1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ra_ppm.c,v 2.13 2006/01/06 06:40:53 greg Exp $"; |
3 |
#endif |
4 |
5 |
* program to convert between RADIANCE and Poskanzer Pixmaps |
6 |
7 |
8 |
#include <stdio.h> |
9 |
#include <math.h> |
10 |
#include <ctype.h> |
11 |
#include <time.h> |
12 |
13 |
#include "platform.h" |
14 |
#include "color.h" |
15 |
#include "resolu.h" |
16 |
17 |
#define fltv(i) (((i)+.5)/(maxval+1.)) |
18 |
int bradj = 0; /* brightness adjustment */ |
19 |
double gamcor = 2.2; /* gamma correction value */ |
20 |
int maxval = 255; /* maximum primary value */ |
21 |
char *progname; |
22 |
int xmax, ymax; |
23 |
24 |
typedef int colrscanf_t(COLR *scan, int len, FILE *fp); |
25 |
typedef int colorscanf_t(COLOR *scan, int len, FILE *fp); |
26 |
27 |
static colrscanf_t agryscan, bgryscan, aclrscan, bclrscan; |
28 |
static void ppm2ra(colrscanf_t *getscan); |
29 |
static void ra2ppm(int binary, int grey); |
30 |
31 |
static colorscanf_t agryscan2, bgryscan2, aclrscan2, bclrscan2; |
32 |
static void ppm2ra2(colorscanf_t *getscan); |
33 |
static void ra2ppm2(int binary, int grey); |
34 |
35 |
static int normval(unsigned int v); |
36 |
static unsigned int scanint(FILE *fp); |
37 |
static unsigned int intv(double v); |
38 |
static unsigned int getby2(FILE *fp); |
39 |
static void putby2(unsigned int w, FILE *fp); |
40 |
static void quiterr(char *err); |
41 |
42 |
43 |
int |
44 |
main( |
45 |
int argc, |
46 |
char *argv[] |
47 |
48 |
49 |
char inpbuf[2]; |
50 |
int gryflag = 0; |
51 |
int binflag = 1; |
52 |
int reverse = 0; |
53 |
int ptype; |
54 |
int i; |
55 |
56 |
progname = argv[0]; |
57 |
58 |
for (i = 1; i < argc; i++) |
59 |
if (argv[i][0] == '-') |
60 |
switch (argv[i][1]) { |
61 |
case 's': |
62 |
maxval = atoi(argv[++i]) & 0xffff; |
63 |
break; |
64 |
case 'b': |
65 |
gryflag = 1; |
66 |
break; |
67 |
case 'g': |
68 |
gamcor = atof(argv[++i]); |
69 |
break; |
70 |
case 'e': |
71 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
72 |
goto userr; |
73 |
bradj = atoi(argv[++i]); |
74 |
break; |
75 |
case 'a': |
76 |
binflag = 0; |
77 |
break; |
78 |
case 'r': |
79 |
reverse = !reverse; |
80 |
break; |
81 |
default: |
82 |
goto userr; |
83 |
84 |
else |
85 |
break; |
86 |
87 |
if (i < argc-2) |
88 |
goto userr; |
89 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
90 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
91 |
progname, argv[i]); |
92 |
exit(1); |
93 |
94 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
95 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
96 |
progname, argv[i+1]); |
97 |
exit(1); |
98 |
99 |
if (maxval < 256) |
100 |
setcolrgam(gamcor); |
101 |
if (reverse) { |
102 |
/* get header */ |
103 |
if (read(fileno(stdin), inpbuf, 2) != 2 || inpbuf[0] != 'P') |
