root/radiance/ray/src/px/ra_pixar.c
Revision: 2.2
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.1: +2 -4 lines
4 /* ra_pixar.c */
5 /*
6 * convert from RADIANCE image file to PIXAR image file. (or vice versa)
7 *
8 * David G. Jones July 1989
9 */
10 /* External functions called:
11 *
12 * header.c:
13 * getheader(fp,func);
14 * printargs(argc,argv,fp);
15 * color.c:
16 * freadscan(scanline,len,fp);
17 * fwritescan(scanline,len,fp);
18 */
19
20 #include <stdio.h>
21 #include <math.h>
22 #include <time.h>
23
24 /* PIXAR */
25 #include <picio.h>
26 #include <pixeldef.h>
27 #include <chad.h>
28
29 /* RADIANCE (color.h conflicts with PIXAR includes) ugh!! */
30 #ifdef undef
31 #include "color.h"
32 #else
33 #define RED 0
34 #define GRN 1
35 #define BLU 2
36 #define EXP 3
37 #define colval(col,pri) ((col)[pri])
38 #define setcolor(col,r,g,b) \
39 ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
40 typedef float COLOR[3]; /* red, green, blue */
41 #endif
42 #include "resolu.h"
43
44
45 char *ProgramName;
46 int global_argc;
47 char **global_argv;
48
49 /* RADIANCE global variables */
50 FILE *radiance_fp = NULL;
51 double radiance_pixel();
52
53 usage()
54 {
55 fprintf(stderr,"usage: %s radiance.pic pixar.pix\n",ProgramName);
56 fprintf(stderr," or %s -r pixar.pix radiance.pic\n",ProgramName);
57 exit(1);
58 }
59
60
61 main(argc,argv)
62 int argc;
63 char *argv[];
64 {
65 char *infile;
66 char *outfile;
67 int i;
68 int reverse = 0;
69
70 ProgramName=argv[0];
71 if (argc < 3)
72 usage();
73 infile=argv[argc-2];
74 outfile=argv[argc-1];
75 for (i=1; i < argc-2 ; ++i)
76 if (!strcmp(argv[i],"-r"))
77 reverse=1;
78 else
79 usage();
80
81 if (reverse)
82 {
83 global_argc=argc;
84 global_argv=argv;
85 pix_ra(infile,outfile);
86 }
87 else
88 ra_pix(infile,outfile);
89 }
90
91 ra_pix(infile,outfile)
92 char *infile;
93 char *outfile;
94 {
95 /* PIXAR variables */
96 RGBAPixelType *pixar_scanline;
97 PFILE *out;
98 /* RADIANCE variables */
99 COLOR *radiance_scanline;
100 /* regular variables */
101 int width;
102 int height;
103 register int x;
104 register int y;
105
106 /* get width, height from radiance file */
107 radiance_getsize(infile,&width,&height);
108 radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR));
109 pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType));
110 if (!radiance_scanline || !pixar_scanline)
111 {
112 fprintf(stderr,"not enough memory?\n");
113 perror("malloc");
114 exit(1);
115 }
116 bzero(pixar_scanline,width*sizeof(RGBAPixelType));
117
118 PicSetForce(1);
119 PicSetPsize(width,height);
120 PicSetTsize(width,height);
121 PicSetPformat(PF_RGB);
122 PicSetPstorage(PS_12DUMP);
123 PicSetPmatting(PM_NONE);
124 PicSetOffset(0,0);
125 PicSetLabel("converted from RADIANCE format by ra_pixar");
126 if (!(out=PicCreat(outfile,0666)))
127 {
128 fprintf(stderr,"can't open PIXAR image file `%s'\n",outfile);
129 perror("open");
130 exit(1);
131 }
132
133 picPreEncodeScanline(out,0);
134 for (y=0; y < height ; ++y)
135 {
136 radiance_readscanline(radiance_scanline,width);
137 for (x=0; x < width ; ++x)
138 {
139 SetRGBColor(&pixar_scanline[x],
