--- ray/src/px/ra_pr.c 1990/01/18 23:58:19 1.5 +++ ray/src/px/ra_pr.c 1992/10/02 16:25:33 2.3 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -13,10 +13,14 @@ static char SCCSid[] = "$SunId$ LBL"; #include +#include + #include "rasterfile.h" #include "color.h" +#include "resolu.h" + #include "pic.h" /* descriptor for a picture file or frame buffer */ @@ -37,9 +41,9 @@ extern char *ecalloc(), *emalloc(); extern long ftell(); -extern double atof(), pow(); +double gamma = 2.2; /* gamma correction */ -double gamma = 2.0; /* gamma correction */ +int bradj = 0; /* brightness adjustment */ pic *inpic, *outpic; @@ -47,7 +51,7 @@ char *progname; char errmsg[128]; -COLR *inline; +COLR *inl; int xmax, ymax; @@ -78,6 +82,11 @@ char *argv[]; case 'b': greyscale = !greyscale; break; + case 'e': + if (argv[i+1][0] != '+' && argv[i+1][0] != '-') + goto userr; + bradj = atoi(argv[++i]); + break; case 'r': reverse = !reverse; break; @@ -113,13 +122,14 @@ char *argv[]; head.ras_depth != 8) quiterr("incompatible format"); /* put header */ - printargs(argc, argv, stdout); + printargs(i, argv, stdout); + fputformat(COLRFMT, stdout); putchar('\n'); - fputresolu(YMAJOR|YDECR, xmax, ymax, stdout); + fprtresolu(xmax, ymax, stdout); /* convert file */ pr2ra(&head); } else { - if (i > argc-1 || i < argc-2) + if (i < argc-2 || (!greyscale && i > argc-1)) goto userr; if ((inpic = openinput(argv[i], &head)) == NULL) { sprintf(errmsg, "can't open input \"%s\"", argv[i]); @@ -139,9 +149,9 @@ char *argv[]; quiterr(NULL); userr: fprintf(stderr, - "Usage: %s [-d][-c ncolors][-b][-g gamma] input [output]\n", + "Usage: %s [-d][-c ncolors][-b][-g gamma][-e +/-stops] input [output]\n", progname); - fprintf(stderr, " Or: %s -r [-g gamma] [input [output]]\n", + fprintf(stderr, " Or: %s -r [-g gamma][-e +/-stops] [input [output]]\n", progname); exit(1); } @@ -185,10 +195,10 @@ register struct rasterfile *h; p->fp = stdin; else if ((p->fp = fopen(fname, "r")) == NULL) return(NULL); - /* discard header */ - getheader(p->fp, NULL); - if (fgetresolu(&xmax, &ymax, p->fp) != (YMAJOR|YDECR)) - quiterr("bad picture size"); + /* check header */ + if (checkheader(p->fp, COLRFMT, NULL) < 0 || + fgetresolu(&xmax, &ymax, p->fp) < 0) + quiterr("bad picture format"); p->nexty = 0; p->bytes_line = 0; /* variable length lines */ p->pos.y = (long *)ecalloc(ymax, sizeof(long)); @@ -203,7 +213,7 @@ register struct rasterfile *h; h->ras_maptype = RMT_EQUAL_RGB; h->ras_maplength = 256*3; /* allocate scanline */ - inline = (COLR *)emalloc(xmax*sizeof(COLR)); + inl = (COLR *)emalloc(xmax*sizeof(COLR)); return(p); } @@ -251,6 +261,8 @@ struct rasterfile *h; pow((cmap[0][i]+.5)/256.,gamma), pow((cmap[1][i]+.5)/256.,gamma), pow((cmap[2][i]+.5)/256.,gamma)); + if (bradj) + shiftcolrs(ctab, 256, bradj); /* convert file */ for (i = 0; i < ymax; i++) { for (j = 0; j < xmax; j++) { @@ -277,7 +289,7 @@ register rgbpixel *l3; if (inpic->bytes_line == 0) { if (inpic->pos.y[y] == 0) { while (inpic->nexty < y) { - if (freadcolrs(inline, xmax, inpic->fp) < 0) + if (freadcolrs(inl, xmax, inpic->fp) < 0) quiterr("read error in picreadline3"); inpic->pos.y[++inpic->nexty] = ftell(inpic->fp); } @@ -287,15 +299,15 @@ register rgbpixel *l3; quiterr("seek error in picreadline3"); } else if (inpic->bytes_line == 0 && inpic->pos.y[inpic->nexty] == 0) inpic->pos.y[inpic->nexty] = ftell(inpic->fp); - if (freadcolrs(inline, xmax, inpic->fp) < 0) /* read scanline */ + if (freadcolrs(inl, xmax, inpic->fp) < 0) /* read scanline */ quiterr("read error in picreadline3"); inpic->nexty = y+1; /* convert scanline */ - normcolrs(inline, xmax); + normcolrs(inl, xmax, bradj); for (i = 0; i < xmax; i++) { - l3[i].r = inline[i][RED]; - l3[i].g = inline[i][GRN]; - l3[i].b = inline[i][BLU]; + l3[i].r = inl[i][RED]; + l3[i].g = inl[i][GRN]; + l3[i].b = inl[i][BLU]; } } @@ -349,7 +361,7 @@ colormap map; register int i, val; for (i = 0; i < 256; i++) { - val = pow(i/256.0, 1.0/gamma) * 256.0; + val = pow((i+0.5)/256.0, 1.0/gamma) * 256.0; map[0][i] = map[1][i] = map[2][i] = val; } }
