root/radiance/ray/src/px/ra_pict.c
Revision: 2.5
Committed: Fri Oct 30 09:14:04 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.4: +31 -23 lines
changes for 32-bit PC port
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /* Convert an Radiance image to APPLE pict format.
8 *
9 * Orginally Iris to PICT by Paul Haeberli - 1990
10 * Hacked into Rad to PICT by Russell Street 1990
11 *
12 * History:
13 * V 1 -- Does basic conversion
14 * V 1.1 (2/11/91) -- Added options for Gamma
15 * -- verbose option
16 * -- man page
17 * -- better about allocating buffers
18 * V 1.2 (19/11/91) -- Revised to handle opening "The Radiance Way"
19 * -- Added exposure level adjustment
20 */
21
22 #include <stdio.h>
23 #ifdef MSDOS
24 #include <fcntl.h>
25 #endif
26
27 #include "pict.h"
28 #include "color.h"
29 #include "resolu.h"
30
31 extern char *malloc();
32
33 int outbytes; /* This had better be 32 bits! */
34 char *progname;
35 int verbose = 0;
36 float gamma = 2.0;
37 int bradj = 0;
38
39 /* First some utility routines */
40
41 putrect(xorg,yorg,xsize,ysize)
42 int xorg, yorg, xsize, ysize;
43 {
44 putashort(yorg);
45 putashort(xorg);
46 putashort(ysize);
47 putashort(xsize);
48 }
49
50 putfprect(xorg,yorg,xsize,ysize)
51 int xorg, yorg, xsize, ysize;
52 {
53 putalong(yorg<<16);
54 putalong(xorg<<16);
55 putalong(ysize<<16);
56 putalong(xsize<<16);
57 }
58
59 putalong(l)
60 long l;
61 {
62 putbyte((l>>24)&0xff);
63 putbyte((l>>16)&0xff);
64 putbyte((l>>8)&0xff);
65 putbyte((l>>0)&0xff);
66 }
67
68 putashort(s)
69 short s;
70 {
71 putbyte((s>>8)&0xff);
72 putbyte((s>>0)&0xff);
73 }
74
75 putbyte(b)
76 int b;
77 {
78 if (putc(b,stdout) == EOF && ferror(stdout)) {
79 fprintf(stderr,"%s: error on write\n", progname);
80 exit(1);
81 }
82 outbytes++;
83 }
84
85 putbytes(buf,n)
86 unsigned char *buf;
87 int n;
88 {
89 if(!fwrite(buf,n,1,stdout)) {
90 fprintf(stderr,"%s: error on write\n", progname);
91 exit(1);
92 }
93 outbytes+=n;
94 }
95
96 main(argc,argv)
97 int argc;
98 char **argv;
99 {
100 int xsize, ysize;
101 int i, picsize;
102 int ssizepos, lsizepos;
103 #ifdef MSDOS
104 extern int _fmode;
105 _fmode = O_BINARY;
106 setmode(fileno(stdin), O_BINARY);
107 setmode(fileno(stdout), O_BINARY);
108 #endif
109 progname = argv[0];
110
111 for (i = 1; i < argc ; i++)
112 if (argv[i][0] == '-')
113 switch (argv[i][1]) {
114 case 'g': gamma = atof(argv[++i]);
115 break;
116
117 case 'e': if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
118 usage();
119 else
120 bradj = atoi(argv[++i]);
121 break;
122
123 case 'v': ;
124 verbose = 1;
125 break;
126
127 case 'r': fprintf(stderr, "Sorry. Get a Macintosh :-)\n");
128 exit(1);
129
130 case '-': i++;
131 goto outofparse;
132 break; /* NOTREACHED */
133
134 otherwise: usage();
135 break;
136 }
137 else
138 break;
139
140 outofparse:
141
142 if (i < argc - 2)
143 usage();
144
145 if (i <= argc - 1 && freopen(argv[i], "r", stdin) == NULL) {
146 fprintf(stderr, "%s: can not open input \"%s\"\n",
147 progname, argv[i]);
148 exit(1);
149 }
150
151 if (i <= argc - 2 && freopen(argv[i+1], "w", stdout) == NULL) {
152 fprintf(stderr, "%s: can not open input \"%s\"\n",
153 progname, argv[i+1]);
154 exit(1);
155 }
156
157 #ifdef DEBUG
158 fprintf(stderr, "Input file: %s\n", i <= argc - 1 ? argv[i] : "stdin");
159 fprintf(stderr, "Outut file: %s\n", i <= argc - 2 ? argv[i+1] : "stdout" );
160 fprintf(stderr, "Gamma: %f\n", gamma);
161 fprintf(stderr, "Brightness adjust: %d\n", bradj);
162 fprintf(stderr, "Verbose: %s\n", verbose ? "on" : "off");
163 #endif
164
165
166 /* OK. Now we read the size of the Radiance picture */
167 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
168 fgetresolu(&xsize, &ysize, stdin) < 0 /* != (YMAJOR|YDECR) */ ) {
169 fprintf(stderr, "%s: not a radiance picture\n", progname);
170 exit(1);
171 }
172
173 /* Set the gamma correction */
174
175 setcolrgam(gamma);
176
177 for(i=0; i<HEADER_SIZE; i++)
178 putbyte(0);
179
180 ssizepos = outbytes;
181 putashort(0); /* low 16 bits of file size less HEADER_SIZE */
182 putrect(0,0,xsize,ysize); /* bounding box of picture */
183 putashort(PICT_picVersion);
184 putashort(0x02ff); /* version 2 pict */
185 putashort(PICT_reservedHeader); /* reserved header opcode */
