--- ray/src/px/ra_pict.c 2003/06/05 19:29:34 2.9 +++ ray/src/px/ra_pict.c 2004/03/28 20:33:14 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ra_pict.c,v 2.9 2003/06/05 19:29:34 schorsch Exp $"; +static const char RCSid[] = "$Id: ra_pict.c,v 2.10 2004/03/28 20:33:14 schorsch Exp $"; #endif /* Convert an Radiance image to APPLE pict format. * @@ -31,10 +31,26 @@ int verbose = 0; float gamcor = 2.0; int bradj = 0; - /* First some utility routines */ +static void putrect(int xorg, int yorg, int xsize, int ysize); +static void putfprect(int xorg, int yorg, int xsize, int ysize); +static void putalong(long l); +static void putashort(short s); +static void putbyte(int b); +static void putbytes(unsigned char *buf, int n ); +static void putpict(int xsize, int ysize); +static void getrow(FILE *in, char *cbuf, int xsize); +static int packbits(unsigned char *ibits, unsigned char *pbits, int nbits); +static void usage(void); -putrect(xorg,yorg,xsize,ysize) -int xorg, yorg, xsize, ysize; + + /* First some utility routines */ +static void +putrect( + int xorg, + int yorg, + int xsize, + int ysize +) { putashort(yorg); putashort(xorg); @@ -42,8 +58,13 @@ int xorg, yorg, xsize, ysize; putashort(xsize); } -putfprect(xorg,yorg,xsize,ysize) -int xorg, yorg, xsize, ysize; +static void +putfprect( + int xorg, + int yorg, + int xsize, + int ysize +) { putalong(yorg<<16); putalong(xorg<<16); @@ -51,8 +72,10 @@ int xorg, yorg, xsize, ysize; putalong(xsize<<16); } -putalong(l) -long l; +static void +putalong( + long l +) { putbyte((l>>24)&0xff); putbyte((l>>16)&0xff); @@ -60,15 +83,19 @@ long l; putbyte((l>>0)&0xff); } -putashort(s) -short s; +static void +putashort( + short s +) { putbyte((s>>8)&0xff); putbyte((s>>0)&0xff); } -putbyte(b) -int b; +static void +putbyte( + int b +) { if (putc(b,stdout) == EOF && ferror(stdout)) { fprintf(stderr,"%s: error on write\n", progname); @@ -77,9 +104,11 @@ int b; outbytes++; } -putbytes(buf,n) -unsigned char *buf; -int n; +static void +putbytes( + unsigned char *buf, + int n +) { if(!fwrite(buf,n,1,stdout)) { fprintf(stderr,"%s: error on write\n", progname); @@ -88,9 +117,11 @@ int n; outbytes+=n; } -main(argc,argv) -int argc; -char **argv; +int +main( + int argc, + char **argv +) { int xsize, ysize; int i, picsize; @@ -123,7 +154,8 @@ char **argv; goto outofparse; break; /* NOTREACHED */ - otherwise: usage(); + default: + usage(); break; } else @@ -207,9 +239,11 @@ outofparse: return 0; /* lint fodder */ } -putpict(xsize, ysize) -int xsize; -int ysize; +static void +putpict( + int xsize, + int ysize +) { int y; int nbytes, rowbytes; @@ -280,10 +314,12 @@ int ysize; free(pbuf); } -int getrow(in, cbuf, xsize) -FILE *in; -char *cbuf; -int xsize; +static void +getrow( + FILE *in, + char *cbuf, + int xsize +) { extern char *tempbuffer(); /* defined in color.c */ COLR *scanin = NULL; @@ -314,11 +350,13 @@ int xsize; } -packbits(ibits,pbits,nbits) -unsigned char *ibits, *pbits; -int nbits; +static int +packbits( + unsigned char *ibits, + unsigned char *pbits, + int nbits +) { - int bytes; /* UNUSED */ unsigned char *sptr; unsigned char *ibitsend; unsigned char *optr = pbits; @@ -359,7 +397,8 @@ int nbits; return optr-pbits; } -usage() +static void +usage(void) { fprintf(stderr, "Usage: %s [-v] [-g gamma] [infile [outfile]]\n", progname);
