1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* program to convert between RADIANCE and Poskanzer Pixmaps |
6 |
7 |
8 |
#include <stdio.h> |
9 |
10 |
#ifdef MSDOS |
11 |
#include <fcntl.h> |
12 |
#endif |
13 |
14 |
#include <math.h> |
15 |
16 |
#include <ctype.h> |
17 |
18 |
#include <time.h> |
19 |
20 |
#include "color.h" |
21 |
22 |
#include "resolu.h" |
23 |
24 |
25 |
int agryscan(), bgryscan(), aclrscan(), bclrscan(); |
26 |
int agryscan2(), bgryscan2(), aclrscan2(), bclrscan2(); |
27 |
int normval(); |
28 |
unsigned int scanint(), intv(), getby2(); |
29 |
30 |
#define fltv(i) (((i)+.5)/(maxval+1.)) |
31 |
32 |
int bradj = 0; /* brightness adjustment */ |
33 |
34 |
double gamcor = 2.2; /* gamma correction value */ |
35 |
36 |
int maxval = 255; /* maximum primary value */ |
37 |
38 |
char *progname; |
39 |
40 |
int xmax, ymax; |
41 |
42 |
43 |
main(argc, argv) |
44 |
int argc; |
45 |
char *argv[]; |
46 |
47 |
char inpbuf[2]; |
48 |
int gryflag = 0; |
49 |
int binflag = 1; |
50 |
int reverse = 0; |
51 |
int ptype; |
52 |
int i; |
53 |
54 |
progname = argv[0]; |
55 |
56 |
for (i = 1; i < argc; i++) |
57 |
if (argv[i][0] == '-') |
58 |
switch (argv[i][1]) { |
59 |
case 's': |
60 |
maxval = atoi(argv[++i]) & 0xffff; |
61 |
break; |
62 |
case 'b': |
63 |
gryflag = 1; |
64 |
break; |
65 |
case 'g': |
66 |
gamcor = atof(argv[++i]); |
67 |
break; |
68 |
case 'e': |
69 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
70 |
goto userr; |
71 |
bradj = atoi(argv[++i]); |
72 |
break; |
73 |
case 'a': |
74 |
binflag = 0; |
75 |
break; |
76 |
case 'r': |
77 |
reverse = !reverse; |
78 |
break; |
79 |
default: |
80 |
goto userr; |
81 |
82 |
else |
83 |
break; |
84 |
85 |
if (i < argc-2) |
86 |
goto userr; |
87 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) { |
88 |
fprintf(stderr, "%s: can't open input \"%s\"\n", |
89 |
progname, argv[i]); |
90 |
exit(1); |
91 |
92 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { |
93 |
fprintf(stderr, "%s: can't open output \"%s\"\n", |
94 |
progname, argv[i+1]); |
95 |
exit(1); |
96 |
97 |
if (maxval < 256) |
98 |
setcolrgam(gamcor); |
99 |
if (reverse) { |
100 |
/* get header */ |
101 |
if (read(fileno(stdin), inpbuf, 2) != 2 || inpbuf[0] != 'P') |
102 |
quiterr("input not a Poskanzer Pixmap"); |
103 |
ptype = inpbuf[1]; |
104 |
#ifdef MSDOS |
105 |
if (ptype > 4) |
106 |
setmode(fileno(stdin), O_BINARY); |
107 |
setmode(fileno(stdout), O_BINARY); |
108 |
#endif |
109 |
xmax = scanint(stdin); |
110 |
ymax = scanint(stdin); |
111 |
maxval = scanint(stdin); |
112 |
/* put header */ |
113 |
newheader("RADIANCE", stdout); |
114 |
printargs(i, argv, stdout); |
115 |
fputformat(COLRFMT, stdout); |
116 |
putchar('\n'); |
117 |
fprtresolu(xmax, ymax, stdout); |
118 |
/* convert file */ |
119 |
if (maxval >= 256) |
120 |
switch (ptype) { |
121 |
case '2': |
122 |
ppm2ra2(agryscan2); |
123 |
break; |
124 |
case '5': |
125 |
ppm2ra2(bgryscan2); |
126 |
break; |
127 |
case '3': |
128 |
ppm2ra2(aclrscan2); |
129 |
break; |
130 |
case '6': |
131 |
ppm2ra2(bclrscan2); |
132 |
break; |
133 |
default: |
134 |
quiterr("unsupported Pixmap type"); |
135 |
136 |
else |
137 |
switch (ptype) { |
138 |
case '2': |
139 |
ppm2ra(agryscan); |
140 |
break; |
141 |