104 |
quiterr("input not a Poskanzer Pixmap"); |
105 |
ptype = inpbuf[1]; |
106 |
#ifdef _WIN32 |
107 |
if (ptype > 4) |
108 |
SET_FILE_BINARY(stdin); |
109 |
SET_FILE_BINARY(stdout); |
110 |
#endif |
111 |
xmax = scanint(stdin); |
112 |
ymax = scanint(stdin); |
113 |
maxval = scanint(stdin); |
114 |
/* put header */ |
115 |
newheader("RADIANCE", stdout); |
116 |
printargs(i, argv, stdout); |
117 |
fputformat(COLRFMT, stdout); |
118 |
putchar('\n'); |
119 |
fprtresolu(xmax, ymax, stdout); |
120 |
/* convert file */ |
121 |
if (maxval >= 256) |
122 |
switch (ptype) { |
123 |
case '2': |
124 |
ppm2ra2(agryscan2); |
125 |
break; |
126 |
case '5': |
127 |
ppm2ra2(bgryscan2); |
128 |
break; |
129 |
case '3': |
130 |
ppm2ra2(aclrscan2); |
131 |
break; |
132 |
case '6': |
133 |
ppm2ra2(bclrscan2); |
134 |
break; |
135 |
default: |
136 |
quiterr("unsupported Pixmap type"); |
137 |
138 |
else |
139 |
switch (ptype) { |
140 |
case '2': |
141 |
ppm2ra(agryscan); |
142 |
break; |
143 |
case '5': |
144 |
ppm2ra(bgryscan); |
145 |
break; |
146 |
case '3': |
147 |
ppm2ra(aclrscan); |
148 |
break; |
149 |
case '6': |
150 |
ppm2ra(bclrscan); |
151 |
break; |
152 |
default: |
153 |
154 |
155 |
} else { |
156 |
#ifdef _WIN32 |
157 |
158 |
if (binflag) |
159 |
160 |
#endif |
161 |
/* get header info. */ |
162 |
if (checkheader(stdin, COLRFMT, NULL) < 0 || |
163 |
fgetresolu(&xmax, &ymax, stdin) < 0) |
164 |
quiterr("bad picture format"); |
165 |
/* write PPM header */ |
166 |
printf("P%1d\n%d %d\n%u\n", (gryflag?2:3)+(binflag?3:0), |
167 |
xmax, ymax, maxval); |
168 |
169 |
170 |
ra2ppm2(binflag, gryflag); |
171 |
else |
172 |
ra2ppm(binflag, gryflag); |
173 |
174 |
exit(0); |
175 |
userr: |
176 |
fprintf(stderr, |
177 |
"Usage: %s [-r][-a][-b][-s maxv][-g gamma][-e +/-stops] [input [output]]\n", |
178 |
progname); |
179 |
exit(1); |
180 |
181 |
182 |
183 |
static void |
184 |
quiterr( /* print message and exit */ |
185 |
char *err |
186 |
187 |
188 |
if (err != NULL) { |
189 |
fprintf(stderr, "%s: %s\n", progname, err); |
190 |
exit(1); |
191 |
192 |
exit(0); |
193 |
194 |
195 |
196 |
static void |
197 |
ppm2ra( /* convert 1-byte Pixmap to Radiance picture */ |
198 |
colrscanf_t *getscan |
199 |
200 |
201 |
COLR *scanout; |
202 |
int y; |
203 |
/* allocate scanline */ |
204 |
scanout = (COLR *)malloc(xmax*sizeof(COLR)); |
205 |
if (scanout == NULL) |
206 |
quiterr("out of memory in ppm2ra"); |
207 |
/* convert image */ |
208 |
for (y = ymax-1; y >= 0; y--) { |
209 |
if ((*getscan)(scanout, xmax, stdin) < 0) |
210 |
quiterr("error reading Pixmap"); |
211 |
gambs_colrs(scanout, xmax); |
212 |
if (bradj) |
213 |
shiftcolrs(scanout, xmax, bradj); |
214 |
if (fwritecolrs(scanout, xmax, stdout) < 0) |
215 |
quiterr("error writing Radiance picture"); |
