root/radiance/ray/src/px/ra_pixar.c
Revision: 1.4
Committed: Mon Nov 11 14:01:21 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.3: +5 -12 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /* ra_pixar.c */
8 /*
9 * convert from RADIANCE image file to PIXAR image file. (or vice versa)
10 *
11 * David G. Jones July 1989
12 */
13 /* External functions called:
14 *
15 * header.c:
16 * getheader(fp,func);
17 * printargs(argc,argv,fp);
18 * color.c:
19 * freadscan(scanline,len,fp);
20 * fwritescan(scanline,len,fp);
21 */
22
23 #include <stdio.h>
24 #include <math.h>
25
26 /* PIXAR */
27 #include <picio.h>
28 #include <pixeldef.h>
29 #include <chad.h>
30
31 /* RADIANCE (color.h conflicts with PIXAR includes) ugh!! */
32 #ifdef undef
33 #include "color.h"
34 #else
35 #define RED 0
36 #define GRN 1
37 #define BLU 2
38 #define EXP 3
39 #define colval(col,pri) ((col)[pri])
40 #define setcolor(col,r,g,b) \
41 ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
42 typedef float COLOR[3]; /* red, green, blue */
43 #endif
44 #include "resolu.h"
45
46
47 char *ProgramName;
48 int global_argc;
49 char **global_argv;
50
51 /* RADIANCE global variables */
52 FILE *radiance_fp = NULL;
53 double radiance_pixel();
54
55 usage()
56 {
57 fprintf(stderr,"usage: %s radiance.pic pixar.pix\n",ProgramName);
58 fprintf(stderr," or %s -r pixar.pix radiance.pic\n",ProgramName);
59 exit(1);
60 }
61
62
63 main(argc,argv)
64 int argc;
65 char *argv[];
66 {
67 char *infile;
68 char *outfile;
69 int i;
70 int reverse = 0;
71
72 ProgramName=argv[0];
73 if (argc < 3)
74 usage();
75 infile=argv[argc-2];
76 outfile=argv[argc-1];
77 for (i=1; i < argc-2 ; ++i)
78 if (!strcmp(argv[i],"-r"))
79 reverse=1;
80 else
81 usage();
82
83 if (reverse)
84 {
85 global_argc=argc;
86 global_argv=argv;
87 pix_ra(infile,outfile);
88 }
89 else
90 ra_pix(infile,outfile);
91 }
92
93 ra_pix(infile,outfile)
94 char *infile;
95 char *outfile;
96 {
97 /* PIXAR variables */
98 RGBAPixelType *pixar_scanline;
99 PFILE *out;
100 /* RADIANCE variables */
101 COLOR *radiance_scanline;
102 /* regular variables */
103 int width;
104 int height;
105 register int x;
106 register int y;
107
108 /* get width, height from radiance file */
109 radiance_getsize(infile,&width,&height);
110 radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR));
111 pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType));
112 if (!radiance_scanline || !pixar_scanline)
113 {
114 fprintf(stderr,"not enough memory?\n");
115 perror("malloc");
116 exit(1);
117 }
118 bzero(pixar_scanline,width*sizeof(RGBAPixelType));
119
120 PicSetForce(1);
121 PicSetPsize(width,height);
122 PicSetTsize(width,height);
123 PicSetPformat(PF_RGB);
124 PicSetPstorage(PS_12DUMP);
125 PicSetPmatting(PM_NONE);
126 PicSetOffset(0,0);
127 PicSetLabel("converted from RADIANCE format by ra_pixar");
128 if (!(out=PicCreat(outfile,0666)))
129 {
130 fprintf(stderr,"can't open PIXAR image file `%s'\n",outfile);
131 perror("open");
132 exit(1);
133 }
134
135 picPreEncodeScanline(out,0);
136 for (y=0; y < height ; ++y)
137 {
138 radiance_readscanline(radiance_scanline,width);
139 for (x=0; x < width ; ++x)
