root/radiance/ray/src/px/ra_ppm.c
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.16: +1 -3 lines
Tue Mar 20 18:45:04 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.15: +2 -1 lines
Added missing rtio.h include to redefine getc, putc, etc.
Sun Mar 6 01:13:17 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 2.14: +3 -3 lines
Mon May 26 17:58:33 2008 UTC (15 years, 11 months ago) by greg
Minor fix for reading grayscale images
Fri Jan 6 06:40:53 2006 UTC (18 years, 4 months ago) by greg
CVS Tags: rad3R8, rad3R9
Fixed byte ordering for 16-bit/channel PPM files
Changes since 2.11: +115 -72 lines
Changes since 2.9: +8 -15 lines
Changes since 2.8: +7 -10 lines
Wed Feb 10 08:43:41 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 2.7: +291 -37 lines
added -s and -b options for greyscale and high-precision output
Sun Feb 27 10:17:07 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.6: +1 -0 lines
Thu Nov 18 09:55:12 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.5: +1 -2 lines
minor compiler warning fixes
Mon Jul 12 12:41:15 1993 UTC (30 years, 10 months ago) by greg
renamed gamma to avoid math library conflict
Fri Oct 2 16:25:15 1992 UTC (31 years, 7 months ago) by greg
Mon Sep 21 12:14:55 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.2: +20 -3 lines
Changes for PC port
Thu Dec 19 14:52:11 1991 UTC (32 years, 5 months ago) by greg
Tue Nov 12 16:05:43 1991 UTC (32 years, 6 months ago) by greg
Mon Nov 11 14:01:32 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.1: +4 -2 lines
Fri Aug 16 12:41:59 1991 UTC (32 years, 9 months ago) by greg
Diff to selected 2.2