case '5': |
142 |
ppm2ra(bgryscan); |
143 |
break; |
144 |
case '3': |
145 |
ppm2ra(aclrscan); |
146 |
break; |
147 |
case '6': |
148 |
ppm2ra(bclrscan); |
149 |
break; |
150 |
default: |
151 |
152 |
153 |
} else { |
154 |
#ifdef MSDOS |
155 |
156 |
if (binflag) |
157 |
158 |
#endif |
159 |
/* get header info. */ |
160 |
if (checkheader(stdin, COLRFMT, NULL) < 0 || |
161 |
fgetresolu(&xmax, &ymax, stdin) < 0) |
162 |
quiterr("bad picture format"); |
163 |
/* write PPM header */ |
164 |
printf("P%1d\n%d %d\n%u\n", (gryflag?2:3)+(binflag?3:0), |
165 |
xmax, ymax, maxval); |
166 |
167 |
168 |
ra2ppm2(binflag, gryflag); |
169 |
else |
170 |
ra2ppm(binflag, gryflag); |
171 |
172 |
exit(0); |
173 |
userr: |
174 |
fprintf(stderr, |
175 |
"Usage: %s [-r][-a][-b][-s maxv][-g gamma][-e +/-stops] [input [output]]\n", |
176 |
progname); |
177 |
exit(1); |
178 |
179 |
180 |
181 |
quiterr(err) /* print message and exit */ |
182 |
char *err; |
183 |
184 |
if (err != NULL) { |
185 |
fprintf(stderr, "%s: %s\n", progname, err); |
186 |
exit(1); |
187 |
188 |
exit(0); |
189 |
190 |
191 |
192 |
ppm2ra(getscan) /* convert 1-byte Pixmap to Radiance picture */ |
193 |
int (*getscan)(); |
194 |
195 |
COLR *scanout; |
196 |
int y; |
197 |
/* allocate scanline */ |
198 |
scanout = (COLR *)malloc(xmax*sizeof(COLR)); |
199 |
if (scanout == NULL) |
200 |
quiterr("out of memory in ppm2ra"); |
201 |
/* convert image */ |
202 |
for (y = ymax-1; y >= 0; y--) { |
203 |
if ((*getscan)(scanout, xmax, stdin) < 0) |
204 |
quiterr("error reading Pixmap"); |
205 |
gambs_colrs(scanout, xmax); |
206 |
if (bradj) |
207 |
shiftcolrs(scanout, xmax, bradj); |
208 |
if (fwritecolrs(scanout, xmax, stdout) < 0) |
209 |
quiterr("error writing Radiance picture"); |
210 |
211 |
/* free scanline */ |
212 |
free((void *)scanout); |
213 |
214 |
215 |
216 |
ra2ppm(binary, grey) /* convert Radiance picture to Pixmap */ |
217 |
int binary, grey; |
218 |
219 |
COLR *scanin; |
220 |
register int x; |
221 |
int y; |
222 |
223 |
scanin = (COLR *)malloc(xmax*sizeof(COLR)); |
224 |
if (scanin == NULL) |
225 |
quiterr("out of memory in ra2ppm"); |
226 |
227 |
228 |
if (freadcolrs(scanin, xmax, stdin) < 0) |
229 |
quiterr("error reading Radiance picture"); |
230 |
if (bradj) |
231 |
shiftcolrs(scanin, xmax, bradj); |
232 |
for (x = grey?xmax:0; x--; ) |
233 |
scanin[x][GRN] = normbright(scanin[x]); |
234 |
colrs_gambs(scanin, xmax); |
235 |
if (grey) |
236 |
if (binary) |
237 |
for (x = 0; x < xmax; x++) |
238 |
putc(scanin[x][GRN], stdout); |
239 |
else |
240 |
241 |
printf("%d\n", scanin[x][GRN]); |
242 |
else |
243 |
if (binary) |
244 |
for (x = 0; x < xmax; x++) { |
245 |
putc(scanin[x][RED], stdout); |
246 |
247 |
putc(scanin[x][BLU], stdout); |
248 |
249 |
else |
250 |
251 |
printf("%d %d %d\n", scanin[x][RED], |
252 |
scanin[x][GRN], |
253 |
scanin[x][BLU]); |
254 |
if (ferror(stdout)) |
255 |
quiterr("error writing Pixmap"); |
256 |
257 |
258 |
free((void *)scanin); |
259 |
260 |
261 |
262 |
ppm2ra2(getscan) /* convert 2-byte Pixmap to Radiance picture */ |
263 |
int (*getscan)(); |
264 |
265 |
COLOR *scanout; |
266 |
double mult; |
267 |
int y; |
268 |
register int x; |
269 |
270 |
scanout = (COLOR *)malloc(xmax*sizeof(COLOR)); |
271 |
272 |