140 {
141 SetRGBColor(&pixar_scanline[x],
142 DBL2PXL(radiance_pixel(radiance_scanline[x],RED)),
143 DBL2PXL(radiance_pixel(radiance_scanline[x],GRN)),
144 DBL2PXL(radiance_pixel(radiance_scanline[x],BLU)));
145 }
146 picEncodeScanline(out,pixar_scanline);
147 }
148 picPostEncodeScanline(out);
149 fclose(radiance_fp);
150 PicClose(out);
151 }
152
153
154 radiance_getsize(filename,w,h)
155 char *filename;
156 int *w;
157 int *h;
158 {
159 if (!(radiance_fp=fopen(filename,"r")))
160 {
161 fprintf(stderr,"can't open RADIANCE image file `%s'\n",filename);
162 perror("open");
163 exit(1);
164 }
165 getheader(radiance_fp,NULL);
166 if (fgetresolu(w, h, radiance_fp) < 0)
167 {
168 fprintf(stderr,"bad RADIANCE format\n");
169 exit(1);
170 }
171 }
172
173
174 radiance_readscanline(buf,x)
175 COLOR *buf;
176 int x;
177 {
178 if (freadscan(buf,x,radiance_fp) < 0)
179 {
180 fprintf(stderr,"read error?\n");
181 perror("fread");
182 exit(1);
183 }
184 }
185
186
187 double radiance_pixel(pixel,i)
188 COLOR pixel;
189 int i;
190 {
191 double value;
192
193 value=colval(pixel,i);
194 if (value < 0.0)
195 return 0.0;
196 else if (value> 1.0)
197 return 1.0;
198 return value;
199 }
200
201 pix_ra(infile,outfile)
202 char *infile;
203 char *outfile;
204 {
205 /* PIXAR variables */
206 RGBAPixelType *pixar_scanline;
207 PFILE *in;
208 /* RADIANCE variables */
209 COLOR *radiance_scanline;
210 FILE *out;
211 /* regular variables */
212 int width;
213 int height;
214 register int x;
215 register int y;
216
217 if (!(in=PicOpen(infile,"r")))
218 {
219 fprintf(stderr,"can't open PIXAR image file `%s'\n",infile);
220 perror("open");
221 exit(1);
222 }
223 if (!(out=fopen(outfile,"w")))
224 {
225 fprintf(stderr,"can't open RADIANCE image file `%s'\n",outfile);
226 perror("open");
227 exit(1);
228 }
229
230 /* get width, height from PIXAR file */
231 width=in->Pwidth;
232 height=in->Pheight;
233
234 /* allocate scan line space */
235 radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR));
236 pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType));
237 if (!radiance_scanline || !pixar_scanline)
238 {
239 fprintf(stderr,"not enough memory?\n");
240 perror("malloc");
241 exit(1);
242 }
243
244 /* write out the RADIANCE header */
245 radiance_writeheader(out,width,height);
246
247 picPreDecodeScanline(in,0);
248 for (y=0; y < height ; ++y)
249 {
250 picDecodeScanline(in,pixar_scanline);
251 for (x=0; x < width ; ++x)
252 {
253 setcolor(radiance_scanline[x],
254 PXL2DBL(pixar_scanline[x].Red),
255 PXL2DBL(pixar_scanline[x].Green),
256 PXL2DBL(pixar_scanline[x].Blue));
257 }
258 radiance_writescanline(out,radiance_scanline,width);
259 }
260 picPostDecodeScanline(in);
261 PicClose(in);
262 fclose(out);
263 }
264
265
266 radiance_writeheader(fp,x,y)
267 FILE *fp;
268 int x;
269 int y;
270 {
271 printargs(global_argc,global_argv,fp);
272 fputc('\n',fp);
273 fprtresolu(x, y, fp);
274 fflush(fp);
275 }
276
277
278 radiance_writescanline(fp,buf,x)
279 FILE *fp;
280 COLOR *buf;
281 int x;
282 {
283 if (fwritescan(buf,x,fp) < 0)
284 {
285 fprintf(stderr,"write error?\n");
286 perror("fwrite");
287 exit(1);
288 }
289 }
