--- ray/src/px/ra_ppm.c 1992/09/21 12:14:55 2.3 +++ ray/src/px/ra_ppm.c 2004/03/28 20:33:14 2.12 @@ -1,46 +1,53 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ra_ppm.c,v 2.12 2004/03/28 20:33:14 schorsch Exp $"; #endif - /* * program to convert between RADIANCE and Poskanzer Pixmaps */ #include - -#ifdef MSDOS -#include -#endif - +#include #include +#include +#include "platform.h" #include "color.h" - #include "resolu.h" -extern double pow(); - -extern char *malloc(); - -int agryscan(), bgryscan(), aclrscan(), bclrscan(); - +#define fltv(i) (((i)+.5)/(maxval+1.)) int bradj = 0; /* brightness adjustment */ - +double gamcor = 2.2; /* gamma correction value */ int maxval = 255; /* maximum primary value */ - char *progname; - int xmax, ymax; +typedef int colrscanf_t(COLR *scan, int len, FILE *fp); +typedef int colorscanf_t(COLOR *scan, int len, FILE *fp); -main(argc, argv) -int argc; -char *argv[]; +static colrscanf_t agryscan, bgryscan, aclrscan, bclrscan; +static void ppm2ra(colrscanf_t *getscan); +static void ra2ppm(int binary, int grey); + +static colorscanf_t agryscan2, bgryscan2, aclrscan2, bclrscan2; +static void ppm2ra2(colorscanf_t *getscan); +static void ra2ppm2(int binary, int grey); + +static int normval(unsigned int v); +static unsigned int scanint(FILE *fp); +static unsigned int intv(double v); +static unsigned int getby2(FILE *fp); +static void putby2(unsigned int w, FILE *fp); +static void quiterr(char *err); + + +int +main( + int argc, + char *argv[] +) { char inpbuf[2]; - double gamma = 2.2; + int gryflag = 0; int binflag = 1; int reverse = 0; int ptype; @@ -51,8 +58,14 @@ char *argv[]; for (i = 1; i < argc; i++) if (argv[i][0] == '-') switch (argv[i][1]) { + case 's': + maxval = atoi(argv[++i]) & 0xffff; + break; + case 'b': + gryflag = 1; + break; case 'g': - gamma = atof(argv[++i]); + gamcor = atof(argv[++i]); break; case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-') @@ -79,73 +92,98 @@ char *argv[]; exit(1); } if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) { - fprintf(stderr, "can't open output \"%s\"\n", + fprintf(stderr, "%s: can't open output \"%s\"\n", progname, argv[i+1]); exit(1); } - setcolrgam(gamma); + if (maxval < 256) + setcolrgam(gamcor); if (reverse) { /* get header */ if (read(fileno(stdin), inpbuf, 2) != 2 || inpbuf[0] != 'P') quiterr("input not a Poskanzer Pixmap"); ptype = inpbuf[1]; -#ifdef MSDOS +#ifdef _WIN32 if (ptype > 4) - setmode(fileno(stdin), O_BINARY); - setmode(fileno(stdout), O_BINARY); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); #endif xmax = scanint(stdin); ymax = scanint(stdin); maxval = scanint(stdin); /* put header */ + newheader("RADIANCE", stdout); printargs(i, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); fprtresolu(xmax, ymax, stdout); /* convert file */ - switch (ptype) { - case '2': - ppm2ra(agryscan); - break; - case '5': - ppm2ra(bgryscan); - break; - case '3': - ppm2ra(aclrscan); - break; - case '6': - ppm2ra(bclrscan); - break; - default: - quiterr("unsupported Pixmap type"); - } + if (maxval >= 256) + switch (ptype) { + case '2': + ppm2ra2(agryscan2); + break; + case '5': + ppm2ra2(bgryscan2); + break; + case '3': + ppm2ra2(aclrscan2); + break; + case '6': + ppm2ra2(bclrscan2); + break; + default: + quiterr("unsupported Pixmap type"); + } + else + switch (ptype) { + case '2': + ppm2ra(agryscan); + break; + case '5': + ppm2ra(bgryscan); + break; + case '3': + ppm2ra(aclrscan); + break; + case '6': + ppm2ra(bclrscan); + break; + default: + quiterr("unsupported Pixmap type"); + } } else { -#ifdef MSDOS - setmode(fileno(stdin), O_BINARY); +#ifdef _WIN32 + SET_FILE_BINARY(stdin); if (binflag) - setmode(fileno(stdout), O_BINARY); + SET_FILE_BINARY(stdout); #endif /* get header info. */ if (checkheader(stdin, COLRFMT, NULL) < 0 || fgetresolu(&xmax, &ymax, stdin) < 0) quiterr("bad picture format"); /* write PPM header */ - printf("P%c\n%d %d\n%d\n", binflag ? '6' : '3', + printf("P%1d\n%d %d\n%u\n", (gryflag?2:3)+(binflag?3:0), xmax, ymax, maxval); /* convert file */ - ra2ppm(binflag); + if (maxval >= 256) + ra2ppm2(binflag, gryflag); + else + ra2ppm(binflag, gryflag); } exit(0); userr: fprintf(stderr, - "Usage: %s [-r][-a][-g gamma][-e +/-stops] [input [output]]\n", + "Usage: %s [-r][-a][-b][-s maxv][-g gamma][-e +/-stops] [input [output]]\n", progname); exit(1); } -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { if (err != NULL) { fprintf(stderr, "%s: %s\n", progname, err); @@ -155,11 +193,12 @@ char *err; } -ppm2ra(getscan) /* convert color Pixmap to Radiance picture */ -int (*getscan)(); +static void +ppm2ra( /* convert 1-byte Pixmap to Radiance picture */ + colrscanf_t *getscan +) { COLR *scanout; - register int x; int y; /* allocate scanline */ scanout = (COLR *)malloc(xmax*sizeof(COLR)); @@ -176,12 +215,15 @@ int (*getscan)(); quiterr("error writing Radiance picture"); } /* free scanline */ - free((char *)scanout); + free((void *)scanout); } -ra2ppm(binary) /* convert Radiance picture to Pixmap */ -int binary; +static void +ra2ppm( /* convert Radiance picture to Pixmap */ + int binary, + int grey +) { COLR *scanin; register int x; @@ -189,37 +231,153 @@ int binary; /* allocate scanline */ scanin = (COLR *)malloc(xmax*sizeof(COLR)); if (scanin == NULL) - quiterr("out of memory in ra2pr"); + quiterr("out of memory in ra2ppm"); /* convert image */ for (y = ymax-1; y >= 0; y--) { if (freadcolrs(scanin, xmax, stdin) < 0) quiterr("error reading Radiance picture"); if (bradj) shiftcolrs(scanin, xmax, bradj); + for (x = grey?xmax:0; x--; ) + scanin[x][GRN] = normbright(scanin[x]); colrs_gambs(scanin, xmax); - if (binary) - for (x = 0; x < xmax; x++) { - putc(scanin[x][RED], stdout); - putc(scanin[x][GRN], stdout); - putc(scanin[x][BLU], stdout); + if (grey) + if (binary) + for (x = 0; x < xmax; x++) + putc(scanin[x][GRN], stdout); + else + for (x = 0; x < xmax; x++) + printf("%d\n", scanin[x][GRN]); + else + if (binary) + for (x = 0; x < xmax; x++) { + putc(scanin[x][RED], stdout); + putc(scanin[x][GRN], stdout); + putc(scanin[x][BLU], stdout); + } + else + for (x = 0; x < xmax; x++) + printf("%d %d %d\n", scanin[x][RED], + scanin[x][GRN], + scanin[x][BLU]); + if (ferror(stdout)) + quiterr("error writing Pixmap"); + } + /* free scanline */ + free((void *)scanin); +} + + +static void +ppm2ra2( /* convert 2-byte Pixmap to Radiance picture */ + colorscanf_t *getscan +) +{ + COLOR *scanout; + double mult; + int y; + register int x; + /* allocate scanline */ + scanout = (COLOR *)malloc(xmax*sizeof(COLOR)); + if (scanout == NULL) + quiterr("out of memory in ppm2ra2"); + if (bradj) + mult = pow(2., (double)bradj); + /* convert image */ + for (y = ymax-1; y >= 0; y--) { + if ((*getscan)(scanout, xmax, stdin) < 0) + quiterr("error reading Pixmap"); + for (x = (gamcor>1.01)|(gamcor<0.99)?xmax:0; x--; ) { + colval(scanout[x],RED) = + pow(colval(scanout[x],RED), gamcor); + colval(scanout[x],GRN) = + pow(colval(scanout[x],GRN), gamcor); + colval(scanout[x],BLU) = + pow(colval(scanout[x],BLU), gamcor); + } + for (x = bradj?xmax:0; x--; ) + scalecolor(scanout[x], mult); + if (fwritescan(scanout, xmax, stdout) < 0) + quiterr("error writing Radiance picture"); + } + /* free scanline */ + free((void *)scanout); +} + + +static void +ra2ppm2( /* convert Radiance picture to Pixmap (2-byte) */ + int binary, + int grey +) +{ + COLOR *scanin; + double mult, d; + register int x; + int y; + /* allocate scanline */ + scanin = (COLOR *)malloc(xmax*sizeof(COLOR)); + if (scanin == NULL) + quiterr("out of memory in ra2ppm2"); + if (bradj) + mult = pow(2., (double)bradj); + /* convert image */ + for (y = ymax-1; y >= 0; y--) { + if (freadscan(scanin, xmax, stdin) < 0) + quiterr("error reading Radiance picture"); + for (x = bradj?xmax:0; x--; ) + scalecolor(scanin[x], mult); + for (x = grey?xmax:0; x--; ) + colval(scanin[x],GRN) = bright(scanin[x]); + d = 1./gamcor; + for (x = (d>1.01)|(d<0.99)?xmax:0; x--; ) { + colval(scanin[x],GRN) = pow(colval(scanin[x],GRN), d); + if (!grey) { + colval(scanin[x],RED) = + pow(colval(scanin[x],RED), d); + colval(scanin[x],BLU) = + pow(colval(scanin[x],BLU), d); } + } + if (grey) + if (binary) + for (x = 0; x < xmax; x++) + putby2(intv(colval(scanin[x],GRN)), + stdout); + else + for (x = 0; x < xmax; x++) + printf("%u\n", + intv(colval(scanin[x],GRN))); else - for (x = 0; x < xmax; x++) - printf("%d %d %d\n", scanin[x][RED], - scanin[x][GRN], - scanin[x][BLU]); + if (binary) + for (x = 0; x < xmax; x++) { + putby2(intv(colval(scanin[x],RED)), + stdout); + putby2(intv(colval(scanin[x],GRN)), + stdout); + putby2(intv(colval(scanin[x],BLU)), + stdout); + } + else + for (x = 0; x < xmax; x++) + printf("%u %u %u\n", + intv(colval(scanin[x],RED)), + intv(colval(scanin[x],GRN)), + intv(colval(scanin[x],BLU))); if (ferror(stdout)) quiterr("error writing Pixmap"); } /* free scanline */ - free((char *)scanin); + free((void *)scanin); } -agryscan(scan, len, fp) /* get an ASCII greyscale scanline */ -register COLR *scan; -register int len; -FILE *fp; +static int +agryscan( /* get an ASCII greyscale scanline */ + register COLR *scan, + register int len, + FILE *fp +) { while (len-- > 0) { scan[0][RED] = @@ -231,10 +389,12 @@ FILE *fp; } -bgryscan(scan, len, fp) /* get a binary greyscale scanline */ -register COLR *scan; -int len; -register FILE *fp; +static int +bgryscan( /* get a binary greyscale scanline */ + register COLR *scan, + int len, + register FILE *fp +) { register int