Minor fix for reading grayscale images
Fixed byte ordering for 16-bit/channel PPM files
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -s and -b options for greyscale and high-precision output
minor compiler warning fixes
renamed gamma to avoid math library conflict
Changes for PC port