quiterr("out of memory in ppm2ra2"); |
273 |
if (bradj) |
274 |
mult = pow(2., (double)bradj); |
275 |
276 |
277 |
278 |
279 |
for (x = gamcor>1.01|gamcor<0.99?xmax:0; x--; ) { |
280 |
colval(scanout[x],RED) = |
281 |
pow(colval(scanout[x],RED), gamcor); |
282 |
colval(scanout[x],GRN) = |
283 |
pow(colval(scanout[x],GRN), gamcor); |
284 |
colval(scanout[x],BLU) = |
285 |
pow(colval(scanout[x],BLU), gamcor); |
286 |
287 |
for (x = bradj?xmax:0; x--; ) |
288 |
scalecolor(scanout[x], mult); |
289 |
if (fwritescan(scanout, xmax, stdout) < 0) |
290 |
291 |
292 |
293 |
294 |
295 |
296 |
297 |
ra2ppm2(binary, grey) /* convert Radiance picture to Pixmap (2-byte) */ |
298 |
int binary, grey; |
299 |
300 |
COLOR *scanin; |
301 |
double mult, d; |
302 |
register int x; |
303 |
int y; |
304 |
305 |
scanin = (COLOR *)malloc(xmax*sizeof(COLOR)); |
306 |
307 |
quiterr("out of memory in ra2ppm2"); |
308 |
if (bradj) |
309 |
310 |
311 |
312 |
if (freadscan(scanin, xmax, stdin) < 0) |
313 |
314 |
315 |
scalecolor(scanin[x], mult); |
316 |
317 |
colval(scanin[x],GRN) = bright(scanin[x]); |
318 |
d = 1./gamcor; |
319 |
for (x = d>1.01|d<0.99?xmax:0; x--; ) { |
320 |
colval(scanin[x],GRN) = pow(colval(scanin[x],GRN), d); |
321 |
if (!grey) { |
322 |
colval(scanin[x],RED) = |
323 |
pow(colval(scanin[x],RED), d); |
324 |
colval(scanin[x],BLU) = |
325 |
pow(colval(scanin[x],BLU), d); |
326 |
327 |
328 |
if (grey) |
329 |
if (binary) |
330 |
331 |
putby2(intv(colval(scanin[x],GRN)), |
332 |
stdout); |
333 |
else |
334 |
335 |
printf("%u\n", |
336 |
intv(colval(scanin[x],GRN))); |
337 |
else |
338 |
if (binary) |
339 |
340 |
putby2(intv(colval(scanin[x],RED)), |
341 |
stdout); |
342 |
343 |
stdout); |
344 |
putby2(intv(colval(scanin[x],BLU)), |
345 |
stdout); |
346 |
347 |
else |
348 |
349 |
printf("%u %u %u\n", |
350 |
351 |
352 |
intv(colval(scanin[x],BLU))); |
353 |
354 |
355 |
356 |
357 |
358 |
359 |
360 |
361 |
agryscan(scan, len, fp) /* get an ASCII greyscale scanline */ |
362 |
register COLR *scan; |
363 |
register int len; |
364 |
FILE *fp; |
365 |
366 |
while (len-- > 0) { |
367 |
scan[0][RED] = |
368 |
scan[0][GRN] = |
369 |
scan[0][BLU] = normval(scanint(fp)); |
370 |
scan++; |
371 |
372 |
return(0); |
373 |
374 |
375 |
376 |
bgryscan(scan, len, fp) /* get a binary greyscale scanline */ |
377 |
378 |
int len; |
379 |
register FILE *fp; |
380 |
381 |
register int c; |
382 |
383 |
384 |
if ((c = getc(fp)) == EOF) |
385 |
return(-1); |
386 |
if (maxval != 255) |
387 |
c = normval(c); |
388 |
scan[0][RED] = |
389 |
scan[0][GRN] = |
390 |
scan[0][BLU] = c; |
391 |
scan++; |
392 |
393 |
return(0); |
394 |
395 |
396 |
397 |
aclrscan(scan, len, fp) /* get an ASCII color scanline */ |
398 |
399 |
register int len; |
400 |
FILE *fp; |
401 |
402 |
403 |
scan[0][RED] = normval(scanint(fp)); |
404 |
scan[0][GRN] = normval(scanint(fp)); |
405 |
406 |
scan++; |
407 |
408 |
return(0); |
409 |
410 |
411 |
412 |
bclrscan(scan, len, fp) /* get a binary color scanline */ |
413 |
414 |
int len; |
415 |
416 |
417 |
int r, g, b; |
418 |
419 |
420 |
r = getc(fp); |
421 |
g = getc(fp); |
422 |
if ((b = getc(fp)) == EOF) |
423 |
return(-1); |
424 |
if (maxval == 255) { |
425 |
scan[0][RED] = r; |
426 |
scan[0][GRN] = g; |
427 |
