1 |
greg |
1.3 |
#ifndef lint |
2 |
greg |
2.5 |
static const char RCSid[] = "$Id: ra_pixar.c,v 2.4 2004/01/02 10:25:13 schorsch Exp $"; |
3 |
greg |
1.3 |
#endif |
4 |
greg |
1.1 |
/* ra_pixar.c */ |
5 |
6 |
* convert from RADIANCE image file to PIXAR image file. (or vice versa) |
7 |
8 |
* David G. Jones July 1989 |
9 |
10 |
/* External functions called: |
11 |
12 |
* header.c: |
13 |
* getheader(fp,func); |
14 |
* printargs(argc,argv,fp); |
15 |
* color.c: |
16 |
* freadscan(scanline,len,fp); |
17 |
* fwritescan(scanline,len,fp); |
18 |
19 |
20 |
#include <stdio.h> |
21 |
schorsch |
2.3 |
#include <string.h> |
22 |
greg |
1.1 |
#include <math.h> |
23 |
greg |
2.2 |
#include <time.h> |
24 |
greg |
1.1 |
25 |
/* PIXAR */ |
26 |
#include <picio.h> |
27 |
#include <pixeldef.h> |
28 |
#include <chad.h> |
29 |
30 |
/* RADIANCE (color.h conflicts with PIXAR includes) ugh!! */ |
31 |
#ifdef undef |
32 |
#include "color.h" |
33 |
#else |
34 |
#define RED 0 |
35 |
#define GRN 1 |
36 |
#define BLU 2 |
37 |
#define EXP 3 |
38 |
#define colval(col,pri) ((col)[pri]) |
39 |
#define setcolor(col,r,g,b) \ |
40 |
((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b)) |
41 |
typedef float COLOR[3]; /* red, green, blue */ |
42 |
#endif |
43 |
greg |
1.4 |
#include "resolu.h" |
44 |
greg |
1.1 |
45 |
46 |
char *ProgramName; |
47 |
int global_argc; |
48 |
char **global_argv; |
49 |
50 |
/* RADIANCE global variables */ |
51 |
FILE *radiance_fp = NULL; |
52 |
double radiance_pixel(); |
53 |
54 |
usage() |
55 |
56 |
fprintf(stderr,"usage: %s radiance.pic pixar.pix\n",ProgramName); |
57 |
fprintf(stderr," or %s -r pixar.pix radiance.pic\n",ProgramName); |
58 |
exit(1); |
59 |
60 |
61 |
62 |
main(argc,argv) |
63 |
int argc; |
64 |
char *argv[]; |
65 |
66 |
char *infile; |
67 |
char *outfile; |
68 |
int i; |
69 |
int reverse = 0; |
70 |
71 |
ProgramName=argv[0]; |
72 |
if (argc < 3) |
73 |
usage(); |
74 |
infile=argv[argc-2]; |
75 |
outfile=argv[argc-1]; |
76 |
for (i=1; i < argc-2 ; ++i) |
77 |
if (!strcmp(argv[i],"-r")) |
78 |
reverse=1; |
79 |
else |
80 |
usage(); |
81 |
82 |
if (reverse) |
83 |
84 |
global_argc=argc; |
85 |
global_argv=argv; |
86 |
pix_ra(infile,outfile); |
87 |
88 |
else |
89 |
ra_pix(infile,outfile); |
90 |
91 |
92 |
ra_pix(infile,outfile) |
93 |
char *infile; |
94 |
char *outfile; |
95 |
96 |
/* PIXAR variables */ |
97 |
RGBAPixelType *pixar_scanline; |
98 |
PFILE *out; |
99 |
/* RADIANCE variables */ |
100 |
COLOR *radiance_scanline; |
101 |
/* regular variables */ |
102 |
int width; |
103 |
int height; |
104 |
register int x; |
105 |
register int y; |
106 |
107 |
/* get width, height from radiance file */ |
108 |
radiance_getsize(infile,&width,&height); |
109 |
radiance_scanline=(COLOR *)malloc(width*sizeof(COLOR)); |
110 |
pixar_scanline=(RGBAPixelType *)malloc(width*sizeof(RGBAPixelType)); |
111 |
if (!radiance_scanline || !pixar_scanline) |
112 |
113 |
fprintf(stderr,"not enough memory?\n"); |
114 |
perror("malloc"); |
115 |
exit(1); |
116 |
117 |
schorsch |
2.3 |
memset(pixar_scanline, '\0', width*sizeof(RGBAPixelType)); |
118 |
greg |
1.1 |
119 |
PicSetForce(1); |
120 |
PicSetPsize(width,height); |
121 |
PicSetTsize(width,height); |
122 |
PicSetPformat(PF_RGB); |
123 |
PicSetPstorage(PS_12DUMP); |
124 |
PicSetPmatting(PM_NONE); |
125 |
PicSetOffset(0,0); |
126 |
PicSetLabel("converted from RADIANCE format by ra_pixar"); |
127 |
if (!(out=PicCreat(outfile,0666))) |
128 |
129 |
fprintf(stderr,"can't open PIXAR image file `%s'\n",outfile); |
