root/radiance/ray/src/px/ra_pixar.c
Revision: 1.3
Committed: Tue Jan 16 09:11:40 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.2: +9 -1 lines
incorporated header read/write routines
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /* Copyright 1989 Regents of the University of California */
6
7 #ifndef lint
8 static char SCCSid[] = "@(#)ra_pixar.c 1.2 9/12/89 LBL";
9 #endif
10
11 /* ra_pixar.c */
12 /*
13 * convert from RADIANCE image file to PIXAR image file. (or vice versa)
14 *
15 * David G. Jones July 1989
16 */
17 /* External functions called:
18 *
19 * header.c:
20 * getheader(fp,func);
21 * printargs(argc,argv,fp);
22 * color.c:
23 * freadscan(scanline,len,fp);
24 * fwritescan(scanline,len,fp);
25 */
26
27 #include <stdio.h>
28 #include <math.h>
29
30 /* PIXAR */
31 #include <picio.h>
32 #include <pixeldef.h>
33 #include <chad.h>
34
35 /* RADIANCE (color.h conflicts with PIXAR includes) ugh!! */
36 #ifdef undef
37 #include "color.h"
38 #else
39 #define XDECR 1
40 #define YDECR 2
41 #define YMAJOR 4
42
43 #define RED 0
44 #define GRN 1
45 #define BLU 2
46 #define EXP 3
47 #define colval(col,pri) ((col)[pri])
48 #define setcolor(col,r,g,b) \
49 ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
50 typedef float COLOR[3]; /* red, green, blue */
51 #endif
52
53
54 char *ProgramName;
55 int global_argc;
56 char **global_argv;
57
58 /* RADIANCE global variables */
59 FILE *radiance_fp = NULL;
60 double radiance_pixel();
61
62 usage()
63 {
64 fprintf(stderr,"usage: %s radiance.pic pixar.pix\n",ProgramName);
65 fprintf(stderr," or %s -r pixar.pix radiance.pic\n",ProgramName);
66 exit(1);
67 }
68
69
70 main(argc,argv)
71 int argc;
72 char *argv[];
73 {
74 char *infile;
75 char *outfile;
76 int i;
77 int reverse = 0;
78
79 ProgramName=argv[0];
80 if (argc < 3)
81 usage();
82 infile=argv[argc-2];
83 outfile=argv[argc-1];
84 for (i=1; i < argc-2 ; ++i)
85 if (!strcmp(argv[i],"-r"))
86 reverse=1;
87 else
88 usage();
89
90 if (reverse)
91 {
92 global_argc=argc;
93 global_argv=argv;
94 pix_ra(infile,outfile);
95 }
96 else
97 ra_pix(infile,outfile);
98 }
99
100 ra_pix(infile,outfile)
101 char *infile;
102 char *outfile;
103 {
104 /* PIXAR variables */
105 RGBAPixelType *pixar_scanline;
106 PFILE *out;
107 /* RADIANCE variables */
108 COLOR *radiance_scanline;
109 /* regular variables */
110 int width;
111 int height;
112 register int x;
113 register int y;
114
115 /* get width, height from radiance file */
116 radiance_getsize(infile,&width,&height);
117 radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR));
118 pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType));
119 if (!radiance_scanline || !pixar_scanline)
120 {
121 fprintf(stderr,"not enough memory?\n");
122 perror("malloc");
123 exit(1);
124 }
125 bzero(pixar_scanline,width*sizeof(RGBAPixelType));
126
127 PicSetForce(1);
128 PicSetPsize(width,height);
129 PicSetTsize(width,height);
130 PicSetPformat(PF_RGB);
131 PicSetPstorage(PS_12DUMP);
132 PicSetPmatting(PM_NONE);
133 PicSetOffset(0,0);
134 PicSetLabel("converted from RADIANCE format by ra_pixar");
135 if (!(out=PicCreat(outfile,0666)))
136 {
137 fprintf(stderr,"can't open PIXAR image file `%s'\n",outfile);
138 perror("open");
139 exit(1);
140 }
141
142 picPreEncodeScanline(out,0);