216 |
217 |
/* free scanline */ |
218 |
free((void *)scanout); |
219 |
220 |
221 |
222 |
static void |
223 |
ra2ppm( /* convert Radiance picture to 1-byte/sample Pixmap */ |
224 |
int binary, |
225 |
int grey |
226 |
227 |
228 |
COLR *scanin; |
229 |
register int x; |
230 |
int y; |
231 |
232 |
scanin = (COLR *)malloc(xmax*sizeof(COLR)); |
233 |
if (scanin == NULL) |
234 |
quiterr("out of memory in ra2ppm"); |
235 |
236 |
237 |
if (freadcolrs(scanin, xmax, stdin) < 0) |
238 |
quiterr("error reading Radiance picture"); |
239 |
if (bradj) |
240 |
shiftcolrs(scanin, xmax, bradj); |
241 |
for (x = grey?xmax:0; x--; ) |
242 |
scanin[x][GRN] = normbright(scanin[x]); |
243 |
colrs_gambs(scanin, xmax); |
244 |
if (grey) |
245 |
if (binary) |
246 |
for (x = 0; x < xmax; x++) |
247 |
putc(scanin[x][GRN], stdout); |
248 |
else |
249 |
250 |
printf("%d\n", scanin[x][GRN]); |
251 |
else |
252 |
if (binary) |
253 |
for (x = 0; x < xmax; x++) { |
254 |
putc(scanin[x][RED], stdout); |
255 |
256 |
putc(scanin[x][BLU], stdout); |
257 |
258 |
else |
259 |
260 |
printf("%d %d %d\n", scanin[x][RED], |
261 |
scanin[x][GRN], |
262 |
scanin[x][BLU]); |
263 |
if (ferror(stdout)) |
264 |
quiterr("error writing Pixmap"); |
265 |
266 |
267 |
free((void *)scanin); |
268 |
269 |
270 |
271 |
static void |
272 |
ppm2ra2( /* convert 2-byte Pixmap to Radiance picture */ |
273 |
colorscanf_t *getscan |
274 |
275 |
276 |
COLOR *scanout; |
277 |
double mult; |
278 |
int y; |
279 |
register int x; |
280 |
281 |
scanout = (COLOR *)malloc(xmax*sizeof(COLOR)); |
282 |
283 |
quiterr("out of memory in ppm2ra2"); |
284 |
if (bradj) |
285 |
mult = pow(2., (double)bradj); |
286 |
287 |
288 |
289 |
290 |
for (x = (gamcor>1.01)|(gamcor<0.99)?xmax:0; x--; ) { |
291 |
colval(scanout[x],RED) = |
292 |
pow(colval(scanout[x],RED), gamcor); |
293 |
colval(scanout[x],GRN) = |
294 |
pow(colval(scanout[x],GRN), gamcor); |
295 |
colval(scanout[x],BLU) = |
296 |
pow(colval(scanout[x],BLU), gamcor); |
297 |
298 |
for (x = bradj?xmax:0; x--; ) |
299 |
scalecolor(scanout[x], mult); |
300 |
if (fwritescan(scanout, xmax, stdout) < 0) |
301 |
302 |
303 |
304 |
305 |
306 |
307 |
308 |
static void |
309 |
ra2ppm2( /* convert Radiance picture to Pixmap (2-byte) */ |
310 |
int binary, |
311 |
int grey |
312 |
313 |
314 |
COLOR *scanin; |
315 |
double mult, d; |
316 |
register int x; |
317 |
int y; |
318 |
319 |
scanin = (COLOR *)malloc(xmax*sizeof(COLOR)); |
320 |
321 |
quiterr("out of memory in ra2ppm2"); |
322 |
if (bradj) |
323 |
324 |
325 |
326 |
if (freadscan(scanin, xmax, stdin) < 0) |
327 |
328 |
329 |
scalecolor(scanin[x], mult); |
330 |
331 |
colval(scanin[x],GRN) = bright(scanin[x]); |
332 |
d = 1./gamcor; |
333 |
for (x = (d>1.01)|(d<0.99)?xmax:0; x--; ) { |
334 |