186
187 lsizepos = outbytes;
188 putalong(0); /* full size of the file */
189 putfprect(0,0,xsize,ysize); /* fixed point bounding box of picture */
190 putalong(0); /* reserved */
191
192 putashort(PICT_clipRgn); /* the clip region */
193 putashort(10);
194 putrect(0,0,xsize,ysize);
195
196 if (verbose)
197 fprintf(stderr, "%s: The picture is %d by %d, with a gamma of %f\n",
198 progname, xsize, ysize, gamma);
199
200
201 putpict(xsize, ysize); /* Here is where all the work is done */
202
203 putashort(PICT_EndOfPicture); /* end of pict */
204
205 picsize = outbytes-HEADER_SIZE;
206 fseek(stdout,ssizepos,0);
207 putashort(picsize&0xffff);
208 fseek(stdout,lsizepos,0);
209 putalong(picsize);
210
211 fclose(stdout);
212 fclose(stdin);
213
214 exit(0);
215 return 0; /* lint fodder */
216 }
217
218 putpict(xsize, ysize)
219 int xsize;
220 int ysize;
221 {
222 int y;
223 int nbytes, rowbytes;
224 char *cbuf, *pbuf;
225
226 cbuf = malloc(4 * xsize);
227
228 if (cbuf == NULL) {
229 fprintf(stderr, "%s: not enough memory\n", progname);
230 exit(1);
231 }
232
233 pbuf = malloc(4 * xsize);
234
235 if (pbuf == NULL) {
236 fprintf(stderr, "%s: not enough memory\n", progname);
237 exit(1);
238 }
239
240 putashort(PICT_Pack32BitsRect); /* 32 bit rgb */
241 rowbytes = 4*xsize;
242 putalong(0x000000ff); /* base address */
243
244
245 if(rowbytes&1)
246 rowbytes++;
247 putashort(rowbytes|0x8000); /* rowbytes */
248 putrect(0,0,xsize,ysize); /* bounds */
249 putashort(0); /* version */
250
251 putashort(4); /* packtype */
252 putalong(0); /* packsize */
253 putalong(72<<16); /* hres */
254 putalong(72<<16); /* vres */
255
256 putashort(16); /* pixeltype */
257 putashort(32); /* pixelsize */
258 putashort(3); /* cmpcount */
259
260
261 putashort(8); /* cmpsize */
262 putalong(0); /* planebytes */
263 putalong(0); /* pmtable */
264 putalong(0); /* pmreserved */
265
266
267 putrect(0,0,xsize,ysize); /* scr rect */
268 putrect(0,0,xsize,ysize); /* dest rect */
269
270
271 putashort(0x40); /* transfer mode */
272
273 for(y=0; y<ysize; y++) {
274 getrow(stdin, cbuf, xsize);
275
276 nbytes = packbits(cbuf,pbuf,24*xsize);
277 if(rowbytes>250)
278 putashort(nbytes);
279 else
280 putbyte(nbytes);
281 putbytes(pbuf,nbytes);
282 }
283
284 if(outbytes&1)
285 putbyte(0);
286
287 free(cbuf);
288 free(pbuf);
289 }
290
291 int getrow(in, cbuf, xsize)
292 FILE *in;
293 char *cbuf;
294 int xsize;
295 {
296 extern char *tempbuffer(); /* defined in color.c */
297 COLR *scanin = NULL;
298 int x;
299
300 if ((scanin = (COLR *)tempbuffer(xsize*sizeof(COLR))) == NULL) {
301 fprintf(stderr, "%s: not enough memory\n", progname);
302 exit(1);
303 }
304
305 if (freadcolrs(scanin, xsize, in) < 0) {
306 fprintf(stderr, "%s: read error\n", progname);
307 exit(1);
308 }
309
310 if (bradj) /* Adjust exposure level */
311 shiftcolrs(scanin, xsize, bradj);
312
313
314 colrs_gambs(scanin, xsize); /* Gamma correct it */
315
316 for (x = 0; x < xsize; x++) {
317 cbuf[x] = scanin[x][RED];
318 cbuf[xsize + x] = scanin[x][GRN];
319 cbuf[2*xsize + x] = scanin[x][BLU];
320 }
321
322 }
323
324
325 packbits(ibits,pbits,nbits)
326 unsigned char *ibits, *pbits;
327 int nbits;
328 {
329 int bytes; /* UNUSED */
330 unsigned char *sptr;
331 unsigned char *ibitsend;
332 unsigned char *optr = pbits;
333 int nbytes, todo, cc, count;
334
335 nbytes = ((nbits-1)/8)+1;
336 ibitsend = ibits+nbytes;
337 while(ibits<ibitsend) {
338 sptr = ibits;
339 ibits += 2;
340 while((ibits<ibitsend)&&((ibits[-2]!=ibits[-1])||(ibits[-1]!=ibits[0])))
341 ibits++;
342 if(ibits != ibitsend) {
343 ibits -= 2;
344 }
345 count = ibits-sptr;
346 while(count) {
347 todo = count>127 ? 127:count;
348 count -= todo;
349 *optr++ = todo-1;
350 while(todo--)
351 *optr++ = *sptr++;
352 }
353 if(ibits == ibitsend)
354 break;
355 sptr = ibits;
356 cc = *ibits++;
357 while( (ibits<ibitsend) && (*ibits == cc) )
358 ibits++;
359 count = ibits-sptr;
360 while(count) {
361 todo = count>128 ? 128:count;
362 count -= todo;
363 *optr++ = 257-todo;
364 *optr++ = cc;
365 }
366 }
367 return optr-pbits;
368 }
369
370 usage()
371 {
372 fprintf(stderr, "Usage: %s [-v] [-g gamma] [infile [outfile]]\n",
373 progname);
374 exit(2);
375 }
