--- ray/src/px/ra_pr.c 1989/02/02 10:49:35 1.1 +++ ray/src/px/ra_pr.c 1991/12/19 14:52:14 2.2 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -13,10 +13,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include -#include +#include "rasterfile.h" #include "color.h" +#include "resolu.h" + #include "pic.h" /* descriptor for a picture file or frame buffer */ @@ -37,17 +39,19 @@ extern char *ecalloc(), *emalloc(); extern long ftell(); -extern double atof(), pow(); +extern double pow(); -double gamma = 2.0; /* gamma correction */ +double gamma = 2.2; /* gamma correction */ +int bradj = 0; /* brightness adjustment */ + pic *inpic, *outpic; char *progname; char errmsg[128]; -COLR *inline; +COLR *inl; int xmax, ymax; @@ -78,6 +82,11 @@ char *argv[]; case 'b': greyscale = !greyscale; break; + case 'e': + if (argv[i+1][0] != '+' && argv[i+1][0] != '-') + goto userr; + bradj = atoi(argv[++i]); + break; case 'r': reverse = !reverse; break; @@ -102,7 +111,7 @@ char *argv[]; quiterr(errmsg); } /* get header */ - if (fread(&head, sizeof(head), 1, stdin) != 1) + if (fread((char *)&head, sizeof(head), 1, stdin) != 1) quiterr("missing header"); if (head.ras_magic != RAS_MAGIC) quiterr("bad raster format"); @@ -113,13 +122,14 @@ char *argv[]; head.ras_depth != 8) quiterr("incompatible format"); /* put header */ - printargs(argc, argv, stdout); + printargs(i, argv, stdout); + fputformat(COLRFMT, stdout); putchar('\n'); - printf("-Y %d +X %d\n", ymax, xmax); + fprtresolu(xmax, ymax, stdout); /* convert file */ pr2ra(&head); } else { - if (i > argc-1 || i < argc-2) + if (i < argc-2 || (!greyscale && i > argc-1)) goto userr; if ((inpic = openinput(argv[i], &head)) == NULL) { sprintf(errmsg, "can't open input \"%s\"", argv[i]); @@ -139,9 +149,9 @@ char *argv[]; quiterr(NULL); userr: fprintf(stderr, - "Usage: %s [-d][-c ncolors][-b][-g gamma] input [output]\n", + "Usage: %s [-d][-c ncolors][-b][-g gamma][-e +/-stops] input [output]\n", progname); - fprintf(stderr, " Or: %s -r [-g gamma] [input [output]]\n", + fprintf(stderr, " Or: %s -r [-g gamma][-e +/-stops] [input [output]]\n", progname); exit(1); } @@ -185,10 +195,10 @@ register struct rasterfile *h; p->fp = stdin; else if ((p->fp = fopen(fname, "r")) == NULL) return(NULL); - /* discard header */ - getheader(p->fp, NULL); - if (fscanf(p->fp, "-Y %d +X %d\n", &ymax, &xmax) != 2) - quiterr("bad picture size"); + /* check header */ + if (checkheader(p->fp, COLRFMT, NULL) < 0 || + fgetresolu(&xmax, &ymax, p->fp) < 0) + quiterr("bad picture format"); p->nexty = 0; p->bytes_line = 0; /* variable length lines */ p->pos.y = (long *)ecalloc(ymax, sizeof(long)); @@ -203,7 +213,7 @@ register struct rasterfile *h; h->ras_maptype = RMT_EQUAL_RGB; h->ras_maplength = 256*3; /* allocate scanline */ - inline = (COLR *)emalloc(xmax*sizeof(COLR)); + inl = (COLR *)emalloc(xmax*sizeof(COLR)); return(p); } @@ -223,7 +233,7 @@ register struct rasterfile *h; else if ((p->fp = fopen(fname, "w")) == NULL) return(NULL); /* write