colval(scanin[x],GRN) = pow(colval(scanin[x],GRN), d); |
335 |
if (!grey) { |
336 |
colval(scanin[x],RED) = |
337 |
pow(colval(scanin[x],RED), d); |
338 |
colval(scanin[x],BLU) = |
339 |
pow(colval(scanin[x],BLU), d); |
340 |
341 |
342 |
if (grey) |
343 |
if (binary) |
344 |
345 |
putby2(intv(colval(scanin[x],GRN)), |
346 |
stdout); |
347 |
else |
348 |
349 |
printf("%u\n", |
350 |
intv(colval(scanin[x],GRN))); |
351 |
else |
352 |
if (binary) |
353 |
354 |
putby2(intv(colval(scanin[x],RED)), |
355 |
stdout); |
356 |
357 |
stdout); |
358 |
putby2(intv(colval(scanin[x],BLU)), |
359 |
stdout); |
360 |
361 |
else |
362 |
363 |
printf("%u %u %u\n", |
364 |
365 |
366 |
intv(colval(scanin[x],BLU))); |
367 |
368 |
369 |
370 |
371 |
372 |
373 |
374 |
375 |
static int |
376 |
agryscan( /* get an ASCII greyscale scanline */ |
377 |
register COLR *scan, |
378 |
register int len, |
379 |
FILE *fp |
380 |
381 |
382 |
while (len-- > 0) { |
383 |
scan[0][RED] = |
384 |
scan[0][GRN] = |
385 |
scan[0][BLU] = normval(scanint(fp)); |
386 |
scan++; |
387 |
388 |
return(0); |
389 |
390 |
391 |
392 |
static int |
393 |
bgryscan( /* get a binary greyscale scanline */ |
394 |
395 |
int len, |
396 |
register FILE *fp |
397 |
398 |
399 |
register int c; |
400 |
401 |
402 |
if ((c = getc(fp)) == EOF) |
403 |
return(-1); |
404 |
if (maxval != 255) |
405 |
c = normval(c); |
406 |
scan[0][RED] = |
407 |
scan[0][GRN] = |
408 |
scan[0][BLU] = c; |
409 |
scan++; |
410 |
411 |
return(0); |
412 |
413 |
414 |
415 |
static int |
416 |
aclrscan( /* get an ASCII color scanline */ |
417 |
418 |
register int len, |
419 |
FILE *fp |
420 |
421 |
422 |
423 |
scan[0][RED] = normval(scanint(fp)); |
424 |
scan[0][GRN] = normval(scanint(fp)); |
425 |
426 |
scan++; |
427 |
428 |
return(0); |
429 |
430 |
431 |
432 |
static int |
433 |
bclrscan( /* get a binary color scanline */ |
434 |
435 |
int len, |
436 |
register FILE *fp |
437 |
438 |
439 |
int r, g, b; |
440 |
441 |
442 |
r = getc(fp); |
443 |
g = getc(fp); |
444 |
if ((b = getc(fp)) == EOF) |
445 |
return(-1); |
446 |
if (maxval == 255) { |
447 |
scan[0][RED] = r; |
448 |
scan[0][GRN] = g; |
449 |
scan[0][BLU] = b; |
450 |
} else { |
451 |
scan[0][RED] = normval(r); |
452 |
scan[0][GRN] = normval(g); |
453 |
scan[0][BLU] = normval(b); |
454 |
455 |
scan++; |
456 |
457 |
return(0); |
458 |
459 |
460 |
461 |
static int |
462 |
agryscan2( /* get an ASCII greyscale scanline */ |
463 |
register COLOR *scan, |
464 |
register int len, |
465 |
FILE *fp |
466 |
467 |
468 |
469 |
colval(scan[0],RED) = |
470 |
colval(scan[0],GRN) = |
471 |
colval(scan[0],BLU) = fltv(scanint(fp)); |
472 |
scan++; |
473 |
474 |
return(0); |
475 |
476 |
477 |
478 |
static int |
479 |
bgryscan2( /* get a binary greyscale scanline */ |
480 |
481 |
int len, |