130 |
perror("open"); |
131 |
exit(1); |
132 |
133 |
134 |
picPreEncodeScanline(out,0); |
135 |
for (y=0; y < height ; ++y) |
136 |
137 |
radiance_readscanline(radiance_scanline,width); |
138 |
for (x=0; x < width ; ++x) |
139 |
140 |
SetRGBColor(&pixar_scanline[x], |
141 |
DBL2PXL(radiance_pixel(radiance_scanline[x],RED)), |
142 |
DBL2PXL(radiance_pixel(radiance_scanline[x],GRN)), |
143 |
DBL2PXL(radiance_pixel(radiance_scanline[x],BLU))); |
144 |
145 |
picEncodeScanline(out,pixar_scanline); |
146 |
147 |
picPostEncodeScanline(out); |
148 |
fclose(radiance_fp); |
149 |
PicClose(out); |
150 |
151 |
152 |
153 |
radiance_getsize(filename,w,h) |
154 |
char *filename; |
155 |
int *w; |
156 |
int *h; |
157 |
158 |
if (!(radiance_fp=fopen(filename,"r"))) |
159 |
160 |
fprintf(stderr,"can't open RADIANCE image file `%s'\n",filename); |
161 |
perror("open"); |
162 |
exit(1); |
163 |
164 |
schorsch |
2.4 |
getheader(radiance_fp,NULL,NULL); |
165 |
greg |
1.4 |
if (fgetresolu(w, h, radiance_fp) < 0) |
166 |
greg |
1.1 |
167 |
fprintf(stderr,"bad RADIANCE format\n"); |
168 |
exit(1); |
169 |
170 |
171 |
172 |
173 |
radiance_readscanline(buf,x) |
174 |
COLOR *buf; |
175 |
int x; |
176 |
177 |
if (freadscan(buf,x,radiance_fp) < 0) |
178 |
179 |
fprintf(stderr,"read error?\n"); |
180 |
perror("fread"); |
181 |
exit(1); |
182 |
183 |
184 |
185 |
186 |
double radiance_pixel(pixel,i) |
187 |
COLOR pixel; |
188 |
int i; |
189 |
190 |
double value; |
191 |
192 |
value=colval(pixel,i); |
193 |
if (value < 0.0) |
194 |
return 0.0; |
195 |
else if (value> 1.0) |
196 |
return 1.0; |
197 |
return value; |
198 |
199 |
200 |
pix_ra(infile,outfile) |
201 |
char *infile; |
202 |
char *outfile; |
203 |
204 |
205 |
206 |
PFILE *in; |
207 |
208 |
209 |
FILE *out; |
210 |
211 |
int width; |
212 |
int height; |
213 |
register int x; |
214 |
register int y; |
215 |
216 |
if (!(in=PicOpen(infile,"r"))) |
217 |
218 |
fprintf(stderr,"can't open PIXAR image file `%s'\n",infile); |
219 |
perror("open"); |
220 |
exit(1); |
221 |
222 |
if (!(out=fopen(outfile,"w"))) |
223 |
224 |
fprintf(stderr,"can't open RADIANCE image file `%s'\n",outfile); |
225 |
perror("open"); |
226 |
exit(1); |
227 |
228 |
229 |
/* get width, height from PIXAR file */ |
230 |
width=in->Pwidth; |
231 |
height=in->Pheight; |
232 |
233 |
/* allocate scan line space */ |
234 |
235 |
236 |
237 |
238 |
239 |
perror("malloc"); |
240 |
exit(1); |
241 |
242 |
243 |
/* write out the RADIANCE header */ |
244 |
radiance_writeheader(out,width,height); |
245 |
246 |
picPreDecodeScanline(in,0); |
247 |
248 |
249 |
picDecodeScanline(in,pixar_scanline); |
250 |
251 |
252 |
setcolor(radiance_scanline[x], |
253 |
PXL2DBL(pixar_scanline[x].Red), |
254 |
PXL2DBL(pixar_scanline[x].Green), |
255 |
PXL2DBL(pixar_scanline[x].Blue)); |
256 |
257 |
radiance_writescanline(out,radiance_scanline,width); |
258 |
259 |
picPostDecodeScanline(in); |
260 |
PicClose(in); |
261 |
fclose(out); |
262 |
263 |
264 |
265 |
radiance_writeheader(fp,x,y) |
266 |
FILE *fp; |
267 |
int x; |
268 |
int y; |
269 |
270 |
printargs(global_argc,global_argv,fp); |
271 |
fputc('\n',fp); |
272 |
greg |
1.4 |
fprtresolu(x, y, fp); |
273 |
greg |
1.1 |
fflush(fp); |
274 |
275 |
276 |
277 |
radiance_writescanline(fp,buf,x) |
278 |
FILE *fp; |
279 |
COLOR *buf; |
280 |
int x; |
281 |
282 |
if (fwritescan(buf,x,fp) < 0) |
283 |
284 |
fprintf(stderr,"write error?\n"); |
285 |
perror("fwrite"); |
286 |
exit(1); |
287 |
288 |
