root/radiance/ray/src/px/ra_pict.c
Sat Mar 5 17:30:38 2022 UTC (3 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.12: +2 -3 lines
Diff to previous 2.12
fix: removed stray tempbuffer() declaration
Fri Jul 19 17:37:56 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.11: +2 -4 lines
Tue Mar 20 18:45:04 2018 UTC (7 years, 3 months ago) by greg
Added missing rtio.h include to redefine getc, putc, etc.
Sun Mar 28 20:33:14 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.9: +70 -31 lines
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Changes since 2.8: +5 -10 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.7: +4 -8 lines
Mon Jul 19 12:04:35 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.6: +5 -5 lines
changed gamma to gamcor
Fri Jun 4 14:47:37 1993 UTC (32 years, 1 month ago) by greg
added math.h for atof() usage
Fri Oct 30 09:14:04 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.4: +31 -23 lines
changes for 32-bit PC port
Thu Dec 19 14:52:09 1991 UTC (33 years, 6 months ago) by greg
Changes since 2.3: +0 -1 lines
Wed Nov 27 09:14:03 1991 UTC (33 years, 7 months ago) by greg
removed reference to stdlib.h
Thu Nov 21 11:34:10 1991 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +158 -63 lines
bug fixes from second version
Tue Nov 12 16:05:39 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.4: +0 -2 lines
Diff to previous 1.4
Mon Nov 11 14:01:55 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.3: +6 -2 lines
Diff to previous 1.3
Mon Oct 28 16:41:31 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.2: +2 -1 lines
Diff to previous 1.2
compatibility fixes
Wed Oct 23 09:33:11 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.1: +5 -3 lines
Diff to previous 1.1
added ra_pict program
Wed Oct 23 09:26:35 1991 UTC (33 years, 8 months ago) by greg