c; @@ -252,10 +412,12 @@ register FILE *fp; } -aclrscan(scan, len, fp) /* get an ASCII color scanline */ -register COLR *scan; -register int len; -FILE *fp; +static int +aclrscan( /* get an ASCII color scanline */ + register COLR *scan, + register int len, + FILE *fp +) { while (len-- > 0) { scan[0][RED] = normval(scanint(fp)); @@ -267,10 +429,12 @@ FILE *fp; } -bclrscan(scan, len, fp) /* get a binary color scanline */ -register COLR *scan; -int len; -register FILE *fp; +static int +bclrscan( /* get a binary color scanline */ + register COLR *scan, + int len, + register FILE *fp +) { int r, g, b; @@ -294,11 +458,91 @@ register FILE *fp; } -int -scanint(fp) /* scan the next positive integer value */ -register FILE *fp; +static int +agryscan2( /* get an ASCII greyscale scanline */ + register COLOR *scan, + register int len, + FILE *fp +) { - register int i, c; + while (len-- > 0) { + colval(scan[0],RED) = + colval(scan[0],GRN) = + colval(scan[0],BLU) = fltv(scanint(fp)); + scan++; + } + return(0); +} + + +static int +bgryscan2( /* get a binary greyscale scanline */ + register COLOR *scan, + int len, + register FILE *fp +) +{ + register int c; + + while (len-- > 0) { + if ((c = getby2(fp)) == EOF) + return(-1); + colval(scan[0],RED) = + colval(scan[0],GRN) = + colval(scan[0],BLU) = fltv(c); + scan++; + } + return(0); +} + + +static int +aclrscan2( /* get an ASCII color scanline */ + register COLOR *scan, + register int len, + FILE *fp +) +{ + while (len-- > 0) { + colval(scan[0],RED) = fltv(scanint(fp)); + colval(scan[0],GRN) = fltv(scanint(fp)); + colval(scan[0],BLU) = fltv(scanint(fp)); + scan++; + } + return(0); +} + + +static int +bclrscan2( /* get a binary color scanline */ + register COLOR *scan, + int len, + register FILE *fp +) +{ + int r, g, b; + + while (len-- > 0) { + r = getby2(fp); + g = getby2(fp); + if ((b = getby2(fp)) == EOF) + return(-1); + scan[0][RED] = fltv(r); + scan[0][GRN] = fltv(g); + scan[0][BLU] = fltv(b); + scan++; + } + return(0); +} + + +static unsigned int +scanint( /* scan the next positive integer value */ + register FILE *fp +) +{ + register int c; + register unsigned int i; tryagain: while (isspace(c = getc(fp))) ; @@ -321,13 +565,57 @@ tryagain: } -int -normval(v) /* normalize a value to [0,255] */ -register int v; +static int +normval( /* normalize a value to [0,255] */ + register unsigned int v +) { if (v >= maxval) return(255); if (maxval == 255) return(v); return(v*255L/maxval); +} + + +static unsigned int +getby2( /* return 2-byte quantity from fp */ + register FILE *fp +) +{ + register int lowerb, upperb; + + lowerb = getc(fp); + upperb = getc(fp); + if (upperb == EOF) + return(EOF); + return(upperb<<8 | lowerb); +} + + +static void +putby2( /* put 2-byte quantity to fp */ + register unsigned int w, + register FILE *fp +) +{ + putc(w & 0xff, fp); + putc(w>>8 & 0xff, fp); + if (ferror(fp)) { + fprintf(stderr, "%s: write error on PPM output\n", progname); + exit(1); + } +} + + +static unsigned int +intv( /* return integer quantity for v */ + register double v +) +{ + if (v >= 0.99999) + return(maxval); + if (v <= 0.) + return(0); + return((int)(v*(maxval+1))); }
