {
163 if (err != NULL) {
164 fprintf(stderr, "%s: %s\n", progname, err);
165 exit(1);
166 }
167 exit(0);
168 }
169
170
171 eputs(s)
172 char *s;
173 {
174 fputs(s, stderr);
175 }
176
177
178 quit(code)
179 int code;
180 {
181 exit(code);
182 }
183
184
185 pic *
186 openinput(fname, h) /* open RADIANCE input file */
187 char *fname;
188 register struct rasterfile *h;
189 {
190 register pic *p;
191
192 p = (pic *)emalloc(sizeof(pic));
193 p->name = fname;
194 if (fname == NULL)
195 p->fp = stdin;
196 else if ((p->fp = fopen(fname, "r")) == NULL)
197 return(NULL);
198 /* check header */
199 if (checkheader(p->fp, COLRFMT, NULL) < 0 ||
200 fgetresolu(&xmax, &ymax, p->fp) < 0)
201 quiterr("bad picture format");
202 p->nexty = 0;
203 p->bytes_line = 0; /* variable length lines */
204 p->pos.y = (long *)ecalloc(ymax, sizeof(long));
205 p->pos.y[0] = ftell(p->fp);
206 /* assign header */
207 h->ras_magic = RAS_MAGIC;
208 h->ras_width = xmax + (xmax&1); /* round to 16 bits */
209 h->ras_height = ymax;
210 h->ras_depth = 8;
211 h->ras_type = RT_STANDARD;
212 h->ras_length = h->ras_width*h->ras_height;
213 h->ras_maptype = RMT_EQUAL_RGB;
214 h->ras_maplength = 256*3;
215 /* allocate scanline */
216 inl = (COLR *)emalloc(xmax*sizeof(COLR));
217
218 return(p);
219 }
220
221
222 pic *
223 openoutput(fname, h) /* open output rasterfile */
224 char *fname;
225 register struct rasterfile *h;
226 {
227 register pic *p;
228
229 p = (pic *)emalloc(sizeof(pic));
230 p->name = fname;
231 if (fname == NULL)
232 p->fp = stdout;
233 else if ((p->fp = fopen(fname, "w")) == NULL)
234 return(NULL);
235 /* write header */
236 fwrite((char *)h, sizeof(*h), 1, p->fp);
237 p->nexty = -1; /* needs color map */
238 p->bytes_line = h->ras_width;
239 p->pos.b = 0;
240
241 return(p);
242 }
243
244
245 pr2ra(h) /* pixrect file to RADIANCE file */
246 struct rasterfile *h;
247 {
248 BYTE cmap[3][256];
249 COLR ctab[256];
250 COLR *scanline;
251 register int i, j, c;
252
253 scanline = (COLR *)emalloc(xmax*sizeof(COLR));
254 /* get color table */
255 for (i = 0; i < 3; i ++)
256 if (fread((char *)cmap[i], h->ras_maplength/3, 1, stdin) != 1)
257 quiterr("error reading color table");
258 /* convert table */
259 for (i = 0; i < h->ras_maplength/3; i++)
260 setcolr(ctab[i],
261 pow((cmap[0][i]+.5)/256.,gamma),
262 pow((cmap[1][i]+.5)/256.,gamma),
263 pow((cmap[2][i]+.5)/256.,gamma));
264 if (bradj)
265 shiftcolrs(ctab, 256, bradj);
266 /* convert file */
267 for (i = 0; i < ymax; i++) {
268 for (j = 0; j < xmax; j++) {
269 if ((c = getc(stdin)) == EOF)
270 quiterr("error reading rasterfile");
271 copycolr(scanline[j], ctab[c]);
272 }
273 if (xmax & 1) /* extra byte */
274 getc(stdin);
275 if (fwritecolrs(scanline, xmax, stdout) < 0)
276 quiterr("error writing RADIANCE file");
277 }
278 free((char *)scanline);
279 }
280
281
282 picreadline3(y, l3) /* read in 3-byte scanline */
283 int y;
284 register rgbpixel *l3;
285 {
286 register int i;
287
288 if (inpic->nexty != y) { /* find scanline */
289 if (inpic->bytes_line == 0) {
290 if (inpic->pos.y[y] == 0) {
291 while (inpic->nexty < y) {
292 if (freadcolrs(inl, xmax, inpic->fp) < 0)
293 quiterr("read error in picreadline3");
294 inpic->pos.y[++inpic->nexty] = ftell(inpic->fp);
295 }
296 } else if (fseek(inpic->fp, inpic->pos.y[y], 0) == EOF)
297 quiterr("seek error in picreadline3");
298 } else if (fseek(inpic->fp, y*inpic->bytes_line+inpic->pos.b, 0) == EOF)
299 quiterr("seek error in picreadline3");
300 } else if (inpic->bytes_line == 0 && inpic->pos.y[inpic->nexty] == 0)
301 inpic->pos.y[inpic->nexty] = ftell(inpic->fp);
302 if (freadcolrs(inl, xmax, inpic->fp) < 0) /* read scanline */
303 quiterr("read error in picreadline3");
304 inpic->nexty = y+1;
305 /* convert scanline */
306 normcolrs(inl, xmax, bradj);
307 for (i = 0; i < xmax; i++) {
308 l3[i].r = inl[i][RED];
309 l3[i].g = inl[i][GRN];
310 l3[i].b = inl[i][BLU];
311 }
312 }
313
314
315 picwriteline(y, l) /* write out scanline */
316 int y;
317 register pixel *l;
318 {
319 if (outpic->nexty != y) { /* seek to scanline */
320 if (outpic->bytes_line == 0) {
321 if (outpic->pos.y[y] == 0)
322 quiterr("cannot seek in picwriteline");
323 else if (fseek(outpic->fp, outpic->pos.y[y], 0) == EOF)
324 quiterr("seek error in picwriteline");
325 } else if (fseek(outpic->fp, y*outpic->bytes_line+outpic->pos.b, 0) == EOF)
326 quiterr("seek error in picwriteline");
327 }
328 /* write scanline */
329 if (fwrite((char *)l, sizeof(pixel), xmax, outpic->fp) != xmax)
330 quiterr("write error in picwriteline");
331 if (xmax&1) /* on 16-bit boundary */
332 putc(l[xmax-1], outpic->fp);
333 outpic->nexty = y+1;
334 if (outpic->bytes_line == 0 && outpic->pos.y[outpic->nexty] == 0)
335 outpic->pos.y[outpic->nexty] = ftell(outpic->fp);
336 }
337
338
339 picwritecm(cm) /* write out color map */
340 colormap cm;
341 {
342 register int i, j;
343
344 if (outpic->nexty != -1 &&
345 fseek(outpic->fp, (long)sizeof(struct rasterfile), 0) == EOF)
346 quiterr("seek error in picwritecm");
347 for (i = 0; i < 3; i++)
348 for (j = 0; j < 256; j++)
349 putc(cm[i][j], outpic->fp);
350 outpic->nexty = 0;
351 if (outpic->bytes_line == 0)
352 outpic->pos.y[0] = ftell(outpic->fp);
353 else
354 outpic->pos.b = ftell(outpic->fp);
355 }
356
357
358 picreadcm(map) /* do gamma correction if requested */
359 colormap map;
360 {
361 register int i, val;
362
363 for (i = 0; i < 256; i++) {
364 val = pow((i+0.5)/256.0, 1.0/gamma) * 256.0;
365 map[0][i] = map[1][i] = map[2][i] = val;
366 }
367 }