482 |
register FILE *fp |
483 |
484 |
485 |
register int c; |
486 |
487 |
488 |
if ((c = getby2(fp)) == EOF) |
489 |
return(-1); |
490 |
491 |
492 |
colval(scan[0],BLU) = fltv(c); |
493 |
scan++; |
494 |
495 |
return(0); |
496 |
497 |
498 |
499 |
static int |
500 |
aclrscan2( /* get an ASCII color scanline */ |
501 |
502 |
register int len, |
503 |
FILE *fp |
504 |
505 |
506 |
507 |
colval(scan[0],RED) = fltv(scanint(fp)); |
508 |
colval(scan[0],GRN) = fltv(scanint(fp)); |
509 |
510 |
scan++; |
511 |
512 |
return(0); |
513 |
514 |
515 |
516 |
static int |
517 |
bclrscan2( /* get a binary color scanline */ |
518 |
519 |
int len, |
520 |
register FILE *fp |
521 |
522 |
523 |
int r, g, b; |
524 |
525 |
526 |
r = getby2(fp); |
527 |
g = getby2(fp); |
528 |
if ((b = getby2(fp)) == EOF) |
529 |
return(-1); |
530 |
scan[0][RED] = fltv(r); |
531 |
scan[0][GRN] = fltv(g); |
532 |
scan[0][BLU] = fltv(b); |
533 |
scan++; |
534 |
535 |
return(0); |
536 |
537 |
538 |
539 |
static unsigned int |
540 |
scanint( /* scan the next positive integer value */ |
541 |
register FILE *fp |
542 |
543 |
544 |
register int c; |
545 |
register unsigned int i; |
546 |
tryagain: |
547 |
while (isspace(c = getc(fp))) |
548 |
549 |
if (c == EOF) |
550 |
quiterr("unexpected end of file"); |
551 |
if (c == '#') { /* comment */ |
552 |
while ((c = getc(fp)) != EOF && c != '\n') |
553 |
554 |
goto tryagain; |
555 |
556 |
/* should be integer */ |
557 |
i = 0; |
558 |
do { |
559 |
if (!isdigit(c)) |
560 |
quiterr("error reading integer"); |
561 |
i = 10*i + c - '0'; |
562 |
c = getc(fp); |
563 |
} while (c != EOF && !isspace(c)); |
564 |
return(i); |
565 |
566 |
567 |
568 |
static int |
569 |
normval( /* normalize a value to [0,255] */ |
570 |
register unsigned int v |
571 |
572 |
573 |
if (v >= maxval) |
574 |
return(255); |
575 |
if (maxval == 255) |
576 |
return(v); |
577 |
return(v*255L/maxval); |
578 |
579 |
580 |
581 |
582 |
getby2( /* return 2-byte quantity from fp */ |
583 |
register FILE *fp |
584 |
585 |
586 |
register int lowerb, upperb; |
587 |
588 |
upperb = getc(fp); |
589 |
lowerb = getc(fp); |
590 |
if (lowerb == EOF) |
591 |
return(EOF); |
592 |
return(upperb<<8 | lowerb); |
593 |
594 |
595 |
596 |
static void |
597 |
putby2( /* put 2-byte quantity to fp */ |
598 |
register unsigned int w, |
599 |
register FILE *fp |
600 |
601 |
602 |
putc(w>>8 & 0xff, fp); |
603 |
putc(w & 0xff, fp); |
604 |
if (ferror(fp)) { |
605 |
fprintf(stderr, "%s: write error on PPM output\n", progname); |
606 |
exit(1); |
607 |
608 |
609 |
610 |
611 |
612 |
intv( /* return integer quantity for v */ |
613 |
register double v |
614 |
615 |
616 |
if (v >= 0.99999) |
617 |
return(maxval); |
618 |
if (v <= 0.) |
619 |
return(0); |
620 |
return((int)(v*(maxval+1))); |
621 |