scan[0][BLU] = b; |
428 |
} else { |
429 |
scan[0][RED] = normval(r); |
430 |
scan[0][GRN] = normval(g); |
431 |
scan[0][BLU] = normval(b); |
432 |
433 |
scan++; |
434 |
435 |
return(0); |
436 |
437 |
438 |
439 |
agryscan2(scan, len, fp) /* get an ASCII greyscale scanline */ |
440 |
register COLOR *scan; |
441 |
register int len; |
442 |
FILE *fp; |
443 |
444 |
445 |
colval(scan[0],RED) = |
446 |
colval(scan[0],GRN) = |
447 |
colval(scan[0],BLU) = fltv(scanint(fp)); |
448 |
scan++; |
449 |
450 |
return(0); |
451 |
452 |
453 |
454 |
bgryscan2(scan, len, fp) /* get a binary greyscale scanline */ |
455 |
456 |
int len; |
457 |
458 |
459 |
register int c; |
460 |
461 |
462 |
if ((c = getby2(fp)) == EOF) |
463 |
return(-1); |
464 |
465 |
466 |
colval(scan[0],BLU) = fltv(c); |
467 |
scan++; |
468 |
469 |
return(0); |
470 |
471 |
472 |
473 |
aclrscan2(scan, len, fp) /* get an ASCII color scanline */ |
474 |
475 |
register int len; |
476 |
FILE *fp; |
477 |
478 |
479 |
colval(scan[0],RED) = fltv(scanint(fp)); |
480 |
colval(scan[0],GRN) = fltv(scanint(fp)); |
481 |
482 |
scan++; |
483 |
484 |
return(0); |
485 |
486 |
487 |
488 |
bclrscan2(scan, len, fp) /* get a binary color scanline */ |
489 |
490 |
int len; |
491 |
492 |
493 |
int r, g, b; |
494 |
495 |
496 |
r = getby2(fp); |
497 |
g = getby2(fp); |
498 |
if ((b = getby2(fp)) == EOF) |
499 |
return(-1); |
500 |
scan[0][RED] = fltv(r); |
501 |
scan[0][GRN] = fltv(g); |
502 |
scan[0][BLU] = fltv(b); |
503 |
scan++; |
504 |
505 |
return(0); |
506 |
507 |
508 |
509 |
unsigned int |
510 |
scanint(fp) /* scan the next positive integer value */ |
511 |
512 |
513 |
register int c; |
514 |
register unsigned int i; |
515 |
tryagain: |
516 |
while (isspace(c = getc(fp))) |
517 |
518 |
if (c == EOF) |
519 |
quiterr("unexpected end of file"); |
520 |
if (c == '#') { /* comment */ |
521 |
while ((c = getc(fp)) != EOF && c != '\n') |
522 |
523 |
goto tryagain; |
524 |
525 |
/* should be integer */ |
526 |
i = 0; |
527 |
do { |
528 |
if (!isdigit(c)) |
529 |
quiterr("error reading integer"); |
530 |
i = 10*i + c - '0'; |
531 |
c = getc(fp); |
532 |
} while (c != EOF && !isspace(c)); |
533 |
return(i); |
534 |
535 |
536 |
537 |
int |
538 |
normval(v) /* normalize a value to [0,255] */ |
539 |
register unsigned int v; |
540 |
541 |
if (v >= maxval) |
542 |
return(255); |
543 |
if (maxval == 255) |
544 |
return(v); |
545 |
return(v*255L/maxval); |
546 |
547 |
548 |
549 |
unsigned int |
550 |
getby2(fp) /* return 2-byte quantity from fp */ |
551 |
552 |
553 |
register int lowerb, upperb; |
554 |
555 |
lowerb = getc(fp); |
556 |
upperb = getc(fp); |
557 |
if (upperb == EOF) |
558 |
return(EOF); |
559 |
return(upperb<<8 | lowerb); |
560 |
561 |
562 |
563 |
putby2(w, fp) /* put 2-byte quantity to fp */ |
564 |
register unsigned int w; |
565 |
566 |
567 |
putc(w & 0xff, fp); |
568 |
putc(w>>8 & 0xff, fp); |
569 |
if (ferror(fp)) { |
570 |
fprintf(stderr, "%s: write error on PPM output\n", progname); |
571 |
exit(1); |
572 |
573 |
574 |
575 |
576 |
unsigned int |
577 |
intv(v) /* return integer quantity for v */ |
578 |
register double v; |
579 |
580 |
if (v >= 0.99999) |
581 |
return(maxval); |
582 |
if (v <= 0.) |
583 |
return(0); |
584 |
return((int)(v*(maxval+1))); |
585 |