header */ - fwrite(h, sizeof(*h), 1, p->fp); + fwrite((char *)h, sizeof(*h), 1, p->fp); p->nexty = -1; /* needs color map */ p->bytes_line = h->ras_width; p->pos.b = 0; @@ -243,7 +253,7 @@ struct rasterfile *h; scanline = (COLR *)emalloc(xmax*sizeof(COLR)); /* get color table */ for (i = 0; i < 3; i ++) - if (fread(cmap[i], h->ras_maplength/3, 1, stdin) != 1) + if (fread((char *)cmap[i], h->ras_maplength/3, 1, stdin) != 1) quiterr("error reading color table"); /* convert table */ for (i = 0; i < h->ras_maplength/3; i++) @@ -251,6 +261,8 @@ struct rasterfile *h; pow((cmap[0][i]+.5)/256.,gamma), pow((cmap[1][i]+.5)/256.,gamma), pow((cmap[2][i]+.5)/256.,gamma)); + if (bradj) + shiftcolrs(ctab, 256, bradj); /* convert file */ for (i = 0; i < ymax; i++) { for (j = 0; j < xmax; j++) { @@ -271,15 +283,13 @@ picreadline3(y, l3) /* read in 3-byte scanline */ int y; register rgbpixel *l3; { - register BYTE *l4; - register int shift, c; - int i; + register int i; - if (inpic->nexty != y) { /* find scanline */ + if (inpic->nexty != y) { /* find scanline */ if (inpic->bytes_line == 0) { if (inpic->pos.y[y] == 0) { while (inpic->nexty < y) { - if (freadcolrs(inline, xmax, inpic->fp) < 0) + if (freadcolrs(inl, xmax, inpic->fp) < 0) quiterr("read error in picreadline3"); inpic->pos.y[++inpic->nexty] = ftell(inpic->fp); } @@ -289,32 +299,15 @@ register rgbpixel *l3; quiterr("seek error in picreadline3"); } else if (inpic->bytes_line == 0 && inpic->pos.y[inpic->nexty] == 0) inpic->pos.y[inpic->nexty] = ftell(inpic->fp); - if (freadcolrs(inline, xmax, inpic->fp) < 0) /* read scanline */ + if (freadcolrs(inl, xmax, inpic->fp) < 0) /* read scanline */ quiterr("read error in picreadline3"); inpic->nexty = y+1; /* convert scanline */ - for (l4=inline[0], i=xmax; i--; l4+=4, l3++) { - shift = l4[EXP] - COLXS; - if (shift >= 8) { - l3->r = l3->g = l3->b = 255; - } else if (shift <= -8) { - l3->r = l3->g = l3->b = 0; - } else if (shift > 0) { - c = l4[RED] << shift; - l3->r = c > 255 ? 255 : c; - c = l4[GRN] << shift; - l3->g = c > 255 ? 255 : c; - c = l4[BLU] << shift; - l3->b = c > 255 ? 255 : c; - } else if (shift < 0) { - l3->r = l4[RED] >> -shift; - l3->g = l4[GRN] >> -shift; - l3->b = l4[BLU] >> -shift; - } else { - l3->r = l4[RED]; - l3->g = l4[GRN]; - l3->b = l4[BLU]; - } + normcolrs(inl, xmax, bradj); + for (i = 0; i < xmax; i++) { + l3[i].r = inl[i][RED]; + l3[i].g = inl[i][GRN]; + l3[i].b = inl[i][BLU]; } } @@ -333,7 +326,7 @@ register pixel *l; quiterr("seek error in picwriteline"); } /* write scanline */ - if (fwrite(l, sizeof(pixel), xmax, outpic->fp) != xmax) + if (fwrite((char *)l, sizeof(pixel), xmax, outpic->fp) != xmax) quiterr("write error in picwriteline"); if (xmax&1) /* on 16-bit boundary */ putc(l[xmax-1], outpic->fp); @@ -368,7 +361,7 @@ colormap map; register int i, val; for (i = 0; i < 256; i++) { - val = pow(i/256.0, 1.0/gamma) * 256.0; + val = pow((i+0.5)/256.0, 1.0/gamma) * 256.0; map[0][i] = map[1][i] = map[2][i] = val; } }
