root/radiance/ray/src/px/ra_pr.c
Sat Feb 22 02:07:28 2003 UTC (22 years, 4 months ago) by greg
Sun Feb 27 10:17:12 1994 UTC (31 years, 4 months ago) by greg
Fri Oct 30 09:08:31 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.3: +6 -6 lines
renamed gamma to gamcor to avoid conflict with math library
Fri Oct 2 16:25:33 1992 UTC (32 years, 8 months ago) by greg
Thu Dec 19 14:52:14 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 2.1
Tue Nov 12 16:05:09 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.13: +0 -0 lines
Diff to previous 1.13
Mon Nov 11 14:01:45 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.12: +4 -2 lines
Diff to previous 1.12
Mon Oct 14 17:09:36 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.11
changed default gamma correction to 2.2
Wed Aug 7 08:36:31 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.10: +14 -5 lines
Diff to previous 1.10
added -e +/-stops option
Thu Apr 18 14:35:38 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.9: +5 -4 lines
Diff to previous 1.9
Wed Nov 7 13:10:31 1990 UTC (34 years, 7 months ago) by greg
Diff to previous 1.8
minor improvement in gamma correction
Mon Mar 12 15:14:40 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.7: +8 -8 lines
Diff to previous 1.7
changed "inline" to "inl" for compiler compatibility
Fri Feb 9 13:59:19 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.6
changed arguments printed in header
Fri Jan 26 08:17:37 1990 UTC (35 years, 5 months ago) by greg
Diff to previous 1.5
Thu Jan 18 23:58:19 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.4: +4 -4 lines
Diff to previous 1.4
Fri Oct 20 20:36:04 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.3: +7 -26 lines
Diff to previous 1.3
change to color normalization calls
Tue Sep 12 13:04:34 1989 UTC (35 years, 9 months ago) by greg
Diff to previous 1.2
Fri Sep 1 12:07:48 1989 UTC (35 years, 10 months ago) by greg
made rasterfile.h local
Thu Feb 2 10:49:35 1989 UTC (36 years, 4 months ago) by greg