140 DBL2PXL(radiance_pixel(radiance_scanline[x],RED)),
141 DBL2PXL(radiance_pixel(radiance_scanline[x],GRN)),
142 DBL2PXL(radiance_pixel(radiance_scanline[x],BLU)));
143 }
144 picEncodeScanline(out,pixar_scanline);
145 }
146 picPostEncodeScanline(out);
147 fclose(radiance_fp);
148 PicClose(out);
149 }
150
151
152 radiance_getsize(filename,w,h)
153 char *filename;
154 int *w;
155 int *h;
156 {
157 if (!(radiance_fp=fopen(filename,"r")))
158 {
159 fprintf(stderr,"can't open RADIANCE image file `%s'\n",filename);
160 perror("open");
161 exit(1);
162 }
163 getheader(radiance_fp,NULL);
164 if (fgetresolu(w, h, radiance_fp) < 0)
165 {
166 fprintf(stderr,"bad RADIANCE format\n");
167 exit(1);
168 }
169 }
170
171
172 radiance_readscanline(buf,x)
173 COLOR *buf;
174 int x;
175 {
176 if (freadscan(buf,x,radiance_fp) < 0)
177 {
178 fprintf(stderr,"read error?\n");
179 perror("fread");
180 exit(1);
181 }
182 }
183
184
185 double radiance_pixel(pixel,i)
186 COLOR pixel;
187 int i;
188 {
189 double value;
190
191 value=colval(pixel,i);
192 if (value < 0.0)
193 return 0.0;
194 else if (value> 1.0)
195 return 1.0;
196 return value;
197 }
198
199 pix_ra(infile,outfile)
200 char *infile;
201 char *outfile;
202 {
203 /* PIXAR variables */
204 RGBAPixelType *pixar_scanline;
205 PFILE *in;
206 /* RADIANCE variables */
207 COLOR *radiance_scanline;
208 FILE *out;
209 /* regular variables */
210 int width;
211 int height;
212 register int x;
213 register int y;
214
215 if (!(in=PicOpen(infile,"r")))
216 {
217 fprintf(stderr,"can't open PIXAR image file `%s'\n",infile);
218 perror("open");
219 exit(1);
220 }
221 if (!(out=fopen(outfile,"w")))
222 {
223 fprintf(stderr,"can't open RADIANCE image file `%s'\n",outfile);
224 perror("open");
225 exit(1);
226 }
227
228 /* get width, height from PIXAR file */
229 width=in->Pwidth;
230 height=in->Pheight;
231
232 /* allocate scan line space */
233 radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR));
234 pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType));
235 if (!radiance_scanline || !pixar_scanline)
236 {
237 fprintf(stderr,"not enough memory?\n");
238 perror("malloc");
239 exit(1);
240 }
241
242 /* write out the RADIANCE header */
243 radiance_writeheader(out,width,height);
244
245 picPreDecodeScanline(in,0);
246 for (y=0; y < height ; ++y)
247 {
248 picDecodeScanline(in,pixar_scanline);
249 for (x=0; x < width ; ++x)
250 {
251 setcolor(radiance_scanline[x],
252 PXL2DBL(pixar_scanline[x].Red),
253 PXL2DBL(pixar_scanline[x].Green),
254 PXL2DBL(pixar_scanline[x].Blue));
255 }
256 radiance_writescanline(out,radiance_scanline,width);
257 }
258 picPostDecodeScanline(in);
259 PicClose(in);
260 fclose(out);
261 }
262
263
264 radiance_writeheader(fp,x,y)
265 FILE *fp;
266 int x;
267 int y;
268 {
269 printargs(global_argc,global_argv,fp);
270 fputc('\n',fp);
271 fprtresolu(x, y, fp);
272 fflush(fp);
273 }
274
275
276 radiance_writescanline(fp,buf,x)
277 FILE *fp;
278 COLOR *buf;
279 int x;
280 {
281 if (fwritescan(buf,x,fp) < 0)
282 {
283 fprintf(stderr,"write error?\n");
284 perror("fwrite");
285 exit(1);
286 }
287 }