143 for (y=0; y < height ; ++y)
144 {
145 radiance_readscanline(radiance_scanline,width);
146 for (x=0; x < width ; ++x)
147 {
148 SetRGBColor(&pixar_scanline[x],
149 DBL2PXL(radiance_pixel(radiance_scanline[x],RED)),
150 DBL2PXL(radiance_pixel(radiance_scanline[x],GRN)),
151 DBL2PXL(radiance_pixel(radiance_scanline[x],BLU)));
152 }
153 picEncodeScanline(out,pixar_scanline);
154 }
155 picPostEncodeScanline(out);
156 fclose(radiance_fp);
157 PicClose(out);
158 }
159
160
161 radiance_getsize(filename,w,h)
162 char *filename;
163 int *w;
164 int *h;
165 {
166 if (!(radiance_fp=fopen(filename,"r")))
167 {
168 fprintf(stderr,"can't open RADIANCE image file `%s'\n",filename);
169 perror("open");
170 exit(1);
171 }
172 getheader(radiance_fp,NULL);
173 if (fgetresolu(w, h, radiance_fp) != (YMAJOR|YDECR))
174 {
175 fprintf(stderr,"bad RADIANCE format\n");
176 exit(1);
177 }
178 }
179
180
181 radiance_readscanline(buf,x)
182 COLOR *buf;
183 int x;
184 {
185 if (freadscan(buf,x,radiance_fp) < 0)
186 {
187 fprintf(stderr,"read error?\n");
188 perror("fread");
189 exit(1);
190 }
191 }
192
193
194 double radiance_pixel(pixel,i)
195 COLOR pixel;
196 int i;
197 {
198 double value;
199
200 value=colval(pixel,i);
201 if (value < 0.0)
202 return 0.0;
203 else if (value> 1.0)
204 return 1.0;
205 return value;
206 }
207
208 pix_ra(infile,outfile)
209 char *infile;
210 char *outfile;
211 {
212 /* PIXAR variables */
213 RGBAPixelType *pixar_scanline;
214 PFILE *in;
215 /* RADIANCE variables */
216 COLOR *radiance_scanline;
217 FILE *out;
218 /* regular variables */
219 int width;
220 int height;
221 register int x;
222 register int y;
223
224 if (!(in=PicOpen(infile,"r")))
225 {
226 fprintf(stderr,"can't open PIXAR image file `%s'\n",infile);
227 perror("open");
228 exit(1);
229 }
230 if (!(out=fopen(outfile,"w")))
231 {
232 fprintf(stderr,"can't open RADIANCE image file `%s'\n",outfile);
233 perror("open");
234 exit(1);
235 }
236
237 /* get width, height from PIXAR file */
238 width=in->Pwidth;
239 height=in->Pheight;
240
241 /* allocate scan line space */
242 radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR));
243 pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType));
244 if (!radiance_scanline || !pixar_scanline)
245 {
246 fprintf(stderr,"not enough memory?\n");
247 perror("malloc");
248 exit(1);
249 }
250
251 /* write out the RADIANCE header */
252 radiance_writeheader(out,width,height);
253
254 picPreDecodeScanline(in,0);
255 for (y=0; y < height ; ++y)
256 {
257 picDecodeScanline(in,pixar_scanline);
258 for (x=0; x < width ; ++x)
259 {
260 setcolor(radiance_scanline[x],
261 PXL2DBL(pixar_scanline[x].Red),
262 PXL2DBL(pixar_scanline[x].Green),
263 PXL2DBL(pixar_scanline[x].Blue));
264 }
265 radiance_writescanline(out,radiance_scanline,width);
266 }
267 picPostDecodeScanline(in);
268 PicClose(in);
269 fclose(out);
270 }
271
272
273 radiance_writeheader(fp,x,y)
274 FILE *fp;
275 int x;
276 int y;
277 {
278 printargs(global_argc,global_argv,fp);
279 fputc('\n',fp);
280 fputresolu(YMAJOR|YDECR, x, y, fp);
281 fflush(fp);
282 }
283
284
285 radiance_writescanline(fp,buf,x)
286 FILE *fp;
287 COLOR *buf;
288 int x;
289 {
290 if (fwritescan(buf,x,fp) < 0)
291 {
292 fprintf(stderr,"write error?\n");
293 perror("fwrite");
294 exit(1);
295 }
296 }
